#2676724 - 03/02/13 12:37 PM bad oil pump, show no oil on dipstick??
Twisted2k Offline
Loc: MN
So Driving home this morning, all is good. I am about to pull into my parking spot, notice a sever shudder and loss of some power. Along with engine noise, clunking and such. Turn it off immediately. felt like it was running on 3 cylinders...check COPS, all seem to be tight, check oil level and it is dry, just a drop on the bottom of the dip stick. Checked coolant, looks green, a lil dark...but not milky or overly oily. I checked my parking spot from the night before,no oil spot...so my problem is where did all the oil go? would a bad oil pump show no oil in the case? my car burns minimal oil, and as of now has not leaked any...I am going to fill the oil to proper level before I try to start it again.
So why would it run fine, then within 5 seconds dump all oil and lose most power? I don't think I would of caused much damage as it ran fine and as soon as there was any shudder it was powered off within 10 seconds and only had a slight load.
ANY idea's of where to start??
Edited by Twisted2k (03/02/13 12:48 PM)
2000 Interceptor, 115k miles, no mods currently...only major problem leaking coolant xover...fixed w/ new manifold.
#2676728 - 03/02/13 12:53 PM Re: bad oil pump, show no oil on dipstick?? [Re: Twisted2k]
Oil filter come loose? Oil cooler o-rings? Oil filter adapter gasket (where it bolts to the block)? Drain plug come loose?
No, a bad oil pump wouldn't cause the dipstick to read low.
After you refill it, when you go to start the engine hold the pedal to the floor...that will keep it from starting and let you crank it around some to build oil pressure before it fires.
#2676731 - 03/02/13 01:03 PM Re: bad oil pump, show no oil on dipstick?? [Re: Twisted2k]
Twisted2k Offline
Loc: MN
I was thinking one of those too, but I couldn't see any oil pooling around any of said parts, but I only took a quick peek. Ill check it more thoroughly when I go out later...
#2676752 - 03/02/13 02:27 PM Re: bad oil pump, show no oil on dipstick?? [Re: Twisted2k]
The oil went some place...
If it isn't leaking it's burning, no other choices...
Now with P/S & PDB
#2676781 - 03/02/13 03:59 PM Re: bad oil pump, show no oil on dipstick?? [Re: Twisted2k]
ChrisM_NY Offline
Loc: Saratoga, New York
The oil from the top end most likely hasnt drained into the pan yet. Same happens if I check after running - check after 20 minutes being off you'll get more accurate measurement . Hopefully you'll be able to measure how much if its burning. Also A plugged positive crankcase ventilation PCV valve will cause more oil burning when its not working-
2007 CVPI SAP 115K/800hrs
#2676782 - 03/02/13 04:03 PM Re: bad oil pump, show no oil on dipstick?? [Re: Twisted2k]
Twisted2k Offline
Loc: MN
Well Im sure it burned it up, but never seen it smoke, or smelled it. never had a oil problem. I filled it up to proper level, and crank it a bit to get oil pressure. Start it up, sound wretched...IDK but it sounds like this motor is toast. Ill make a video In a bit and put it up, u all can tell me what u think. I am sad...
#2676785 - 03/02/13 04:06 PM Re: bad oil pump, show no oil on dipstick?? [Re: Twisted2k]
deezdrama Offline
Loc: central il
Make sure it isnt your oil filter cooler gasket... they like to go out on these.. was first thing I had to replace when I got mine...but u say theres no visible leaks... is there visible smoke?
Have u cleaned your maf?
imgurl
<<<2007 Crown Vic P71>>>
175k
Precision Industries Stallion Torque Converter, New Ford Racing PI Intake, Polished plenum, Cat delete/duals/Thrush 2 chambers/3.5" tips, 18" Bullitt rims, 5% tint all around
<<<2010 White P71>>>
105k
15% tint, blacked door pillars, marauder corner lamps, HID projector headlights, 18" staggered Bullitts..... work in progress
#2676792 - 03/02/13 04:19 PM Re: bad oil pump, show no oil on dipstick?? [Re: Twisted2k]
Twisted2k Offline
Loc: MN
No visible leaks, and no I haven't cleaned my MAF...but this is my new issue, watch video.
http://youtu.be/P_mFYfRwha8
#2676824 - 03/02/13 05:50 PM Re: bad oil pump, show no oil on dipstick?? [Re: Twisted2k]
toxic29 Offline
Loc: California
No oil = no engine... sounds terminal
1999 cvpi 198.xxx and counting all stock. street appearance pkg cloth interior deep Wedgwood blue. 2007 p71 black&white pavement pounder 121xxx all stock. totaled RIP.
2008 p71 99.000 C.C.package 3.27 traction lock vibrant white.
#2676826 - 03/02/13 05:53 PM Re: bad oil pump, show no oil on dipstick?? [Re: Twisted2k]
Twisted2k Offline
Loc: MN
I know that, thing is...I had just check it 2 days before was half a qrt low...so I added the half qrt. it ran great for the 15 mins I drove it today, then literally as I was pulling into my parking spot it did this...no lights no sound getting louder, just crapped out...Ive seen engines go before, and normally it gets worse not just suddenly. : /
#2676828 - 03/02/13 05:56 PM Re: bad oil pump, show no oil on dipstick?? [Re: Twisted2k]
toxic29 Offline
Loc: California
Is this really true and will this work on my 2007 p71 ???
#2676850 - 03/02/13 06:45 PM Re: bad oil pump, show no oil on dipstick?? [Re: Twisted2k]
Twisted2k Offline
Loc: MN
worked on my 2000...
#2676879 - 03/02/13 07:35 PM Re: bad oil pump, show no oil on dipstick?? [Re: Twisted2k]
For the OP oil pressure has long since built to max from running it... All cranking does is build pressure without actually running the engine...
The noise is 99% a rocker clattering, most likely due to a collapsed lash adjuster... Hopefully it doesn't score the camshaft...
Throw a quart of Marvel Mystery Oil in it and let it idle for 10-15 min to see if it will free up...
Now with P/S & PDB
#2676910 - 03/02/13 08:22 PM Re: bad oil pump, show no oil on dipstick?? [Re: Twisted2k]
Dan04Merc Offline
Loc: CT
How much oil did you have to add to get it to the proper level?
2004 Grand Marquis
2011 Crown Victoria (Rear ended in a parking lot, total loss)
2007 Grand Marquis
#2676934 - 03/02/13 08:58 PM Re: bad oil pump, show no oil on dipstick?? [Re: Twisted2k]
Twisted2k Offline
Loc: MN
Ill give the mystery oil a shot, not much to lose but 6$....
I had to put in about 3.5 qrts!! IDK, its throwing a CEL NOW....finally, so ima pull the code tomm and go from there. I am going out of town for work for 3-4 weeks on Monday so I wont be able to do any kind of a tear down till I get back. Just sucks it just happened outa nowhere, no warning signs, sounds nothing...
2 registered (Old_Guy_Stu, D_nor), 77 Guests and 30 Spiders online.
