#2692969 - 04/07/13 04:55 AM How to change your power steering fluid (flush)
Greengo Offline
Loc: Behind You, USA
Turkey basters don't cut it for me. I was inspired by the trans fluid cooler line flush/change for this. So we'll do this via the PS small hose cooler to reservoir.
Your system looks something like this:
You'll end up doing it look like this:
What you'll need:
8mm socket
2-3 qts of Mercon, Mercon V or a ATF that meets requirements for either (typically much, much cheaper!)
12-18 inches of 3/8 black hose
container to catch fluid (2 empty oil qts)
Power steering fluid change! Unmount the reservoir (8mm socket), lower it so the hoses are facing up (to prevent a spill), disconnect the smaller hose (#9 in the diagram above) where it connects to the cooler, disconnect the larger hose (#4) where it connects to the reservoir. Carefully lift it out and drain. Reconnect larger house, attach extra 3/8 hose to cooler and put other end into empty oil quart. Fill reservoir with Mercon fluid and have assistant start car and quickly turn the steering wheel lock to lock while you quickly pour a qt of Merc V in the reservoir. Yell at them to turn car off. Remove full drain qt. Mmm! Frothy. The whole thing literally takes seconds. Do it again. Disconnect drain hose, reconnect smaller reservoir hose to cooler. Top off with 3rd qt. Turn wheel lock to lock 20 times. Double check fluid is on max line. Forget about it for another 100k.
Post notes: I used some orange hand cleaner on a rag to wipe the reservoir clean. Worked really well.
Some of my hoses were leaking. I replaced #9 (the smaller) and didn't push the bigger one all the way on before clamping it. I think the hose had gotten lazy so hopefully it's in a tighter position now if that makes any sense.
Thanks Oscar for the diagram. Thanks Billy or Jacob for the idea inspired by the tranny cooler line bucket flush.
Tags: Power steering, flush, change, ps change, ps flush,
Edited by Greengo (04/07/13 05:01 AM)
Edit Reason: cant get png image to appear
2005 Cleveland Heights P71 Awesome interior light. LCM external relay. U-Haul Pan. Headlight harness upgrade. J-Mod! Say What!?!
#2693188 - 04/07/13 07:39 PM Re: How to change your power steering fluid (flush) [Re: Greengo]
matlobi Offline
Loc: Twin Cities, MN
Good tips.
I'm going to be doing this soon.
2004 MGM Ultimate - Bone stock, for now.
#2693264 - 04/07/13 10:10 PM Re: How to change your power steering fluid (flush) [Re: Greengo]
Loafy Offline
Loc: Okanagan, British Columbia
I am doing this tomorrow!
Quick question.
Jacking up the front of the car to make the turning easier. I know running a car with a damn near empty Power Steering system is HARD on the pump.
BTW Old power steering fluid stinks like ass. but not as bad as old diff fluid.
#2693305 - 04/07/13 11:27 PM Re: How to change your power steering fluid (flush) [Re: Greengo]
This is the exact method I've always used on my Panthers. I know I've written it up somewhere on here, but you did a much better job. laugh Thanks, hopefully now more people will actually maintain their PS system.
Only bit I have to add is that you can pull the fuse for the fuel pump or pop the fuel shut-off in the trunk. This will keep the engine from starting so you are turning it over slower and with the starter and you can stop it very quickly when the fluid gets low. You'll still need 2 people obviously. I found letting the engine start results in the fluid being pumped too quickly for my liking since I didn't want to let it run totally dry.
1998 Mercury Grand Marquis LS HPP ~92k miles, not entirely stock.
1997 Town Car Cartier ~143k miles, 70mm TB, Ported Plenum, Gutted Airbox, Mechanical Fan Delete, Contour E-fan Retrofit, Dual exhaust with Magnaflows, rear cat delete, MSD Ignition, KYB Gas-A-Justs, Marauder/HPP rear sway bar, P71 front bar, air ride reinstated, Blinker Mod, Projector retrofit, Caddy 4-note horn retrofit, Wood rim steering wheel retrofit, natural weight reduction.. Smashed 1/13/13....I fixt it..
#2693424 - 04/08/13 12:37 PM Re: How to change your power steering fluid (flush) [Re: Greengo]
2008MGM Offline
Loc: Richmond, VA
Is this comparable to what the dealer does for a PS flush? This seems more like a drain/refill. Does the machine used at the dealer apply more force to actually "flush" the old gunk out?
2008 Mercury Grand Marquis LS - 117,XXX miles - Dual exhaust system, Jensen double-din stereo unit with Bluetooth, GPS and now an Infinity Basslink subwoofer/amplifier
#2693458 - 04/08/13 02:07 PM Re: How to change your power steering fluid (flush) [Re: 2008MGM]
LTDteether Offline
A power steering flush is not a Ford-mandated service procedure. In the above procedure, the fluid is making a full circuit of the PS system so this is a flush, not a drain and fill.
Ford does mandate a purge procedure for after work is done on the PS system. It involves pulling the ignition coil fuse, attaching a hand-held vacuum pump to he reservoir and pumping it down before cranking the engine for 10 seconds at a time while turning the wheels to the stops.
'99 GM GS HPP.
#2693475 - 04/08/13 03:18 PM Re: How to change your power steering fluid (flush) [Re: Loafy]
Greengo Offline
Loafy- I had the car jacked up because I was changing the oil and it made much easier to have my assistant turn the steering wheel.
BigMerc96- Thanks for the tip about removing the fuel pump relay to only crank it out slower. I was surprised how fast the fluid gets sucked out of the reservoir, I mean as soon as the car starts you need to go to a full pour of the bottle!
I wish I could edit my post but I'm out of time for edit. Can I contact a mod to change it? I'd like it for the BOK.
Edited by Greengo (04/08/13 03:20 PM)
#2822635 - 03/28/14 01:19 PM Re: How to change your power steering fluid (flush) [Re: Greengo]
clutterking Offline
Loc: New Jersey
This is exactly what I was looking for, thanks Greengo. The turkey baster method was hardly getting any fluid out and I couldn't figure out which of the lines were the return.
#2822879 - 03/29/14 02:00 PM Re: How to change your power steering fluid (flush) [Re: Greengo]
I'll stick with the turkey baster, though I use a 60 ml syringe and some 1/8" line
I took off the return line for my old 93 P-71 and cranked it over with the coil packs unplugged. The fluid shot out like a Tsunami, even going into a gallon pail shot EVERYWHERE!!!1!!
#2883131 - 01/31/15 03:05 AM Re: How to change your power steering fluid (flush) [Re: Chevyguy]
Run4orest Offline
Loc: NC
Great post, Thanks!!
But,,, Dang,,,, now,,,,,, I'm Thinking......
I,,, still got a cabin full of baking soda from my last Tranny fluid Tsunami that hit my cowl and air plenum last year..
(at least it was fresh 1yr old Tranny fluid)
Planned on changing mine out this weekend (weather permit) and wanted a good full flush method.
Should be a sticky,,,,,,, with Chevyguy's warning..
With that in mind,,,,, I am going with at least 8' "feet" worth of 3/8th drain hose on "this" and my Tranny flush going forward...
Thanks Again!
05 P71 Daily Driver - 140K - LCM Relay Up-grade - Ford PI Racing Manifold - Serpentine Tensioner - PCV - Fuel Filter - All fluids - MP3 - Depo Lenses - Nip Tuck Bumper - Antenna Plugs - 17" OEM Wheels - SAP Conversion - Viper - Fire Extinguisher - Flashlight - Aftermarket Lug Nut Wrench
#2883137 - 01/31/15 08:51 AM Re: How to change your power steering fluid (flush) [Re: 2008MGM]
The pressure of the pump running likely exerts far more pressure than the so called flush machines... In my opinion these trans & P/S flushes are just something to pick your wallet... I've used the OP's method for the last 30 years or more, never had a issue...
On a transmission I rarely pull the pan, just run the line into a bucket and dump fluid into filler till it changes color.. Reconnect line, top off, done... At 177K mi I used this exact procedure on my F-150 that likely still had factory fill(fluid was dark as used motor oil and so rancid it stunk up my shop)... The new fluid is still so clean can barely see it on the stick...
1998 Grand Marquis LS. 77K mi.
2007 Grand Marquis GS. 78K mi.
#2883138 - 01/31/15 09:09 AM Re: How to change your power steering fluid (flush) [Re: Greengo]
dzp Offline
Loc: Kentucky
So I did this last year but I didn't use this method I have a 96 and went with what this guy done. https://www.youtube.com/watch?v=T5AMLRDvEIY
He left the car off and said the gearbox would have enough pressure to push the fluid out as you were turning the wheels back and forth. Did this give me a full PS flush doing it this way or did I do it wrong?
1996 Mercury Grand Marquis LS 55,XXX miles
Purchased 07/2011 with 39,000 original miles
5% Sides / Back Windows
35% Windshield with 5% strip
Viper Remote starter & Keyless Entry
1 registered (merk44z), 230 Guests and 15 Spiders online.
a_d_a_m 167
dpk 155
BigMerc96 128
Moby_Vic 114
WSTRLNG 85
reminc70 78
Ponyguy 75
RF_Overlord 65
Bellwestern80 58
SocalSam 48
Osu
Osu
