#2692836 - 04/06/13 08:55 PM What is this, and what is it for?
F1erceK Offline
Loc: Maine
Part 9F763 on this diagram:
http://www.fordparts.com/Commerce/RenderIllustration.ashx?id=233162474&f=3&n=E5TZ9601B
I want to do the MZT mod with 04 CVPI zip tube. THe ziptube does not have a port on it to connect to this part, so unsure what it does, and what effects I will have by/when removing it.
Edited by xTu (04/06/13 08:55 PM)
2003 Mercury Marauder
Addco Sway Bars / Heinous Rear Control Arms / Metco Watts Link / Metco DSS / Cobra swapped motor with a teksid / Full Stainless Works Dual Exhaust / Mustang Shelby GT500 Wheels / Drilled Slotted Rotors & Ceramic Pads / 3.73 Trac-Loc; Carbon Fiber Clutches, Ford Racing Girdle / Tune by Mo's
#2692842 - 04/06/13 09:03 PM Re: What is this, and what is it for? [Re: F1erceK]
BlaineB Offline
The page you provided isn't loading for me, but most likely it was an intake silencer if you were putting it on your Town Car.
Is it a large plastic hollow thing by chance?
#2692914 - 04/07/13 12:26 AM Re: What is this, and what is it for? [Re: F1erceK]
F1erceK Offline
Loc: Maine
Blaine,
Yes, nothing connects to it. Seems silly... So if I remove it, the intake is louder? O_o?
#2692930 - 04/07/13 01:23 AM Re: What is this, and what is it for? [Re: F1erceK]
BlaineB Offline
A picture would help just to verify.
I think your intake might "hiss" slightly at full throttle. Or you can hear the "air" being sucked in just a tad more. I've never had a silencer in a car I was driving, and I removed the silencer in my Father's Honda. It isn't necessary.
But you have the two ports plugged into the rear of the 04 tube near the throttle body, right? The hard plastic tube that runs to the idle air controller, and the other flexible rubber tube that runs to the driver's side valve cover, correct? If so then I'm 99% certain that other device IS in fact the silencer I described.
#2693002 - 04/07/13 10:26 AM Re: What is this, and what is it for? [Re: F1erceK]
It appears to be the resonator, there are 2 hanging off most newer civilian Panthers and they are just to quiet down the intake noise.
CVPI's do not have resonators.
Originally Posted By Gale Banks
Have you ever test drove a Crown Vic? It’s like driving your grandmother’s living room and it handles about as well.
#2693336 - 04/08/13 02:34 AM Re: What is this, and what is it for? [Re: F1erceK]
hellraiser319 Offline
Loc: Moline, IL
It basically gets rid of that throaty intake sound by making a vacuum cushion of air inside that chamber.
Chris H.
03 CVPI & 96 Aspire, see fquick link for info
MECP Advanced - CEA170106 - Best Buy #0023 - Moline, IL
XBL, PSN, FB, FQuick, TCG = hellraiser319
4 registered (Tenevic_P71, 3 invisible), 83 Guests and 89 Spiders online.
a_d_a_m 217
BigMerc96 145
EZlivin11 105
Chaplian 103
RF_Overlord 99
Moby_Vic 98
dpk 93
charlieD 90
Ponyguy 86
White99MGM 83
