Page 2 of 3 < 1 2 3 >
#2693225 - 04/07/13 09:13 PM Re: Gear oil change [Re: coolguy147]
stalag Offline
Loc: Columbus, OH
As long as it says on the tube of RTV that you used.
#2693250 - 04/07/13 09:48 PM Re: Gear oil change [Re: coolguy147]
theperfectdrugsk Offline
Loc: Maine
Yeah...depends on if you used the black, the red, the grey...or the quickset.
If you threw away the tube already...then just wait an hour or so.
2007 CVPI, headlight relay upgrade. 120k and counting.
#2693260 - 04/07/13 10:02 PM Re: Gear oil change [Re: coolguy147]
coolguy147 Offline
Loc: Florida
1 hr dry. 24 hr cure. I ended up just putting it in. I think I waited 45 minutes. It was dark, and I needed to finish up the job. I'll check in the morning for any leaks. Blew out the vent on the rear axle too.
Man...I'm sore lol.
1998 Mercury Grand Marquis LS
-JMOD
12X,XXX
2006 Pontiac GTO 6sp 6.0l
6X,XXX
#2693271 - 04/07/13 10:22 PM Re: Gear oil change [Re: coolguy147]
Loafy Offline
Loc: Okanagan, British Columbia
Continuous Bead. RTV 1/8 inch thick
I've heard of jacks kicking out in the same situation.
If I was doing that at work I'm sure somebody would be fired.
#2693275 - 04/07/13 10:25 PM Re: Gear oil change [Re: coolguy147]
Loafy Offline
I never waited on my car... but then now if I really think about it. I never put RTV. I'm pretty sure I cleaned it up real well, and just tightened the bolts in a criss-cross pattern for a nice seal. No leaks.
#2693280 - 04/07/13 10:30 PM Re: Gear oil change [Re: coolguy147]
Loafy Offline
For my Valve covers I let the RTV sit for 15 mins before I completely torqued er down. Build a skin g'know!
#2693355 - 04/08/13 06:31 AM Re: Gear oil change [Re: coolguy147]
coolguy147 Offline
Loc: Florida
Well, the manual says it must be applied within 15 minutes. I'm sure there was a little wait time on it because it took some time to put the stuff all the way around. I'm think, I'm ok?
-JMOD
12X,XXX
6X,XXX
#2693537 - 04/08/13 05:47 PM Re: Gear oil change [Re: coolguy147]
Loc: Maine
The wait time is the time you should wait before exposing it to gear oil (or water or whatever it is the gasket is sealing against). Pretty sure you don't need to wait to put the diff cover on the diff.
1. RTV on diff cover
2. diff cover to diff
3. wait 1 hour
4. add gear oil
#2693565 - 04/08/13 06:55 PM Re: Gear oil change [Re: theperfectdrugsk]
coolguy147 Offline
Loc: Florida
3. wait 1 hour
4. add gear oil
It clearly says, "NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied."
Doesn't talk about a wait time for the RTV to be installed. The next step is to add the lubricant after the housing cover is torqued down. I think I'm fine since I wait roughly 40-45 minutes before I added everything. Plus, I live in Florida.
-JMOD
12X,XXX
6X,XXX
#2693660 - 04/08/13 09:57 PM Re: Gear oil change [Re: coolguy147]
Loc: Maine
Exactly. RTV stands for Room Temperature Vulcanizing silicone. RTV and silicone rubber are the same thing, I've just heard it's best to let the RTV/silicone rubber cure a bit (meaning after assembling the axle and cover) before adding the gear oil.
That said, I was in a hurry and only waited about 30 minutes before adding the oil, and I haven't had any leaks or anything, so you're probably fine.
#2693703 - 04/08/13 10:32 PM Re: Gear oil change [Re: theperfectdrugsk]
coolguy147 Offline
Loc: Florida
Yea, did the same thing. It was 10pm and I needed to go somewhere lol. Thanks for your help!!!
-JMOD
12X,XXX
6X,XXX
#2693707 - 04/08/13 10:34 PM Re: Gear oil change [Re: coolguy147]
coolguy147 Offline
Loc: Florida
While changing my gear oil I decided to inspect the differential. I get a slight clunk when I go from reverse to drive or drive to reverse. Ujoints? No play in the driveshaft but I did notice play in the spider gears. How much play is allowed in the spider gears? With the whole rear end jacked up, I can rotate one tire and feel the play when I rotate it the opposite way. I can kinda see the play in the spider gears themselves.
-JMOD
12X,XXX
6X,XXX
#2693756 - 04/08/13 11:52 PM Re: Gear oil change [Re: coolguy147]
Loc: Maine
I think the clunk is normal...i guess it depends on how much youre talking about. I've only ever had vehicles that aren't limited slip...might be different with LS? As long as there aren't chunks of metal in the gear oil, I'd say you don't have much to worry about.
#2693820 - 04/09/13 06:46 AM Re: Gear oil change [Re: coolguy147]
Black_Sunshine Offline
I don't think that the RTV curing is as important with the rear because it's not under pressure like the cooling system or the crankcase.
75mm DBW TB
� hood ornament
� c-pillar emblems
� LS style body side moldings
CarDomain
Facebook
#2693860 - 04/09/13 10:07 AM Re: Gear oil change [Re: coolguy147]
Loc: Maine
Yeah...I accidentally bought the red RTV instead of the black...so I was a little worried that the gear oil would prevent it from drying properly, since it wasn't the "maximum oil resistance." Haven't had any problems though.
As an aside, apparently permatex now makes an RTV tube specifically for gear oil and differentials.
NM117 335
Moby_Vic 147
BigMerc96 121
Ezbok58a 116
Chaplian 116
RF_Overlord 115
EZlivin11 115
a_d_a_m 96
mdnos 96
Ponyguy 93
