#2689876 - 03/31/13 04:00 PM Overhead console display fix:
martz0r Offline
Loc: Punta Gorda, FL
The compass display hasn't worked on my car since I bought it. I figured it wasn't a fuse because the lights on the console were operable.
I first did a CVN search but didn't come up with anything. Searched Google, and found this write up on fordforums and had an idea of where to look.
Constant heat from the roof of the car and time cause these chips on the motherboard to de-solder themselves and either become loose or completely fall off.
I took a few pics regarding disasembly and gaining access to the motherboard to repair it. This is on the long overhead console in my LX Sport. I lowered the sunglasses holder and removed the two screws holding the console to the bracket. There was also a screw in the front, by the rear view mirror.
Carefully and slowly use your hands to pry and unclip the console from the bracket. There are two in the rear, and 4 towards the front. Once you have it unclipped, just disconnect the power harness and you can remove the console from the car. DO NOT turn the console over, in case one of your chips has completely disconnected like mine and is sitting in the console somewhere.
Once out, this is what you'll find:
Remove the two torx screws (circled). I don't know the exact size, because I didn't have it and had to use a small allen wrench which worked just fine. Also unclip the two buttons (circled) by bending open the side tabs and sliding up and out.
Once you get those 4 points disconnected, the whole unit will lift out like this:
Pry in those two tabs (there are two on the opposite side as well) and disconnect the casing to reveal this:
In the middle you see the motherboard. I found one chip completely missing (and by a stroke of luck I found it inside my console case) and one with a loose side.
I tore off the one that was hanging on by a thread, and re-soldered them back on.
I'm not going to show you my solder job, because it is quite crude... But it works. I have a compass now, and hopefully this will help someone out in the future on how to potentially fix their overhead console.
'07 Durango HEMI Limited 4x4
#2689882 - 03/31/13 04:25 PM Re: Overhead console display fix: [Re: martz0r]
AACoPD05 Offline
Great write up! BOK anyone?
#2689890 - 03/31/13 04:41 PM Re: Overhead console display fix: [Re: martz0r]
95_Grand Offline
I know I saw a how to on this about a year back also, oh well I second the BOK!
- Juan
-2000 Crown Vic, Bullett Wheels
-RIP-White 1995 Grand Marquis, 16xxxx -Muffler delete with straight pipe in place -Custom gauges by Scott -KYB shocks -Nightshaded tail lights -Blacked out rear fascia -All auxiliary lights LEDs -3 broken window motors XP -Gentex Rear View Mirror -6w LED CHMSL mod -101mm intake snout made with duct hose -Gatorback Belt -180 T-Stat -P&P TB -Gods Head badge in rear -Good Ole' K&N Air Filter -2005 Mustang Wheels with 1.5" F and 2" R Spacers -Cady 4 Tone Horn -Mercury Sable Console w/ Cut Seats -Taurus SHO Spoiler (Pending Application)
-Sold- '03 black n white CVPI
#2689937 - 03/31/13 06:34 PM Re: Overhead console display fix: [Re: martz0r]
puppy Offline
Loc: Washington
While mine is still working, I agree on BOK. This can information can come in handy.
#2689952 - 03/31/13 07:05 PM Re: Overhead console display fix: [Re: martz0r]
martz0r Offline
Upon further inspection, the buttons with the white connectors that are pictured do not need to be disconnected. I wasn't planning on taking pictures when I started this so the pics are actually from the re-assembly. I didn't realize the buttons can stay connected to white piece since you only need to take the motherboard out until I was just looking over the pics.
#2690159 - 04/01/13 09:09 AM Re: Overhead console display fix: [Re: martz0r]
Drac Offline
Cpt. Smug
Loc: Cali
I had this issue with mine... However both of the resistors were long gone. I just made a bridge of solder across the contacts on both sides and it has seemed to work this far. No problems to report.
#2690224 - 04/01/13 12:30 PM Re: Overhead console display fix: [Re: martz0r]
ZombieLinux Offline
Loc: Hillsborough County, FL
It would be good to get a good shot of those resistors. In case others need to be sourced in cases like Drac's. While it may work, its not ideal.
1996 Town Car /w 3.55 gears with Ford Racing Locker. 70mm ported & half shafted throttle body. Ported Plenum. JMOD. ADDCO Front & Rear sway bars. KYB Gas-A-Just Police Shocks /w Poly Bushings. Aluminum Thunderbird Driveshaft. BOC Tune & MZT. Lincoln LS rims with 225/60-R16s, 2006 Black Grand Marquis Seats. 03+ Defrost Duct.
Wanted parts: Tork Tech Kit, Supercharger, Manual Swap Bits.
Coming Soon: Manual Transmission (T-3650), New rear control arms, and interior/audio work.
#2698226 - 04/19/13 02:50 PM Re: Overhead console display fix: [Re: martz0r]
Wags4000 Offline
Loc: Northumberland, PA
excellent write up.
not trying to hijack the thread, but you seem to know the workings of the long OHC... nothing works in mine (03 CVLX) since the car is black I'm assuming the same chips have melted off and need re-soldering in order to work, but the lights don't work either. my floor lights in the front come on when the doors are opened or when the rotary switch is turned, but not the overhead lights....except occasionally they will come on and work if my kid slams the back passenger door when getting in. I don't think its the LCM since the floor lights work and I don't think its a door ajar switch since they all activate the front floor lights. faulty ground somewhere overhead maybe?
2003 CVLX; 312k mi (perch 103k); P74; Black Paint/Black leather; Blinking side marker mod; 2.73 open dif; Autolite Dbl Plat; General Altimax RT43; LCM Ext relay, FRPP mani; Max-Life 5w-30
03 Crown Victoria LX by Wags4000, on Flickr
2001 Merc GM LS; RIP at 340k mi (bought at 67k)-my former commuter. Finally passed on due to no one driving it and things just stopped working.
1986 Merc GM LS; 165k mi (bought at 118k)- Red with White vinyl half roof; 5.0L; RIP
87 Caprice Wagon; 356k; 5.0L(307cu) RIP
#2698276 - 04/19/13 04:36 PM Re: Overhead console display fix: [Re: martz0r]
AACoPD05 Offline
Have you pulled it down to make sure the previous owner didnt unplug it? Usually if the compass fails the lights still work.
#2698377 - 04/19/13 08:56 PM Re: Overhead console display fix: [Re: AACoPD05]
Wags4000 Offline
The lights acually work occationally when the back pass door is slamed but it doesnt last
Anyone know which pillar the wireing harness goes up?
#2699085 - 04/21/13 01:23 PM Re: Overhead console display fix: [Re: Wags4000]
Wags4000 Offline
bump
tearing it apart right now, looking for a loose connection
cant seem to find where the wires run to the roof frown
#2699149 - 04/21/13 04:52 PM Re: Overhead console display fix: [Re: martz0r]
martz0r Offline
Sorry, I didn't get that in-depth with it. Remove your visors, and the screws near the coat hooks (or pull handles) in the rear, and the two near the rear window. Loosen whatever interior trim necessary to lower the headliner and you should be able to see.
Or, remove the driver's side a-pillar cover and there's a good possibility it's running down that.
#2700772 - 04/25/13 11:31 AM Re: Overhead console display fix: [Re: Wags4000]
Bull Offline
Contract Cleaner
Loc: Dayton Ohio
bump
The wiring runs down the right "C" pillar
"Chaos, panic and disorder... my work here is done."
#2700775 - 04/25/13 11:42 AM Re: Overhead console display fix: [Re: Bull]
Wags4000 Offline
Thanks Bull,
I didn't pull the C pillar to look, but that would definitely fit with the symptoms that the back right door being slammed 'jars' something for a minute or two and it works. I wonder if there is a chaffed wire in there somewhere.
#2700924 - 04/25/13 07:29 PM Re: Overhead console display fix: [Re: Wags4000]
fastblackmerc Offline
Loc: The Triangle
Thanks Bull,
I can fix the compass for you.
180 Stat,TR6 Plugs,GMS plug connectors,FRP 4.10 Gears,JLT CAI kit w/SS heat shield,XCal-2 w/tune,Mustang shorty SS/JetHot coated headers,Custom mandrel-bent SS exhaust,Polished SS Magnaflow mufflers,ADDCO frt & rear sway bars,Clear bra,Trans cooler,Metco rear upper & lower control arms,Metco Watts link,Metco driveshaft hoop,Pioneer AVIC-X940BT,V1 with remote,WeatherTech vent visors,6000K Dual beam HIDs,39% tint,Rear door courtesy lights,All bulbs replaced with LEDs,Trunk mounted fire extinguisher,ROSS ,Valet lighting,Int. door handle lighting (green LED),Red powdercoated valve covers,Ford Racing coil covers,Gorilla wheel locks,Mustang dead pedal,Gas tank bib,Trunk bib,Remote start/alarm,Lincoln trunk organizer,Lower grill mod,"Real" oil and volt gauges,6000k HID foglights,Marauder fender badges,Red S-55 badge,Billet "Marauder" pedal covers,door sill plates,gearshift surround,heel plates,SS inserts,S55 mod, LED reverse lights & tail lights,DeckLid Designs trunk lid liner
