#2751167 - 08/28/13 10:40 PM Transmission whine 05 P71
BigBeaver Offline
Loc: Ohio
I am new to the Forum, and am new to Forums all together. I found crownvic.net whilst researching for the car I ended up buying at a state auction. I purchased an 05 P71 with 130,000 miles on it. I have done a preliminary search of the forums and haven't found the issue I think I am having. Any help, insight, or direction would of course be appreciated.
During acceleration or while driving the vehicle I get a whining noise (only when traveling, no noise when idling or revving the engine in park), that sounds like it is coming from the mid to back of the vehicle. At any speed if I let off the throttle the noise dies off instantly. I can only hear it with the windows of the car rolled up. I have no other indications that anything is amiss.
Thanks in advance
I don't suffer fools... I encourage them... admittedly, it's cheap entertainment.
#2751185 - 08/28/13 11:05 PM Re: Transmission whine 05 P71 [Re: BigBeaver]
bigROC209 Offline
Loc: Stockton, CA
It could be something in the rear end going out. Maybe the gears? Does it have a Trac Lok?
2002 Marquis LS Precision Trac, new engine @ 125K, GT Wheels, HP tires, SCT Xcal 2, 91 Octane tune from BOC, Traction Locker w/Ford Racing clutches, 3.55's, Police D/S, Ford Racing IM @114K, 75mm TB, Trick Flow Plenum, Ziptube, GT MAF, P71 Rear Coils, Summit Racing UDP's, HPP Sway Bar, Gas KYB's, J-Mod, 2-1/4" Dual Exhaust, Thrush Glasspacks & 18" tips, MSD COPs, NGK TR55's & Grey Injectors, Pinstripe removed, Disc changer, 2400 watt Pioneeer amp & 6x9's, Kicker Comp VR 10" DVC subwoofers.
#2751396 - 08/29/13 03:52 PM Re: Transmission whine 05 P71 [Re: BigBeaver]
These cars do definitely have louder than average torque converters, combine that with the lack of sound deadening in a P71 and its pretty noticeable. That could just be the noise you are hearing, but this kind of thing is hard to "diagnose" over the internet without hearing it.
1998 Mercury Grand Marquis LS HPP ~92k miles, not entirely stock.
1997 Town Car Cartier ~143k miles, 70mm TB, Ported Plenum, Gutted Airbox, Mechanical Fan Delete, Contour E-fan Retrofit, Dual exhaust with Magnaflows, rear cat delete, MSD Ignition, KYB Gas-A-Justs, Marauder/HPP rear sway bar, P71 front bar, air ride reinstated, Blinker Mod, Projector retrofit, Caddy 4-note horn retrofit, Wood rim steering wheel retrofit, natural weight reduction.. Smashed 1/13/13....I fixt it..
#2751836 - 08/30/13 06:45 PM Re: Transmission whine 05 P71 [Re: BigBeaver]
BigBeaver Offline
Loc: Ohio
Thanks for the replies. I have driven it for a little over 600 miles in a week and the sound seems to be constant and non changing. I have noticed nothing out of the ordinary powertrain wise. As it was suggested I am beginning to think it is just nature of the beast.
On another note I am impressed to have gotten over 23mpg on the first full tank I drained.
A few personal touches along with some elbow grease and I think I can turn this diamond in the rough into a nice daily driver.
#2751842 - 08/30/13 06:54 PM Re: Transmission whine 05 P71 [Re: BigBeaver]
N4RC Offline
King of necro-threads
Loc: Madison, Wisconsin
Is it almost a whistling kind of whine? I was hearing a similar noise for a long time, and a few months later my transmission went out. Maybe no connection, but I don't know.
2005 CVPI. 298 Bajillion miles.
#2751876 - 08/30/13 08:09 PM Re: Transmission whine 05 P71 [Re: N4RC]
BigBeaver Offline
Loc: Ohio
frown I'm going to think positive for now
#2751893 - 08/30/13 08:46 PM Re: Transmission whine 05 P71 [Re: BigBeaver]
gettinsome Offline
Loc: 29palms ca
Save tech questions for the technical forums please. but welcome to the vicster scene man!
2009 Mercury Grand Marquis Ultimate 63000 miles- my new project!!
1999 Crown Vic p73 code 212000 miles and going!!-Its bye bye
2003 Mercury Grand Marquis (sold) 63000 miles. It was my baby...regret getting rid of it...
1996 Mercury Grand Marquis (Magic Carpet Ride) Sold to my uncle. 317000 miles and counting!
#2751942 - 08/30/13 11:18 PM Re: Transmission whine 05 P71 [Re: BigBeaver]
Wags4000 Offline
Loc: Northumberland, PA
before just assuming its normal i'd suggest two relatively cheep maintenance jobs that could help, first change the trans filter and fluid (at least whats in the pan) and pull the cover off the Diff and change that fluid. if you see alot of metal particles in either the trans or dif fluid then you'll have a good starting point for finding a possible problem. worth the price of fluids and gaskets IMO
2003 CVLX; 213k mi (perch 103k); P74; Black Paint/Black leather; Blinking side marker mod; 2.73 open dif; Autolite Dbl Plat; General Altimax RT43; LCM Ext relay, FRPP mani; Max-Life 5w-30
03 Crown Victoria LX by Wags4000, on Flickr
2001 Merc GM LS; 304k mi (bought at 67k)-my former commuter. Still has the all plastic coolant cross-over intake. runs good and should for a long time. Max-Life 5w-30
1986 Merc GM LS; 165k mi (bought at 118k)- Red with White vinyl half roof; 5.0L; RIP
87 Caprice Wagon; 356k; 5.0L(307cu) RIP
#2759106 - 09/18/13 08:22 PM Re: Transmission whine 05 P71 [Re: BigBeaver]
bjorkmae Offline
Loc: Chicago Area, IL
Mine does the same exact thing, take your foot off the throttle and it immediately goes away. I have 135k miles
Sold:
SUPERCHARGED 1998 CVPI with 2001 5.4 PI swap, V2 S-trim Vortech @ 8PSI, 2.5" duals with X-pipe & a lot of other goodies.
#2759259 - 09/19/13 11:52 AM Re: Transmission whine 05 P71 [Re: BigBeaver]
Mileaway Offline
Loc: Sacto. Calif.
affirm^^
I'm almost positive that it's normal especially if u have steep rear gears. a 3:55 for instance
and is louder in any case if u have overdrive off
and even cement freeways are going to emphasize the noise
being that the two sounds are almost identical
and the lack of heavy glass such is now in Buicks and these cars need more sound proofing anyway..especially at the rocker panel areas
but alas..their production is over..so
mehsmile
i suspect all is well with ur car
welcome
#2759344 - 09/19/13 06:15 PM Re: Transmission whine 05 P71 [Re: BigBeaver]
bjorkmae Offline
According to my door sticker and the tag on the axle its a 2.73 RAR. My 98 CVPI didn't make this noise that I can recall but it had a blower and bigger fuel pump so if it did it would have been hard to tell.
Sold:
#2759607 - 09/20/13 01:44 PM Re: Transmission whine 05 P71 [Re: BigBeaver]
Mileaway Offline
Loc: Sacto. Calif.
2.73 doesn't make any noise ..
so?
IDK
#2759887 - 09/21/13 05:36 AM Re: Transmission whine 05 P71 [Re: BigBeaver]
bluviclx98 Offline
Loc: Mississippi
Welcome from Mississippi! Isn't it strange for cvpi to have 2.73? I thought most came with 3.55. IDK
Its only my opinion and worthless cept to me!
1998 Crown Vic Lx. 103,000 miles, Dual Exhaust W/ H-Pipe, Magnaflow's and 2nd Cat Delete, FRPP PI Intake, P&P Plenum, Summit 70mm TB, MTZ, BOC 93 OCT Tune, 180 stat, 22c Plugs, ADTR High Flow intake tube, Autometer Z-Series Tach in Column Mount, 2" Hitch Receiver, Previous Owner Replaced Air Suspension with Coils. BH1976 Headlight Harness, Black P71 Honeycomb Grille. (On but not shown)
Moderator:  Chaplian, Liquid, Mpilot
4 registered (Lincoln_GTC, WWR_CVPI, BrianDye, hairy_paperclip), 266 Guests and 10 Spiders online.
a_d_a_m 164
dpk 153
BigMerc96 130
Moby_Vic 112
WSTRLNG 88
reminc70 79
Ponyguy 78
RF_Overlord 67
Bellwestern80 57
SocalSam 48
