#2758879 - 09/18/13 12:38 AM 2005 cvpi p0171, p0174 after 2006 pcm swap help!
nvidiaclockerp71 Offline
Loc: Sacramento, California
Hey you guys! I just recently did the 06 cluster swap on my 2005 cvpi(write up coming soon) After the PCM swap I got the p0174 and p0171 that I cant get rid of. Car runs like normal. Long term fuel trim is at around 25 on both banks. Can it be a calibration issue or incompatible sensors? I am planning on swapping the FPDM since its different. Any help is appreciated!
05 CVPI ex CHP K9 unit
Vented hood
2006 pcm/cluster swap
Stock
#2758957 - 09/18/13 11:24 AM Re: 2005 cvpi p0171, p0174 after 2006 pcm swap help! [Re: nvidiaclockerp71]
idontbelieveit Offline
Loc: Over there
Is there any other work you've done under the hood while you were swapping out PCM's? With both banks running lean and recent parts swaps, I'm thinking along the lines of a vacuum leak.
#2758997 - 09/18/13 02:13 PM Re: 2005 cvpi p0171, p0174 after 2006 pcm swap help! [Re: nvidiaclockerp71]
Leadfoot Offline
Loc: Montreal, Qc, Canada
as I am not familiar with the DBW cars, are the 05 and 06 mafs the same?
-Dave
2003 P74 Crown Victoria LX Spruce Green- TR3650 5speed swap, Marauder Cluster and gauge pod, Marauder spoiler, 04 cvpi, maf and zip tube, dual exhaust, 4.10 gears, metro rear control arms, SQ roll bar without partition, headlight relay upgrade, Pioneer Avic 930BT head unit + Axxess Metra ASWC-1 for steering wheel controls, 17" CVPI rims.
2004 Manual CVPI aka Guinevere - RIP
#2759037 - 09/18/13 04:35 PM Re: 2005 cvpi p0171, p0174 after 2006 pcm swap help! [Re: idontbelieveit]
Before I did the PCM swap no check engine light was on. As soon as I swapped it a few miles later it came on with lean codes. I don't hear any vacuum leaks anywhere. The engine idles and drives like normal.
Vented hood
Stock
#2759038 - 09/18/13 04:36 PM Re: 2005 cvpi p0171, p0174 after 2006 pcm swap help! [Re: Leadfoot]
I've checked the MAF part numbers and they're the same. I was thinking about the fuel injectors. It doesn't have the same part number.
Vented hood
Stock
#2759063 - 09/18/13 05:40 PM Re: 2005 cvpi p0171, p0174 after 2006 pcm swap help! [Re: nvidiaclockerp71]
Leadfoot Offline
if the 06 pcm is set to use 24lb injectors vs the 19lb 05 ones that could be why it is throwing codes
-Dave
#2759070 - 09/18/13 05:56 PM Re: 2005 cvpi p0171, p0174 after 2006 pcm swap help! [Re: nvidiaclockerp71]
The pictures they have on RockAuto for 2005 have a red or orange piece(19#) - 5W7Z9F593AA
and the ones they have for 2006 have a blue piece(24#) - 6W7Z9F593AA
They have different part numbers as well, just the first 2 numbers are different. If they were the same and the '06 part just superseded the '05 part number as an update they would have the '06 part number listed for '05's
#2759084 - 09/18/13 06:45 PM Re: 2005 cvpi p0171, p0174 after 2006 pcm swap help! [Re: nvidiaclockerp71]
olopezm Offline
Loc: Irapuato, Mexico
The first 4 characters can be used to determine the year 5 (05) and 6 (06). The next 5 are the actual part number and last 2 indicate either calibration or revision.
Having said that, injectors should be the same according to the above information. I'll still check the manual to confirm.
Oscar.
1997 Pontiac Grand Prix GT
2000 Ford Windstar SE
#2759089 - 09/18/13 06:54 PM Re: 2005 cvpi p0171, p0174 after 2006 pcm swap help! [Re: nvidiaclockerp71]
If injectors are different size the fuel pump would likely compensate at lower speeds but probably not be able to deliver enough volume(pressure) at higher throttle...
Now with P/S & PDB
#2759096 - 09/18/13 07:11 PM Re: 2005 cvpi p0171, p0174 after 2006 pcm swap help! [Re: nvidiaclockerp71]
GoldPanther Offline
BOK contributor
Loc: Chitcagoland!
Thats interesting!
As far as I know fuel pumps are the same from 2003 to 2011.
So I think the pump wont make any issues!
Former 03 mgm ultimate edition owner, currently pantherless.
#2759100 - 09/18/13 07:33 PM Re: 2005 cvpi p0171, p0174 after 2006 pcm swap help! [Re: GrandMarq9807]
Fuel rail pressure is around 45-40 psi. The lowest I've seen is around 39 psi so I think its not a pressure issue. There's something that's letting air in the intake.
Vented hood
Stock
#2759104 - 09/18/13 08:16 PM Re: 2005 cvpi p0171, p0174 after 2006 pcm swap help! [Re: nvidiaclockerp71]
Leadfoot Offline
I don't think that is the case, it's the difference between drinking through a small straw vs a large straw . . if the pcm is saying that max fuel is being needed, a small straw will never provide as much fuel as a larger one.
-Dave
#2759105 - 09/18/13 08:17 PM Re: 2005 cvpi p0171, p0174 after 2006 pcm swap help! [Re: nvidiaclockerp71]
Leadfoot Offline
50lbs of pressure on a 19lb injector is going to be considerably less fuel than the same amount of pressure on a 24lb injector
-Dave
#2759112 - 09/18/13 08:44 PM Re: 2005 cvpi p0171, p0174 after 2006 pcm swap help! [Re: Leadfoot]
DING, DING, DING!
We need someone to confirm whether they used 24# injectors in '06+
I asked stlvic if he had put in 24# injectors when I saw his car this summer because they have that blue piece on them which would indicate a 24# injector, he said they were stock.
I have the stock injectors from my '05 in the garage and a set of 24's so i can compare them tomorrow.
#2759187 - 09/19/13 01:57 AM Re: 2005 cvpi p0171, p0174 after 2006 pcm swap help! [Re: nvidiaclockerp71]
On the '03-up returnless fuel systems voltage is varied to the pump to maintain proper A/F ratio, pump doesn't run one constant speed as in the return type system.... Sooo if smaller injectors were used the control circuit would be calling for max voltage at WOT but system would be lean...
A leak in the intake system would have to be between the MAF and throttle body, any leak afterwards would cause excessive idle speed...
Now with P/S & PDB
