#2296009 - 05/13/11 06:17 PM P2197 help
Crazie311 Offline
Loc: FLORIDA
the car is running very bad,i get CE light and run my code reader getting p2197 so I thought I had an exhaust leak.i cant find one, any other ideas...its dropped my mpg considerably...any help is greatly appreciated.
2003 p71 vic,brown interior,plastic floor,155,xxx.
#2296060 - 05/13/11 08:30 PM Re: P2197 help [Re: Crazie311]
QuicksterP71 Offline
Loc: Ma.
did you seafoam your car it will show your any exhaust leaks
#2296069 - 05/13/11 08:57 PM Re: P2197 help [Re: Crazie311]
Crazie311 Offline
Loc: FLORIDA
i seafoamed it a while back.I mean could a tiny exhaust leak make my car run terrible..bog down not want to go?
#2296128 - 05/13/11 11:13 PM Re: P2197 help [Re: Crazie311]
Loc: Ma.
Oxygen sensor locked lean Bank 2
i would look for a vacume leak first you can use starter fluid spray it around vacume line and intake see if you can hear a diffrence in the way the car runs. It could also be your PCV valve. You could also try testing and cleaning your MAF. Or it could be either of your O2 sensors i would start with the heated O2 sensor check wiring.
Edited by QuicksterP71 (05/13/11 11:17 PM)
#2296146 - 05/13/11 11:28 PM Re: P2197 help [Re: Crazie311]
Loc: Ma.
Here is what I have found on this code.
P2197
Lack of HO2S-21 Switch, Sensor Indicates Lean
Detailed Description
A heated oxygen sensor (HO2S) indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
Possible causes :-
Electrical:
# Short to VPWR in the harness or HO2S.
# Water in the harness connector.
# Open/shorted HO2S circuit.
# Corrosion or poor mating terminals and wiring.
# Damaged HO2S.
# Damaged powertrain control module (PCM).
Fuel System:
# Excessive fuel pressure.
# Leaking/contaminated fuel injectors.
# Leaking fuel pressure regulator.
# Low fuel pressure or running out of fuel.
# Vapor recovery system.
Induction System:
# Air leaks after the mass air flow (MAF) sensor.
# Vacuum Leaks.
# PCV system.
# Improperly seated engine oil dipstick.
EGR System:
# Leaking gasket.
# Stuck EGR valve.
# Leaking diaphragm or EVR.
Base Engine:
# Oil overfill.
# Cam Timing.
# Cylinder compression.
# Exhaust leaks before or near the HO2S(s).
#2296225 - 05/14/11 04:18 AM Re: P2197 help [Re: Crazie311]
ferg Offline
Loc: SE Michigan
^^Those look like pretty good places to start! Can't think of anything to add.
What year, model, and mileage??
How long has it been running badly?
Did the light come on long before it started running badly and the mpg's dropped?
2006 P71 (DD since 2011), white, bumper tuck, 5% tint, code alarm/remote start, MGM cruise wheel, sunroof, carpet, center console, mustang offroad h-pipe dumped at the axle, marauder spoiler, 3" lift/31" mud tires, new 4.6, 188k and counting.
2021 Durango GT (family truckster)
2010 Corvette Grand Sport m6
1995 Corvette base m6
2002 Dale Earnhardt Monte SS
#2296709 - 05/15/11 12:24 AM Re: P2197 help [Re: Crazie311]
Crazie311 Offline
Loc: FLORIDA
03 light came on right after it started running badly..Maybe a week?two? not long.I will check some of the things listed above and see,what do you mean by heated o2 check wiring?
#2296847 - 05/15/11 09:18 AM Re: P2197 help [Re: Crazie311]
Loc: Ma.
heated o2 sensor is the second o2 sensor if i recall correctly
#2297943 - 05/16/11 11:57 PM Re: P2197 help [Re: Crazie311]
Crazie311 Offline
Loc: FLORIDA
but what could be wrong?bad wiring?should i just replace it?
#2298270 - 05/17/11 02:43 PM Re: P2197 help [Re: Crazie311]
Big_Bad_Joe Offline
Loc: Rochester NY
this thread is a waste without year, model, mileage, recent service history in the post
How do you expect people to help... not interested in reading two pages and having to ask for some basic information...
Underdrives from ADTR.net
Given to DG in Ohio
#2299140 - 05/18/11 11:50 PM Re: P2197 help [Re: Crazie311]
Crazie311 Offline
Loc: FLORIDA
its an 03 as stated above...its one page.......and its a crown vic...hence crownvic.net...its a p71 with 150,xxx.thank you for all the help.
#2762200 - 09/28/13 11:50 AM Re: P2197 help [Re: Crazie311]
jibjab90 Offline
Loc: South Shore, Ma
Anybody ever have any luck with this code? My 04 has 150k on it and it throws it when it's cold outside (the light comes on as soon as I start driving away). It did it last Winter but went away once it started getting warmer. Can't say I noticed a huge difference in performance but last night while driving it felt a bit unsure of itself. I've yet to check for vacuum leaks, but what might cause it to only come on when it's cold (50 degrees and below)?
2004 P71, 180,XXX
#2762322 - 09/28/13 09:34 PM Re: P2197 help [Re: QuicksterP71]
idontbelieveit Offline
Loc: Over there
They're all heated O2 sensors these days.
2 registered (RF_Overlord, speedfreak), 136 Guests and 18 Spiders online.
Traffic22 15
