#2782016 - 11/24/13 09:36 PM Problems with fuel pump and fuel rail P0191
pacecarman Offline
Hello,
I am having a electrical problem with my P71 2006 crown vic. The car was running fine when I got it but then all of the sudden while warming up in the drive way it stalled and died.
I got the error code P0191 - Fuel Rail Pressure Sensor Low.
So I replaced the sensor, but still no start. I heard the fuel pump priming but very weak. So I replaced the fuel pump assembly (actually 3 fuel pumps now) and also the fuel filter. Still no start.
I replaced the Driver Module Fuel located in the trunk of the car (with the same exact model #) and still no start.
I removed the fuel rail hose and saw there was no gas getting to the fuel rail so I hotwired the fuel pump and it started to work. So I got under the car and rewired the ground going to the fuel pump assembly and the fuel pump started to prime as usual.
Here are the current issues: The fuel pump is at a constant high pitch as if there is no control to the fuel pressure.
The code P0191 will always come back on the second start if I erase the code.
I have checked for frayed wires on the inertia cutoff switch, fuel pump assembly, driver module fuel, fuel rail pressure sensor and they all seem to be good and connected.
Could this be something else? Fuel regulator? some other connection? I don't know what controls the fuel pump pressure or what turns on the fuel pump other than the fuel pump relay which is also good. Also the fuel pump fuse.
Out of ideas now, need help
thanks
#2782018 - 11/24/13 09:43 PM Re: Problems with fuel pump and fuel rail P0191 [Re: pacecarman]
pacecarman Offline
Forgot to mention I looked all on this forum and internet looking for a similar issue related to the code P0191 and found nothing matching. One said the check all grounds, but wanted to know if a certain power supply would go out/ broken/ or faulty I should be looking for. All the parts I replaced were with perfectly running cars.
#2782534 - 11/26/13 11:16 AM Re: Problems with fuel pump and fuel rail P0191 [Re: pacecarman]
pacecarman Offline
Any ideas?
Why would just making a new ground for the fuel pump assembly cause the fuel pump to turn on, but never turn off when ignition turns to on? But you hook up the original ground wire and the car doesn't turn on the fuel pump at all with the ignition switch turned to on position
Bad inertia switch?
I've already crossed out fuel pump, fuel pump assembly, driver fuel module, FRPS, Fuel pump relay, fuel pump fuse, connections, frayed wires
6 registered (Sakoulas, mrti, DC_Dave, MIAMI-DADE, olschoolsteel, 1 invisible), 47 Guests and 118 Spiders online.
Moby_Vic 188
a_d_a_m 159
BigMerc96 139
Chaplian 109
White99MGM 108
EZlivin11 104
DudeAbides 96
charlieD 87
RF_Overlord 86
SocalSam 83
