Page 1 of 6 1 2 3 4 5 6 >
#2811624 - 02/21/14 12:55 AM updates for NTHE10s
Nthe10s Offline
Loc: FL
For the guys that don't know the car or build. please read the links below
10sec Turbo Build
10sec Turbo build part 2
For the rest of the guys. Thought i would post a few updates.
Turbo was set back for rebuild due to oil leaking from seals. when they tore the turbo down. some damage was found on the exhaust wheel(i think it happen back in 2011 when car was on 93octane and plug melted)so i had them replace the wheel along with installing a .96a/r housing. i've been thinking about getting for so time. below are a few pic
next:I sent the injectors, fuel reg, and pump out for a rebuild. injectors were a little dirty, fuel reg need rebuild, and pump was great.
while all that was going on. i built a jig, cut, and welded my new 17" wheels for the new M/T radials. wheels now are 17x7 front and 17x10 rear. just need to send them out for coating before the car is back together.
the best is always save for the last...
well i tore the motor down as you know. crank, rod, pistons, block and bores looked great(until i started cleaning and checking the parts)Crank is perfect, rods are perfect, block needs a freshen up, Pistons and wrist pins were all good but one. #3 where i had a issue with back in 2011. had a plug melt down.
bad pistion
it was time to upgrade a little more. hint..hint ->look at the label
old bore was 3.55 new is 3.70. It doesn't sound so different until you do this.
The new setup will be
76mm/.96a.r, 302ci, 10:1, E85, with a lot of boost... there maybe one more change but we will see.
Rich
Edited by Nthe10s (02/21/14 01:01 AM)
2V 4.6l, Single 76mm Turbo, slow
http://www.youtube.com/watch?v=3rBA2ShSUzY
#2811629 - 02/21/14 01:47 AM Re: updates for NTHE10s [Re: Nthe10s]
Bulldog5_oh Offline
NICE!!! Sucks about the piston....but definitely made way for an even better setup. Looking forward to seeing your progress and results.
#2811648 - 02/21/14 05:42 AM Re: updates for NTHE10s [Re: Nthe10s]
IMPRESSIVE as usual lol smile
#2811651 - 02/21/14 06:23 AM Re: updates for NTHE10s [Re: Nthe10s]
Mr. 427
Excellent work!
I'm diggin' the self-widened wheels.
1964 Ford Galaxie 500 R-Code
1972 Ford Galaxie 500
2008 Ford CVPI
#2811656 - 02/21/14 07:12 AM Re: updates for NTHE10s [Re: Nthe10s]
MEvans043 Offline
Loc: Upstate, New York
Is it just me or do I not see a sleeve in that cylinder? I thought Modulars didn't have enough material to bore out more than .020" without sleeving.
04 P71- 5 speed manual
Clicky >>TR3650 5 Speed Swap
#2811663 - 02/21/14 08:18 AM Re: updates for NTHE10s [Re: Nthe10s]
I love the wheels, of course the rest is awesome as well but the DIY wheels are great.
#2811664 - 02/21/14 08:29 AM Re: updates for NTHE10s [Re: Nthe10s]
Rainyp71 Offline
Loc: North Carolina, USA
Amazing looking. Can't wait to see even more progress!
2000 P71 Crown Vic former Gordonsville, VA Police Wrecked @ 200,199 Miles - All fixed! Currently 250,000 Miles
GMAX As-05 tires, 3.55 gears, Ford 28 spline limited slip w/ carbon clutches, upgraded trans cooler, Airlift 1000 bags, custom trunk false floor, autometer tach, Sony Double DIN Head Unit, KYBs all around, 26in Cherrybombs 2.25" dual exhuast.
#2811707 - 02/21/14 12:11 PM Re: updates for NTHE10s [Re: Nthe10s]
MERCURY2003LSE Offline
Loc: CANADA
Awesome . i cant wait for the project to be completed and new lower ET,s at the track banana
#2811715 - 02/21/14 12:35 PM Re: updates for NTHE10s [Re: Nthe10s]
Are you going for a new name this time?
#2811759 - 02/21/14 04:03 PM Re: updates for NTHE10s [Re: Nthe10s]
Alex07 Offline
Loc: United Kingdom
uhhhh... woah ff
1999 Honda Accord
2016 Triumph Tiger 800 XRT
1973 Ford F100
1973 Ford Torino
#2811785 - 02/21/14 05:24 PM Re: updates for NTHE10s [Re: MEvans043]
just look at the ford sticker wink
#2811788 - 02/21/14 05:53 PM Re: updates for NTHE10s [Re: Nthe10s]
MEvans043 Offline
Oh sweet. I totally missed that in the picture, I was focused on the pistons.
I foresee this becoming a 9 second Vic now. Holy cow.
#2811795 - 02/21/14 06:27 PM Re: updates for NTHE10s [Re: Nthe10s]
pantera77 Offline
Loc: Buffalo, NY
Impressive work as usual. Scratch that, amazing work.
2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
2005 Grand Marquis GS - Marauder swaybars, exhaust, wheels - Daily Driver/Winter Beater
2003 Marauder - Trilogy # 8, JLT, kooks, 2.5" exhaust, 4.10's/31 spline, widened rear's, metco's, addco's, ridetech's 415hp/381tq
2004 Marauder DTR - 46k 100% Bone Stock
1987 Colony Park - Money Pit
#2811822 - 02/21/14 07:40 PM Re: updates for NTHE10s [Re: Nthe10s]
Loc: Iwakuni, Japan.
3.70 bore, Here comes a 5.0 baby!
1990 Mazda Miata
2000 Toyota Crown Estate Athlete V
1994 Autozam (Mazda) AZ-1 (Kei Car legend)
#2811862 - 02/21/14 09:51 PM Re: updates for NTHE10s [Re: MEvans043]
Nthe10s Offline
Loc: FL
The iron blocks you can go .040" but i wouldn't do it because i daily drive this car.
The Boss 5.0 Block comes with a larger bore and has better webbing so no need for sleeving.
Rich
1 registered (White Falcon LS), 84 Guests and 27 Spiders online.
