Page 3 of 4 < 1 2 3 4 >
#2545200 - 06/20/12 12:39 AM Re: Front-end swap FAQ [Re: BigMerc96]
holy crap, haven't seen this thread in awhile. Yeah, whale Vic nose fits a GMQ. If its a '92-'02 you need the fenders from a Vic, Aeros would also require the hood and latch. Otherwise its just the header panel and lights & wiring.
Originally Posted By s33k3r
#2666584 - 02/09/13 01:40 AM Re: Front-end swap FAQ [Re: BigMerc96]
jwreed4130 Offline
Loc: Beverly, NJ, USA
I have a 01 Vic and want to use the 06 grand marquis front and rear bumper covers. I like the sharper lines and also they have fog lights as well.
I have read a ton of stuff but can't figure out what I actually would need to get to make it all work. For example, I know I would need both covers, fog lights and brackets.
I don't know if I would need the header, bumper support bars for both, lights, grille. I can't see the fenders being a problem but I am not sure about those either.
Everyone talks about changing 98-02 to a 2003 but not 01 CV to 06 GMQ stuff. Any help would be greatly appreciated.
#2666657 - 02/09/13 09:37 AM Re: Front-end swap FAQ [Re: BigMerc96]
You will need the rear trunk fascia from the GMQ as well, otherwise there will be a gap below the license plate. The rear bumper is a direct swap, no further modifications required.
For the front, yes you will also need to swap the header panel/grille/lights to properly line up with the bumper. Not sure if anyone has tried it or not, but I can guarantee you there will be some nasty gaps if it fits at all with the CV header panel.
The hood and fenders are the same, so you are good there.
As for the bumper supports/inner bumper, I don't know, again, I don't think anyone has tried, but I can't imagine that there is enough difference that you couldn't just trim the CV one to fit.
#2695356 - 04/12/13 09:35 AM Re: Front-end swap FAQ [Re: BigMerc96]
Ieatpeople Offline
Loc: MD
i have throughly read the original post, and am still left with a question.
i am trying to swap in marauder headlights/turnsignals on my 07 vic.
heres the list of parts i want to use, will these work together on an 07 vic?
2004 MGM/MM header panel
1999 MGM bumper cover
2004 MM headlights/turnsignals
Edited by Ieatpeople (04/12/13 11:01 AM)
07 CVPI, Black, dual spots
RE Audio SEX15D2 15" sub
Ground Shaker 4cf ported box
Rockford Fosgate R1000-1D
Polk Audio DB 5x7 & 6x9
Pioneer AVH-P4200DVD
NVX Audio Sound Damping Mat
No performance mods, just stock and slow
#2695387 - 04/12/13 10:44 AM Re: Front-end swap FAQ [Re: BigMerc96]
Marauders used the same front end as '03-'05 GMQ but with a different bumper cover. so you'd need '03-'05 GMQ header panel, grille, lights, and bumper. THe hood and fenders are the same as any '98+ crown vic so you're good there.
#2695394 - 04/12/13 11:02 AM Re: Front-end swap FAQ [Re: BigMerc96]
Ieatpeople Offline
Loc: MD
i bought a set of MM lights/turns off of ebay, then realized they wouldn't line up. im gonna order the header panel, grill, and bumper sometime soon.
#2695437 - 04/12/13 12:47 PM Re: Front-end swap FAQ [Re: BigMerc96]
BigNSlow Offline
Aussie powered
Loc:
1985 Grand Marquis
2002 Volvo V70
#2820483 - 03/21/14 03:31 PM Re: Front-end swap FAQ [Re: BigMerc96]
loudpakmike Offline
Loc: S.Carolina
What if I want to go from 97 MGM to 98 MGM
#2820485 - 03/21/14 03:37 PM Re: Front-end swap FAQ [Re: BigMerc96]
BlaineB Offline
Header panel, bumper cover, lights, and grille. Hood and fenders will be the same from your 97-98 Grand Marquis.
#2820521 - 03/21/14 06:02 PM Re: Front-end swap FAQ [Re: BlaineB]
hood is NOT the same. Fenders are.
#2820550 - 03/21/14 08:12 PM Re: Front-end swap FAQ [Re: BigMerc96]
BlaineB Offline
OOps. What about the CV?
#2820556 - 03/21/14 08:21 PM Re: Front-end swap FAQ [Re: BigMerc96]
124neta Offline
don't get riled, sugar!
Loc: Il
same problem.
Not sure if mentioned earlier in thread, but aero bumpers will require trimming to fit whale bumpercover.
Edit: I'm not sure about that last bit. I may have just encountered troubles because I was putting the aero bumper on whale frame. Bumper shock mounting holes different?
Edited by 124neta (03/21/14 08:26 PM)
#2820557 - 03/21/14 08:27 PM Re: Front-end swap FAQ [Re: BlaineB]
There are only really 3 hoods on '79-'11 CV/GMQ. '79-'91, '92-'97, and '98-'11. Crown Vic and Grand Marquis share the same hood.
#2820681 - 03/22/14 09:46 AM Re: Front-end swap FAQ [Re: BigMerc96]
BlaineB Offline
Right. I also believe they were aluminum for 92-97, or at least partially through that run. I believe the same goes for the trunk lids a well.
#2820788 - 03/22/14 04:53 PM Re: Front-end swap FAQ [Re: BlaineB]
correct, all '92-'97 OEM hoods were Aluminum. '92-'94 trunk lids were steel, '95-'97 are aluminum. I was actually sort of surprised my Town Car has a steel trunk. There is much less info on the various body panels for Town Cars.
6 registered (Sakoulas, mrti, DC_Dave, MIAMI-DADE, olschoolsteel, 1 invisible), 47 Guests and 118 Spiders online.
Moby_Vic 188
a_d_a_m 159
BigMerc96 139
Chaplian 109
White99MGM 108
EZlivin11 104
DudeAbides 96
charlieD 87
RF_Overlord 86
SocalSam 83
