#2828487 - 04/17/14 03:29 PM correct plugs for 07
unclecrown Offline
Loc: northern California
Hi Guys
I was in a big hurry to get spark plugs for the weekend, now they have arrived, I realized they are not the same numbers as what came out last time I changed them. “AGSF32N
SP-413.
I should have kept looking for AGSF32PM SP-493, they were in the motor last time I changed them.
Please can anyone tell me if they are hotter or colder or what the difference will be.
Always appreciate help I get here.
07 C/Vic P71
c/control,3.27 traction-lok,engine /Romeo trans 4R75E4/speed W/od,E/140 speedmeter fuel recommend 87oct
tilt wheel,adjustable pedals,aluminum drive shaft,silicone hoses, A/C,engine idle meter,pwr windows w/driver-side express down,rear window defroster,rear window mounted antenna,rear poweraccess point-inc pwr junction box,8-way power drivers seat,driver/passenger side airbags,full size spare,HD rubber floor covering and Duel ashtray mounted cupholders.
#2828503 - 04/17/14 04:27 PM Re: correct plugs for 07 [Re: unclecrown]
Bangster Offline
Same heat range, they are nickel-alloy instead of platinum. I am not sure of the wear on the nickel electrode plugs versus platinum, but it likely isn't as long. Motorcraft sells these longer life than copper plugs.
If longevity isn't important to you, these are okay to use. As in they won't last as long as 100,000 platinums, but will last longer than 20,000 coppers.
97 Cougar 4.6 Sport (RIP)
89 Cougar LS (RIP)
63 Falcon 302
82 F-150
97 Mark VIII LSC (RIP)
2017 Escape SE (RIP)
2012 Fusion Sport AWD
#2828530 - 04/17/14 06:22 PM Re: correct plugs for 07 [Re: unclecrown]
unclecrown Offline
Hi Bangster,
Thanks very much, I will go ahead and use them. You are right I don’t leave the plugs in for 100,000.Will see if I can get 50,000 out of them. As you probably know gasoline has hit $4.15 a gallon here, so I will be opening up the plug gaps to .065” and fitting “sultans of spark” coils in an attempt to improve MPG.
Mileage now is 105,000.
PS, I see you are up to 86 today,you must know your AC system inside out.
07 C/Vic P71
#2828638 - 04/18/14 07:10 AM Re: correct plugs for 07 [Re: unclecrown]
therealdnewton3 Offline
Loc: Indianapolis
Those plugs will easily last 50k miles. I'd use them and not worry.
HIS: 2007 Grand Marquis LS with CVPI struts/shocks & 29mm/17mm sway bars with stock springs (an excellent compromise for handling and ride!)
HERS: 2005 Grand Marquis LS with stock struts/shocks with 26mm/15mm sway bar (less control than mine but more than stock, however it has heated seats so the rest does not matter to her!)
SON'S: 2006 CVLX; pending suspension upgrades
#2828697 - 04/18/14 12:49 PM Re: correct plugs for 07 [Re: unclecrown]
unclecrown Offline
Hi,
Thanks its reassuring to know that I should get 50,000 miles from the plugs.
07 C/Vic P71
2 registered (32_80, reminc70), 100 Guests and 14 Spiders online.
