Page 3 of 3 < 1 2 3
#2867319 - 10/18/14 12:42 PM Re: Transmission shudder [Re: OH04CVPI]
OH04CVPI Offline
Loc: Ohio
I appreciate all the help, folks!
2007 CVPI (work vehicle)
2011 Ram Hemi Crew Cab 4X4
#2867576 - 10/20/14 04:28 AM Re: Transmission shudder [Re: RF_Overlord]
03RedVicSport Offline
Loc: Central NY
Originally Posted By: RF_Overlord
While Dr. Tranny Instant Shudder Fixx is respected on BITOG and is not considered snake oil, here's the problem with it:
If it works, that means the additive pack in the ATF is depleted and the fluid is at the end of its useful life. You are still only putting a band-aid on the problem. The real solution is to do a complete fluid exchange with fresh Mercon V. Yes, I understand the difference in cost and ease of use, but I would only use Dr Tranny as a stop-gap until I could perform a proper "fixx".
That's the first thing I did on my '94 mustang, was a fluid & filter & Mercon V.
NO difference AT ALL.
Then I added the Dr. Tranny stuff and it made a huge improvement. I added a 2nd dose and it's almost completely gone.
Yeah it doesn't fill me with a lot of hope for the future either, but it's still working and WAY better than it was.
"All This Has Happened Before And Will Again"
#2867604 - 10/20/14 11:52 AM Re: Transmission shudder [Re: OH04CVPI]
JSO2003P71 Offline
Loc: Florida
How does this Dr. Tranny lubeguard work? Just what does it do to stop the shutter?
2003 cvpi,2008 cvpi,1994 honda accord,1976 camaro,1988 c1500,2001 honda accord,1999 honda accord,1994 suzuki rf900r,2012 Dodge charger,2001 mustang gt,2010 impala,2013 impala,2013 Taurus
#2867608 - 10/20/14 12:18 PM Re: Transmission shudder [Re: OH04CVPI]
Mercon V is known as an HFM fluid...Highly Friction Modified. It was developed by Ford primarily to address the shudder issue caused by a phenomenon called "stiction" in the torque converter clutch. Stiction is where the clutch material alternately slips then grabs, producing the "rumble strip" feeling and is caused by a breakdown of the fluid/friction material interface. Ford's solution was to increase the amount of friction modifiers in the fluid. These are the same friction modifiers used in gear lube for limited-slip differentials. It's one of the primary improvements over plain Mercon.
Dr. Tranny is a concentrated dose of FM.
#2867615 - 10/20/14 01:31 PM Re: Transmission shudder [Re: JSO2003P71]
GrandVictoriaV8 Offline
Loc: Eastern Canada
A few fragments of info in this clip...
#2867642 - 10/20/14 03:49 PM Re: Transmission shudder [Re: OH04CVPI]
JSO2003P71 Offline
Loc: Florida
Interesting,thanks. I just like to know how and why things work. Thanks again.
#2869138 - 10/28/14 08:15 PM Re: Transmission shudder [Re: OH04CVPI]
Loc: Eastern Canada
Just thought I'd add that I went and bought the Dr. Tranny stuff so I could form my own opinion.
I know nothing about the history of my fluid and I'm not changing it until spring - if then. It did appear decent on the stick, though. Anyway, I bought 2 tubes of DT, dumped one in and went for a drive. The shudder I'd noticed over the past few months could not be felt anywhere, and although I tried, I could no duplicate it even once.
Also, previously when going up hill the transmission shift was kinda hard and noticeable. Now it's incredibly smooth. The kick-in feels almost effortless.
Just my observations, judge for yourself.
#2869152 - 10/28/14 09:16 PM Re: Transmission shudder [Re: OH04CVPI]
OH04CVPI Offline
Loc: Ohio
I have put it in, and have noticed a difference already, but it's been several days now. However, I did notes definite improvement almost right away.
#2869154 - 10/28/14 09:29 PM Re: Transmission shudder [Re: OH04CVPI]
Loc: Eastern Canada
I emailed the company with some questions about the product and the representative said that it was OK to add 2 tubes if you don't experience the results you desire, but to never add any more than 2 tubes. I bought 2 but just used 1.
#2869283 - 10/29/14 04:37 PM Re: Transmission shudder [Re: BigMerc96]
imvic Offline
Loc: syracuse, n.y......i mean, Den...
x200, definitely sounds like a misfire. 4.6s can be really soft with misfires, feels more like a trans issue but happens under different circumstances. But the fact that its "shuddering" when accelerating under load (ie: accelerating without downshifting) sounds much more like a misfire from a weak coil/plug. [/quote]
man, you guys are dead on with this. i had a bad (no. 7) plug wire a few months ago. under hiway cruise conditions, the car would shudder badly. i was scared that it was the tranny because it felt SO much like it was slipping and grabbing. the CEL came on and i read the code. i did a plug and wire change and all gone. the correct word for these misfires is "soft". well put.
just in the last few days it has come back. but i think that the intake finally let go at the rear water hose fitting. i think it is leakint into the plug hole and shorting out the plug. time to change the intake.
'97 CV. 226,000 and change on it. Unmolested, except for a K&N air filter, an air box mod, a really cool hood shock modification, KYB shocks, P71 front springs, cut 1/3 coil to lower it 1", HPP front and rear sway bar with poly bushings on the front, Hankook Ventus V4 ES 225/55/ZR17 front and 235/55ZR17 rear on new wheels...and a trailer hitch that adds 10 HP.
"Buy land. They've stopped making it" - Mark Twain
Page 3 of 3 < 1 2 3
