Page 2 of 4 < 1 2 3 4 >
#2868020 - 10/22/14 01:25 PM Re: Car is breaking up at all rpm [Re: Vickey2000]
Vickey2000 Offline
Loc: South Florida
I think I will buy my new maf and injectors that way I have a excuse to buy them now for my turbo build.
2000 CVPI- Matte Pine Green Metallic- Weekend Warrior
NA- 14.366 @96.83
1996 Grand Marquis- Aluminum- Daily driven
PI intake swap, marauder rear sway bar, heavy duty converter, and shift kit.
#2868089 - 10/22/14 06:58 PM Re: Car is breaking up at all rpm [Re: Vickey2000]
09mnsp Offline
Loc: Minnesota, U.S.
Originally Posted By: Vickey2000
the stations have so many failsafes, filters, and separators to make sure this kind of issue doesnt happen.
I would at least like to think the same when it comes to this
09 P71
#2868108 - 10/22/14 08:26 PM Re: Car is breaking up at all rpm [Re: Vickey2000]
kurt Offline
Loc: OH
Shaping mafs fixed it. But your old maf back in also fixed it. I'd be looking at the coupler at the maf or anything else you removed and put back on in the process. Maybe nothing is bad. Could have just been a soft set coupler.
07 P71 (MHS stage II cams, UDP, Kooks long tubes, 3650 swap)
02 FX4 F150 5.4 (custom dents)
68 mustang coupe (in pieces)
66 F250 240 L6 218 whp (Restored and not stock)
83 mustang gt (return of the 4v)
#2868113 - 10/22/14 08:42 PM Re: Car is breaking up at all rpm [Re: Vickey2000]
Vickey2000 Offline
Loc: South Florida
kurt- I triple checked everything. I even had to take the intake off to remove all the spark plugs so I doubt I forgot to tighten it up 2x. Im still leaning towards bad gas.
I was driving earlier today in the car and seamed fine. Floored it the entire time(after she was all warmed up) to make sure she didnt go lean and just to remove all that crap from the tank.
NA- 14.366 @96.83
#2868404 - 10/23/14 10:36 PM Re: Car is breaking up at all rpm [Re: Vickey2000]
kurt Offline
Loc: OH
I thought after you removed and installed everything was fine. So I was implying that you only had something loose once. The second time you got everything tight so now it's all good. Sorry if I misunderstood. Whatever the cause was hopefully it is gone for good now
#2868406 - 10/23/14 10:40 PM Re: Car is breaking up at all rpm [Re: kurt]
yeahinc Offline
Loc: Orlando, FL
We had a bad coolant temp sensor once, it did this. Took us 2 weeks to figure it out. Damn sensor. It's behind to the bottom of the alternator in the engine block under the intake manifold.
http://www.cmautowerkz.com
#2868485 - 10/24/14 02:56 PM Re: Car is breaking up at all rpm [Re: Vickey2000]
Vickey2000 Offline
Loc: South Florida
Kurt- nope. Lol. I checked everything then reinstalled and still wrong. Hey wr all get confused, we are only human.
Yeahinc- what year did it happen to? I thought the knock sensor was in the side of the block under the manifold.
NA- 14.366 @96.83
#2868501 - 10/24/14 03:58 PM Re: Car is breaking up at all rpm [Re: Vickey2000]
They both are. There is a threaded boss on the cylinder heads in the engine valley. The coolant temp sensor is in the drivers side head.
#2868555 - 10/24/14 07:20 PM Re: Car is breaking up at all rpm [Re: Vickey2000]
Vickey2000 Offline
Loc: South Florida
Thanks guys. I didnt know that. It has to be an original part with about 150k on it. I will check and see how much that part is tomorrow.
NA- 14.366 @96.83
#2868673 - 10/25/14 07:35 PM Re: Car is breaking up at all rpm [Re: Vickey2000]
Vickey2000 Offline
Loc: South Florida
Well here it is.
I pulled it apart to show that epoxy was on the outside. Someone already messed with it. Even worse, I didnt realize it when I re assembled the motor. I will install it tomorrow. Should be easy since the victor jr frees up a ton of room. I will let you know how it turns out.
NA- 14.366 @96.83
#2868684 - 10/25/14 09:06 PM Re: Car is breaking up at all rpm [Re: Vickey2000]
09mnsp Offline
Good to hear you're getting somewhere with this. smile
09 P71
#2868769 - 10/26/14 07:42 PM Re: Car is breaking up at all rpm [Re: Vickey2000]
Vickey2000 Offline
Loc: South Florida
Installed the new sensor today and car is running the same way. Not breaking up anymore but I still dont know what caused this scare.
NA- 14.366 @96.83
#2868837 - 10/27/14 08:06 AM Re: Car is breaking up at all rpm [Re: Vickey2000]
Og04 Offline
Loc: Miami, Fl.
O2 sensors?
2004 P71- 123k miles
Magnusson Tork Tech 9lbs. Stainless Works LT, 3.73 gears,
Catless 2.5 exhaust. 19" 2011 Mustang wheels, 2005/2015 Mustang Rear Lower ControlArms, tuned by Mo's Speed Shop
#2868842 - 10/27/14 09:13 AM Re: Car is breaking up at all rpm [Re: Vickey2000]
Vickey2000 Offline
Loc: South Florida
I just replaced them 6-7 months ago sobi dont think they are bad.
NA- 14.366 @96.83
#2869315 - 10/29/14 08:17 PM Re: Car is breaking up at all rpm [Re: Vickey2000]
Vickey2000 Offline
Loc: South Florida
ITS BACK!!!!!!!
This time it happened right after I hit the rev limiter. Now it is dumping gas like crazy!!!! At idle she will read from 9.8 to 10.5!!! WTF!!!!!
NA- 14.366 @96.83
0 registered (), 109 Guests and 11 Spiders online.
Traffic22 15
