#2872896 - 11/20/14 12:51 PM Misfire questions. Help!
Brandon_White Offline
Loc: Portland, OR
My 2001 CVPI has the obvious signs of misfiring. Shaking, rough idle, flashing CEL but no codes on the scan tool. I'm not sure how to determine which cylinder, or cylinders are misfiring. I can't drive it and need it for work so any help is appreciated. I have spare coils to swap in if that helps. I just don't know how to figure out which cylinder it is. Thanks guys!
2001 CVPI, 101,XXX miles
Magnaflow Mufflers, more mods in the works
#2872899 - 11/20/14 02:27 PM Re: Misfire questions. Help! [Re: Brandon_White]
chipdog4 Offline
Loc: SouthWest Indiana
Check the plug wells and see which one has oil or antifreeze pooled in it.
99 LSE clone
#2872990 - 11/21/14 01:08 AM Re: Misfire questions. Help! [Re: Brandon_White]
bluviclx98 Offline
Loc: Mississippi
Let it idle and pull Connector at coils off one at a time. It should make motor miss or run rough. If one doesn't sound different when pulled then good chance that's it. Then replace with spare coil. Check plug next. Before removing plug suck plug well with vac or blow with air to remove debris first. Listen for each injector with hollow metal tube for ticking if coils and plugs are ok. Hope this helps and good luck.
Its only my opinion and worthless cept to me!
1998 Crown Vic Lx. 103,000 miles, Dual Exhaust W/ H-Pipe, Magnaflow's and 2nd Cat Delete, FRPP PI Intake, P&P Plenum, Summit 70mm TB, MTZ, BOC 93 OCT Tune, 180 stat, 22c Plugs, ADTR High Flow intake tube, Autometer Z-Series Tach in Column Mount, 2" Hitch Receiver, Previous Owner Replaced Air Suspension with Coils. BH1976 Headlight Harness, Black P71 Honeycomb Grille. (On but not shown)
#2872998 - 11/21/14 07:06 AM Re: Misfire questions. Help! [Re: Brandon_White]
Loc: Portland, OR
Alright well no luck at all. It's looking bad for me, I'm broke and not sure what to do.
#2873018 - 11/21/14 09:52 AM Re: Misfire questions. Help! [Re: Brandon_White]
Loc: Portland, OR
Now it's worse and I have four codes. P0355, P0356, P0357, P0102 and P0205
#2873021 - 11/21/14 10:17 AM Re: Misfire questions. Help! [Re: Brandon_White]
Bangster Offline
Looks like you have a wiring problem on the drivers side. Those codes mean there likely an open or a short in the wiring to those cylinders.
P0102 and P0205
That P0205 is a wiring issue to a cylinder also affected by a wiring problem above.
97 Cougar 4.6 Sport (RIP)
89 Cougar LS (RIP)
63 Falcon 302
82 F-150
97 Mark VIII LSC (RIP)
2017 Escape SE (RIP)
2012 Fusion Sport AWD
#2873022 - 11/21/14 10:22 AM Re: Misfire questions. Help! [Re: Bangster]
Loc: Portland, OR
P0102 and P0205
How would I find or fix it?
#2873041 - 11/21/14 03:08 PM Re: Misfire questions. Help! [Re: Brandon_White]
bluviclx98 Offline
Loc: Mississippi
I think the wiring for those cylinders comes from wires under the brake master cylinder on the brake booster. There is large harness connectors that lead to back of driver valve cover and then to each cop. Look for chafed, worn or harness laying on valve cover and grounded or burnt through. Their should be a common color wire that goes to each cop, red with light green stripe I believe. Could be wrong on color. Have to track that wire for damage. Shorts are hard to find, good luck.
#2873126 - 11/22/14 02:07 AM Re: Misfire questions. Help! [Re: Brandon_White]
Loc: Portland, OR
Well I'm completely lost, I guess I'm taking it in. Thanks anyways guys.
#2873542 - 11/25/14 01:23 AM Re: Misfire questions. Help! [Re: Brandon_White]
bluviclx98 Offline
Loc: Mississippi
Let us know the results and hopefully not to pricey and you get it fixed!
6 registered (MinnesotaP71, Hambone, RyderPhan, WalterL, akr619, cv83), 106 Guests and 13 Spiders online.
