#2893258 - 04/25/15 04:05 PM Vacuum operated device on fuel rail?
hilljack Offline
Loc: New Mexico, USA
What is this thing on the fuel rail, and what does it do?
Edited by hilljack (04/25/15 07:05 PM)
2004 Crown Victoria Sport LX
Factory Rear Air Ride/HD KYB Shocks
JMod, 3L27, MagnaFlow mufflers
04 CVPI Air Box/Zip Tube, 70 mm Truck TB, AED SC @ 6PSI
140,000 miles
#2893276 - 04/25/15 05:31 PM Re: Vacuum operated device on fuel rail? [Re: hilljack]
dedsqwirl Offline
Loc: SCS, MI
Fuel pressure regulator.
#2893281 - 04/25/15 05:46 PM Re: Vacuum operated device on fuel rail? [Re: hilljack]
hilljack Offline
Hhmm? This is on a 2004 CV. Are you sure?
140,000 miles
#2893282 - 04/25/15 06:03 PM Re: Vacuum operated device on fuel rail? [Re: hilljack]
Bangster Offline
It is a Pressure Dampener.
97 Cougar 4.6 Sport (RIP)
89 Cougar LS (RIP)
63 Falcon 302
82 F-150
97 Mark VIII LSC (RIP)
2017 Escape SE (RIP)
2012 Fusion Sport AWD
#2893284 - 04/25/15 06:15 PM Re: Vacuum operated device on fuel rail? [Re: hilljack]
hilljack Offline
Cool, thanks. Is it a needed part or can the fuel system run ok without it?
Plan on making some changes and that may not be used, if it is not needed.
140,000 miles
#2893303 - 04/25/15 08:55 PM Re: Vacuum operated device on fuel rail? [Re: hilljack]
southflavic Offline
Loc: Pompano Beach, fl.
You should be fine without it. Its called a injector pulse dampener. After market rails??
03vic in south florida, vortech supercharger,70mm throttle body with spacers ,p&p upper phenium,180 thermo,80lb injectors, custom tune from mo's,locker with 3.55,ported pi head, stage 2 cams ,forged bottom end all in a new block.
#2893310 - 04/25/15 09:33 PM Re: Vacuum operated device on fuel rail? [Re: hilljack]
hilljack Offline
Cool. Kinda what I was thinking. Yep, after market rails.
140,000 miles
0 registered (), 136 Guests and 14 Spiders online.
