#2908199 - 07/20/15 12:14 PM Code scanner
Frankie4speed Offline
Frankie the Fighter
I have an Innovia 3130. It won't give me live data anymore. I don't know how old it is .I got it used. Can it be repaired? If not which one should I get? I want to scan A.B.S. and S.R.S. and of course live data. There are so many out there I'm confused. Thanks for any help.
#2908215 - 07/20/15 01:17 PM Re: Code scanner [Re: Frankie4speed]
DussellRay Offline
Loc: South Florida
The one I use is only $30 total and it does all the live data as well as codes but I don't believe it does A.B.S.
It might not be exactly what you're looking for but here you go. It's worked very well for codes, for me.
2000 Crown Victoria Base Geezer Edition with 88,000 miles (and counting).
BOTM July 2015
Click to reveal... (Mods Added and in the waiting)
mods so far:
3.55 rear end (23 tooth speedo gear)
Tinted Windows
Hardwired Whistler radar detector
hardwired dash cam (G1W-C)
2003 Cup holder
Extra Accessory outlet from LX on passenger side
Interior LEDs
Homemade headlight relay upgrade
#2908248 - 07/20/15 04:25 PM Re: Code scanner [Re: Frankie4speed]
Frankie the Fighter
Thanks Ray. Just spoke with someone at innova. They will try to repair it. For $99.If not they will send me the updated version. A 3160 for $129.
#2908958 - 07/24/15 11:10 AM Re: Code scanner [Re: Frankie4speed]
Rodman Offline
Loc: Trying to keep Austin Weird
Frankie, if you're going to spend $100 or more anyway, check out the ScanGauge II. I own one, and can highly recommend it. Not sure about ABS or SRS on it though, but here is a link to their site:
http://www.scangauge.com/
You can buy direct from them, as well as Amazon and probably eBay.
Good Luck!
Semi-employed with a temp agency. Actually very enjoyable gigs so far.
Current: Mine is an '03 LX w/135K miles & the Wife has had (sold 12/2019) an '03 GM with about 125K miles and some peeling paint. frown
1. Law of Mechanical Repair - After your hands become coated with grease, your nose will begin to itch and you'll have to pee.
2. Law of Gravity - Any tool, nut, bolt, screw, when dropped, will roll to the least accessible corner.
3. Law of Probability - The probability of being watched is directly proportional to the stupidity of your act.
4. Variation Law - If you change lines (or traffic lanes), the one you were in will always move faster than the one you are in now.
#2909091 - 07/25/15 03:00 AM Re: Code scanner [Re: DussellRay]
MercRoller Offline
Loc: Corryton, Tn
Looks interesting, what app do you use for your phone with it?
#2909143 - 07/25/15 01:34 PM Re: Code scanner [Re: Frankie4speed]
DussellRay Offline
Loc: South Florida
i use the pro Torque app. the pro is $5 plus the ~$22 for the scanner. you can still use the free version but you are limited to only codes, I think.
BOTM July 2015
mods so far:
Tinted Windows
2003 Cup holder
Interior LEDs
#2909193 - 07/25/15 08:37 PM Re: Code scanner [Re: Frankie4speed]
Quasar Offline
Loc: Milwaukee, WI
I got the autel md802. It will run you about 250-300 on Amazon. But I promise you it will do everything you want and more. I can pull the door codes from the DDM with it, all the eatc tests, cluster tests, PCM tests.
It does airbag and ABS codes as well as all OBD codes. Best scanner I have ever bought. Updates are free for first year $99.00 a year after that. But the updates only tend to be for newer model cars, so until you buy a 2014/2015 vehicle, Id skip the updates or at least only do every few years.
http://www.auteltech.com/Professional%20Scan%20Tools/368.jhtml
#2909218 - 07/25/15 11:43 PM Re: Code scanner [Re: Frankie4speed]
MercRoller Offline
Loc: Corryton, Tn
Thank you for the info. Going to check that out.
#2909470 - 07/27/15 10:10 AM Re: Code scanner [Re: Frankie4speed]
Frankie the Fighter
Rodman, Thanks for the info. Just sent out my old Innova. Waiting for my new 3160.
#2909794 - 07/28/15 06:13 PM Re: Code scanner [Re: Frankie4speed]
Autel MD802 4-system here. So far so good. If you opt for this one, get/upgrade to the All System.
Quasar, is the DDM and other scan modules separate files in the unit? I'd like to try something.
Alex.
#2909809 - 07/28/15 07:06 PM Re: Code scanner [Re: Frankie4speed]
IPreferDIY Offline
My experience with Autel hasn't been all that great. I got their AL439, which is a basic code reader/scanner that includes a voltmeter and starting and charging system tests. The starting and charging system tests don't seem to have ever worked properly. Both tests tell me there is "excessive noise" (which causes the starting test not to measure anything). I recall that the AC voltmeter worked fine when checking a 16V AC adapter, but I got weird results when trying to measure AC ripple.
Their customer service was absolutely useless. I ended up exchanging the unit twice but got the same results. I don't recall the timing, but I've tested two alternators that I have and tried the unit on at least one other person's car. Both of my alternators seem to be working fine, and I even confirmed for at least one of them that the diodes weren't leaking. I ultimately kept the latest unit since it was still a lot better than what else I could've gotten for the same money (about $90 CDN plus taxes when it was on sale for half price).
When updating it (at no cost), there was a program file and a data file. I think I did the program file first, and everything came up in Chinese. I navigated through the menus from memory to update the other file, and the English came back. IIRC, I still got the same results from the starting and charging tests.
Based on my experiences, I'm not at all impressed with Autel, though it's interesting to read other people's experiences.
EDIT: I just did an update for s's&g's with two English files. Now some of the messages are in Spanish even though it's set for English. wtf2
Edited by IPreferDIY (07/28/15 09:16 PM)
2000 Grand Marquis LS HPP, a hand-me-down in 2008 with 128,000 km; 180,000 km as of May 2015
mods: air filter box 'tuba', headlight relay harness, J-mod (around 186,350 km), 70mm throttle body, KYB Gas-A-Just shocks, aluminum driveshaft, ARA3 PCM
#2910023 - 07/29/15 07:46 PM Re: Code scanner [Re: GM_Guy]
Quasar Offline
Loc: Milwaukee, WI
Alex.
I think so yes. mine is the all systems version, its not under OBD but its all under the scan section. You start a new scan. It pulls the vin and vehicle info then gives you the abilty to scan all the modules or to pick through the list of modules. (Sorry i dont have it with me at moment for exact wording).
Ipreferdiy, my md802 doesnt have that feature of the electrical testimg, but that does sound frustrating. I will absolutely agree and say that the weakest link of this scan tool is the update process. It is slow and tedious but once its updated it has been great.
Edited by Quasar (07/29/15 10:57 PM)
#2911098 - 08/03/15 11:27 PM Re: Code scanner [Re: Frankie4speed]
aperson48 Offline
Loc: Vancouver, BC
Has anyone used the OBDLink LX bluetooth reader?
Here's the link: https://www.scantool.net/obdlink-lx.html
I was thinking of using this to get real-time readouts for MPG and RPMs (sadly my '05 doesn't have a tach). Also checking and clearing check engine lights. Would be cool to hook this up to a tablet and mount it on my dash!
2005 navy blue CVPI, ex Victoria PD
#2911189 - 08/04/15 03:03 PM Re: Code scanner [Re: aperson48]
PHoganDive Offline
Loc: Mass, USA
I use an Ultragauge for those things, and more... Ultragauge
#2917704 - 09/14/15 09:22 AM Re: Code scanner [Re: Frankie4speed]
CROWNVICROB Offline
Loc: USA
I could be wrong, but i think SCT is the most common brand.
Signature removed for excessive length.
Read the rules.
2 registered (RipWixomAssembly, Moby_Vic), 134 Guests and 19 Spiders online.
Traffic22 15
