#2930913 - 11/22/15 12:31 PM 15" steelies on 03+ rear?
BigNSlow Offline
Loc:
Hopefully someone here has tried this and can give me the right answer. Will 15" steelies from pre 98' fit on the rear of 03+? I know they won't clear the calipers in the front but what about the back? Reason I am asking is I have a set of steelies with brand new snow tires that I never used and want to throw them on the rear this winter.
#2930916 - 11/22/15 12:43 PM Re: 15" steelies on 03+ rear? [Re: BigNSlow]
Chaplian Offline
Insert witty title here
Loc: Chicago, IL
I am quite positive they will fit. I can't remember who, but someone here was using 15" slicks for their rear on their 03+ when they drag raced.
2011 Crown Vic LX- 78,xxx.
2003 Crown Vic HPP- 235,xxx miles. Retired.
1995 Impala SS- 29xxx miles. The Lovely Lady
2003 BMW 325i Wagon- 8250 RPM redline. Complete M3 drivetrain, suspension, and electronics. Taylor Swift.
2017 Mazda3 GT Hatchback- 90,xxxx miles. 2.5L, fully loaded. The Daily Grind.
#2930965 - 11/22/15 05:24 PM Re: 15" steelies on 03+ rear? [Re: BigNSlow]
EvilVic has 15" drag wheels on the back, I know NGreen had 15" wheels front and rear on his Turbo car as well.
#2931015 - 11/22/15 10:43 PM Re: 15" steelies on 03+ rear? [Re: BigNSlow]
Yes they will fit. See plenty of cvgms around here with an old set of steelies for winter tires out back. Even saw a Marauder a couple years ago with a set of pre-o3 wheels with snow tires on it. Downside is the tire sticks out further.My concern would be fender to wheel clearance. Might be problematic over bumps with any extra bodies in the car.
Alex.
#2931041 - 11/23/15 01:37 AM Re: 15" steelies on 03+ rear? [Re: BigNSlow]
As Alex said, they'll fit but will stick out.
Is this for Rustrauder? If so, I would recommend against it in case of RAS failure.
If it's for the green car, I wouldn't worry since it's on coils.
#2931067 - 11/23/15 07:30 AM Re: 15" steelies on 03+ rear? [Re: BigNSlow]
BigNSlow Offline
Loc:
Ok thanks for the info. It's for the green car.
#2931182 - 11/23/15 02:47 PM Re: 15" steelies on 03+ rear? [Re: BigNSlow]
Some pics. The Marauder had lincoln alloy wheels on it if I remember right. Might have been Sport wheels to. Don't remember, but it was definately a set of panther based alloy wheels.
And a couple other randomn spottings. I'm sure if I actually look for them I'll spot a few more.
Alex.
#2931185 - 11/23/15 03:02 PM Re: 15" steelies on 03+ rear? [Re: BigNSlow]
cruz07 Offline
Loc: Dallas County, TX
The angle of the CV from the rear looks kindof cool, until the shot from the back, then it looks like a four legged beetle.
2005 P71 146,XXX SOLD 03-10-2020
2018 Chevrolet Traverse 33,XXX
X-Panthers
1997 P71 161K
1998 P71 113K
Originally Posted By Moby_Vic
Because CVN is the land of $600 cars.
#2937946 - 11/28/15 06:40 PM Re: 15" steelies on 03+ rear? [Re: BigNSlow]
Mr. 427
I've got 15s on the back, too.
You'll be good to go.
1964 Ford Galaxie 500 R-Code
1972 Ford Galaxie 500
2008 Ford CVPI
#2939658 - 11/29/15 07:38 PM Re: 15" steelies on 03+ rear? [Re: CNGInterceptor]
BigNSlow Offline
Loc:
Yup, they don't fit. The wheel rubs on the caliper.
#2939850 - 11/29/15 10:44 PM Re: 15" steelies on 03+ rear? [Re: BigNSlow]
How close to seating the wheel does it get?
I should try out one of my aftermarket 15s I still have from the box and see how the clearance is on it since it doesn't have as deep a drop center.
Alex.
#2939858 - 11/29/15 10:56 PM Re: 15" steelies on 03+ rear? [Re: BigNSlow]
BigNSlow Offline
Loc:
The wheel goes on but you won't be able to drive off because it would be seized against the caliper.
#2939906 - 11/30/15 12:11 AM Re: 15" steelies on 03+ rear? [Re: BigNSlow]
Is it the shape of the 15s, then? As others have said, we have people running (different) 15s out back.
#2940178 - 11/30/15 08:33 AM Re: 15" steelies on 03+ rear? [Re: BigNSlow]
mdnos Offline
Loc: not here any longer
Put a 1/4 inch slip on spacer. I believe Mr. Gasket makes some for around $25..Seen them on ebay plenty of times.
#2940202 - 11/30/15 08:45 AM Re: 15" steelies on 03+ rear? [Re: mdnos]
BigNSlow Offline
Loc:
I don't want to screw around with that. I have a set of 17"s I can put in the back. The tires aren't great but they will do.
Moderator:  RF_Overlord
