Page 2 of 3 < 1 2 3 >
#3059922 - 02/11/16 04:22 PM Re: Oil filter madness [Re: 98BoatCaptain]
Nick23 Offline
Loc: Mayberry, NC
Just checked my sources, Toyota has been doing it since 2014...
1999 Crown Vic P71
3.55 Trac Lok
SpeedForm Mustang GT functional hood scoop
Magnaflow 18134s
70mm Throttle Body
#3059930 - 02/11/16 04:24 PM Re: Oil filter madness [Re: 98BoatCaptain]
98BoatCaptain Offline
Loc: Albuquerque NM
Oh lovely. Further evidence I should take a look at getting a 2011 CV when the time comes. Should probably start looking now.
1998 Mercury Grand Marquis LS
212k miles, Peelformance White frown
#3059978 - 02/11/16 04:54 PM Re: Oil filter madness [Re: Nick23]
Blakat Offline
Loc: Shadow of Ford World HQ
I had not heard that before, so I just asked my brother (Toyota test engineer), and he confirmed that several of their engines have gone that way.
Not a big deal, the tools are readily available. Apparently you can still remove the filter cover with a 3/8" ratchet extension or channel locks, but the tool makes it much easier.
http://www.walmart.com/ip/48206820?wmlsp...594&veh=sem
Have no fear. Embrace change.
2008 Crown Victoria Police Interceptor
Former Sheriff's Department, Isabella County, Michigan
#3059994 - 02/11/16 05:12 PM Re: Oil filter madness [Re: 98BoatCaptain]
Bangster Offline
There is a trend back to cartridge style oil filters. Welcome back using a roll of toilet paper as a filter.
Oil is black because it holds in suspension carbon and other combustion by products, like it is supposed to. If I drive most of the miles on my 285,000 mile Grand Marquis, the oil is black in the first 1,000 miles. If it is only my wife driving, it is still golden brown at 5,000 miles.
I have always filled to the top of the cross hatch area (usually 5.5 quarts), and until recently (last 60k or so miles) I didn't have to add. Now I can add a pint at 3000 miles and be at the bottom cross hatch at 5000 miles. I don't consider that excessive use.
97 Cougar 4.6 Sport (RIP)
89 Cougar LS (RIP)
63 Falcon 302
82 F-150
97 Mark VIII LSC (RIP)
2017 Escape SE (RIP)
2012 Fusion Sport AWD
#3060010 - 02/11/16 05:15 PM Re: Oil filter madness [Re: Bangster]
Blakat Offline
Anyone in Detroit remember Ramchargers? They used to sell a screw on oil filter that used a toilet paper roll filter.
#3060226 - 02/11/16 07:45 PM Re: Oil filter madness [Re: 98BoatCaptain]
CrystalPistol Offline
Loc: Shenandoah Valley
Originally Posted By 98BoatCaptain
So it seems I've committed a cardinal sin by putting a Fram HM2 filter on my motor the last time I did an oil change, a few weeks ago.
Bought the Fram because Fram was all they had at the store. But I can order a Motorcraft 820S. It is only about $5 with shipping, and I was ordering some stuff from rockauto anyway. Is it worth the effort to swap it out before the next oil change?
I can only see that ending in tears. Every time I've replaced the oil filter before, I had first drained the engine. If I take the filter off with the engine full of oil...well, it will be messy.
No more so than taking it off after draining for a complete oil change. You might have to add 1/2 quart back after swapping filters but it's not gonna drain all the oil out of the pan 'cause the oil is all below the filter adapter and on the far side of the oil pump.
Just pull the car upon the ramps .... shut the engine off .... let sit a shot while to cool off, etc .... and swap the oil filter ..... and then start engine and let it run a few moments .... park on level .... shut off .... wait a few moments to drain back .... check oil level.
Edited by CrystalPistol (02/11/16 07:46 PM)
#3060250 - 02/11/16 08:03 PM Re: Oil filter madness [Re: 98BoatCaptain]
The Fram OCD is more of a internet myth than fact, I've never had a issue with one and were all I used for years... I WILL NOT use a Purolator Classic as those tend to have iffy anti drain back valves that cause noisy startup because filter has lost it oil... Plus there have been issues with tears in the pleats...
Some oils darken with use, but generally it's because as engine wears blowby becomes greater, that contaminants and overheats(which darkens) the oil in piston ring lands and on cylinder walls... On any engine that quickly darkens oil it's likely not a good to do extended changes... 3-4K mi with dino would by my routine and exactly what the beater F-150 gets... I've run the '07 over 11K mi and the '98 9500mi using Mobil 1 and oil was still cleaner than the truck at 3K mi...
Back in Dec I picked up 46 quarts of Pennzoil Platinum SRT 0W-40 at A Zone closeout for $2 a quart... For the next couple years that will be in both my MGMs, truck and probably the T-Bird...
Now with P/S & PDB
#3060298 - 02/11/16 08:37 PM Re: Oil filter madness [Re: GrandMarq9807]
Chaplian Offline
Insert witty title here
Loc: Chicago, IL
http://minimopar.knizefamily.net/oilfilters/reference.html
2011 Crown Vic LX- 78,xxx.
2003 Crown Vic HPP- 235,xxx miles. Retired.
1995 Impala SS- 29xxx miles. The Lovely Lady
2003 BMW 325i Wagon- 8250 RPM redline. Complete M3 drivetrain, suspension, and electronics. Taylor Swift.
2017 Mazda3 GT Hatchback- 90,xxxx miles. 2.5L, fully loaded. The Daily Grind.
#3060626 - 02/12/16 12:15 AM Re: Oil filter madness [Re: 98BoatCaptain]
I'll +1 everyone who recommends that you use the Fram until your next change. I had a loose Fram I got on an oil change special and that's currently on the Marquis. No big deal. Otherwise, FL820S or Purolator PureOne for me.
Change intervals on Panthers? Eh. After hearing about CNGInterceptor going something absurd like 17k on a change (before he started tearing the car apart), I go 5-7k on the Marquis with synthetic and don't even think about it. I admit to 3-4k intervals on the Marauder with full synthetic just because.
#3062497 - 02/13/16 01:51 AM Re: Oil filter madness [Re: 98BoatCaptain]
Y_K Offline
Loc: USA
Fram Ultra oil filters are top tier.
An example from BITOG
I have a stash of MC 820s filters that I am slowly bringing back to Walmart, as they have repeated tear issues after switch to Purolator, which was in turn acquired. To put it bluntly, I'd avoid Motorcraft like a plague right now. There are multiple tear reports on this particular filter. Used to be the go to filter for me. Mobil 1 gives start-up noise. Fram Ultra is fine and of higher quality than M1 anyway. NAPA Platinum is a very good option, no noise, and they are on sale at reasonable price levels a couple of times per year.
Color of spent oil is meaningless nowadays.
Here is a recent discussion, involving an MC filter. And you can find a few recent MC 820s autopsies with tears and low build quality there. Pity, it used to be a very good filter..
2004 MGM & 2004 LTC
#3062505 - 02/13/16 02:14 AM Re: Oil filter madness [Re: 98BoatCaptain]
For the longest time, I read positive review after positive review of the 820 on BITOG. Now this. I may have to cut open my next few oil changes and see what it looks like inside.
#3062513 - 02/13/16 02:30 AM Re: Oil filter madness [Re: 98BoatCaptain]
MercRoller Offline
Loc: Corryton, Tn
I think like anything, changing the oil at regular intervals with any decent quality filter and you will be fine. My dad has a Ford Van with almost 300k on it and its always had Motorcraft filters on it without issue.
#3062793 - 02/13/16 11:44 AM Re: Oil filter madness [Re: 98BoatCaptain]
Y_K Offline
Loc: USA
Motorcraft changed the manufacturer for the 820 recently, and the manufacturer changed hands. Corners are being cut somewhere.
I hope they will clean their act sooner than later.
2004 MGM & 2004 LTC
#3062905 - 02/13/16 01:10 PM Re: Oil filter madness [Re: a_d_a_m]
Blakat Offline
Yeah, now I am ascared!
#3063017 - 02/13/16 02:37 PM Re: Oil filter madness [Re: 98BoatCaptain]
Fordguy78 Offline
Loc: Minnesota
Synthetic oil is for cars that say on the 710 cap to use synthetic oil. Don't use it in the 4.6 as its a waste. If you want the added detergents in a fancy oil just use some atf . add a art and run the engine till warmed up, then drain the oil. I see what happens to peoples cars that use syn oil like amsoil and go twelve or fourteen k on the same oil. I end up tearing the engine down and clean the bearings out of the pan sump . use normal oil change it at 3500 to 5000 miles, if your a short triper every 3000. And for oil consumption yes all cars do it, the rings don't scrape the oil off and some is left exposed to combustion . as the new low tension ri GS of newer cars wear they will burn more , faster.
I MAY NOT KNOW IMORTANT THINGS, BUT I KNOW WHAT I AM TALKING ABOUT.....I THINK
