#3214937 - 05/22/16 07:47 AM Low coolant?
Jalv13 Offline
Loc: NJ
So my 2010 p7b that I just got has low coolant, I'm praying it's not the upper intake manifold leaking, if it is I'm sure I can replace is due to the 1000 posts about it, but my question is, is there anyway to test for leaks, how would I find the leak, should I just keep topping it off, and universal coolant, I have about a gallon of that should I use it, and finally(sorry) if it's not a leak what else could it be?
#3214953 - 05/22/16 08:18 AM Re: Low coolant? [Re: Jalv13]
mdnos Offline
Loc: not here any longer
You need to pressure check the cooling system. Harbor Freight, Stant, others make a kit with various sized adapters to fit multiple radiator openings. They are not one size fits all
#3214969 - 05/22/16 08:45 AM Re: Low coolant? [Re: Jalv13]
White Falcon LS Offline
Loc: SoCal
Top it up when it's cold, and keep an eye on it to see if it drops, or if someone simply just didn't fill it up completely. Failing that, you need to pressure test the system as mentioned above.
#3215017 - 05/22/16 09:26 AM Re: Low coolant? [Re: Jalv13]
Jalv13 Offline
Loc: NJ
Thoughts on universal coolant? If it's a no go where can I buy motorcraft gold
#3215033 - 05/22/16 10:10 AM Re: Low coolant? [Re: Jalv13]
fordoldfart Offline
Loc: kansas
Use Zerx g05.
#3215049 - 05/22/16 10:23 AM Re: Low coolant? [Re: Jalv13]
stalag Offline
Loc: Columbus, OH
See the link in my sig.
#3215337 - 05/22/16 02:54 PM Re: Low coolant? [Re: stalag]
Przemek Offline
Loc: Warsaw, Poland
As White Falcon LS wrote, top up coolant and observe it's level. If it lowers, you have a leak. Good way of searching it is to light a front of radiator and hoses with a sharp flashlight in the dark (not brightly lit garage or something like this). The leak will reflect the light of the flashlight.
If the leak is not massive you may not be able to observe it because the coolant quickly evaporates on a hot radiator.
Than pressure check is useful. Small and medium leaks may come from small holes (usually invisible) in front of radiator caused by stones coming through a grill.
If it is the reason of a leak, you have to either replace the radiator or disassemble it, take to a workshop which locates the holes and TIG welds them.
I think in the USA it is much cheaper to replace the radiator with a new one than welding. Quite the opposite than here in Poland where we don't have much radiators for CVPI ;-)
Best regards
2006 CVPI, white, 150 k miles
2007 Peugeot 607 limousine, gris aster
2005 Mercedes C55 AMG, obsidian black
#3218394 - 05/24/16 03:23 PM Re: Low coolant? [Re: Jalv13]
Jalv13 Offline
Loc: NJ
So I filled it up with vatozone universal Coolant, im gonna see if I have a leak before I flush and fill with g-05
#3218594 - 05/24/16 04:45 PM Re: Low coolant? [Re: Jalv13]
torotoro Offline
Loc: NJ
I'd rather use distilled water to top it off than "universal" coolant. I ruined my '96 Taurus with that junk.
2002 LX Spruce Green/Tan Cloth ~124,000 miles
Bilsteins, 17mm rear sway bar, BH1976 headlight relay harness, side marker/blinker mod
BC4E Dead Pedal, Upgraded Speakers, 35% Window Tint, De-chromed Exterior, Soundproofing.
0 registered (), 136 Guests and 14 Spiders online.
