#3295394 - 07/22/16 06:28 PM Upper Steering Shaft
EZlivin11 Offline
Loc: Central Coast Of CA USA
While putting the front suspension back together My son pulled on the rack and pinion to make room to insert the lower control arm cam bolt. He then said the rack would not go back in place. he pulled the upper shaft out of the steering column.
I see that it is clocked by 1 tooth that is wider than the others, but it just isn't going back in. I was reading about it in the manual and it talks about re-clocking the clock spring and about the deployable steering column needed to be replaced if deployed. Am I just having a hard time getting the shaft in or am I in deep dodo??? I didn't want to yell at My son so I sadly walked away and told him its break time, so I wouldn't say or do something I would regret. Please tell me I'm not inserting it correctly and go try again...
Edit
PS: This Car is not going to be happy until I do something to everything. I haven't been in to the transmission yet. Any bets on what is next.
Edited by EZlivin11 (07/22/16 06:45 PM)
The Gray Ghost
AKA: The Murranator
IF It's Not Broke, It Must Be Time For An Upgrade
2008 Ford Crown Victoria P71 4.6-2v
Upgrades /Mo's /1/2ShaftTB /P&PIntake /Steeda /Steering /Brakes /Suspension /Driveline /Rear-Axle3.55TL /BodySuspension-EnergySuspension /Interior /LTC-Leather /200Amp-Powerdistrabution-System /AuxBattery /SonyBluetooth /
#3295602 - 07/22/16 09:49 PM Re: Upper Steering Shaft [Re: EZlivin11]
GRC Offline
Loc: Zone 6
Yes those the lower control arm cam bolts are fun for sure, I hosed the tie rod bellows with spray lube & did my best not to tear the rubber as the bolt occupied the same space
if you remove the drivers side rack mount stud from the subframe & loosen the passenger side the rack will come forward & up just enough to git'r done. barely
on the bright side the trans should give you some time to get the steering stuffed back together
2003 & 2011 CVPI's
#3295818 - 07/23/16 10:28 AM Re: Upper Steering Shaft [Re: EZlivin11]
It should go back if it's just that one tooth that aligns it, unlock the column and keep trying.
When you do get it back in, make sure that green ring is secure. There was an issue with it coming out the bottom of the upper column which led to some kind of service bulletin, when I did the floor shifter in my ''05 CVPI and dropped the column, that came out and broke the connector to the gas pedal which left me at idle until I got a new pedal.
#3295834 - 07/23/16 10:39 AM Re: Upper Steering Shaft [Re: EZlivin11]
A retainer inspection/bulletin mentioned above is part of the latest steering shaft recall tsb. IF it is dislodged, there is a couple holes to drill via template through the column and green collar for screws to hold on the retainer. Column has to come out for that though.
Alex.
Description: Drill Guide
Edited by GM_Guy (07/23/16 11:12 AM)
#3295866 - 07/23/16 11:08 AM Re: Upper Steering Shaft [Re: EZlivin11]
#3295898 - 07/23/16 12:19 PM Re: Upper Steering Shaft [Re: EZlivin11]
EZlivin11 Offline
I did my homework last night, and I think I'm going to try and reassemble the shaft as is no parts and then take her to the dealer and try for the recall. This is the second time this shaft has come lose, The first time was when I changed out the lower shaft, but it didn't come all the way out then, and I was able to stick it back together. As I was reading the recall and repair for the shafts I noticed there is a repair kit with a bearing retainer in it to keep this from happening, and you remove the column to install the retainer. Is that drop dead date of 22 sept. 14 still in effect, I'm going to try anyway the worst Vreeland Ford can do is say no right? LOL
Now as far as the steering wheel moving while the shafts were disconnected, if the air bag light doesn't come on the clock spring should not have moved, and If I gently turn the wheel clockwise till I feel tension then center the wheel + 2 turns I should be close??? what do you all think? Mine failed miserably thanks for the link GM
Edited by EZlivin11 (07/23/16 12:20 PM)
The Gray Ghost
AKA: The Murranator
#3296018 - 07/23/16 01:42 PM Re: Upper Steering Shaft [Re: EZlivin11]
EZlivin11 Offline
To get a leg up, and in case My dependable Ford Dealer won't help Me out, I went digging for gold (I mean Parts), and Dorman, and OEM is all that pop out at Me. Strange I only hit on 1 review on Dorman upper shaft and it said don't waste your money.. That would suck cuz the price grabs you after looking at OEM. Also does the bearing come on the shaft like Dorman I found it both ways on the interweb, and there was a listing for the shaft and a collar. Is that what they are calling the bearing?
The Gray Ghost
AKA: The Murranator
#3296778 - 07/24/16 10:14 AM Re: Upper Steering Shaft [Re: EZlivin11]
Have you had the steering recall check done already? If not, when you get it back together, drive to the ford lot, dislodge that green retainer so it meets the criteria they are looking for in the recall (its not as if you are trying a scam, you got a genuine problem if it keeps popping out). See what happens. When you get your car back, before you get in the car, get down and inspect the retainer. If its still dislodged, raise holy hell about it.
[If you had the recall check done, was it done before or after the ammended recall letter that included a check of the lower column bearing?]
[did the car have a replacement shaft already? My understanding is its a one time deal. If it happens again, its on you].
Alex.
Edited by GM_Guy (07/24/16 10:17 AM)
#3296794 - 07/24/16 11:30 AM Re: Upper Steering Shaft [Re: EZlivin11]
EZlivin11 Offline
My CVPI is listed as no open recalls.
The steering shafts were in sad sad shape when She followed Me Home (looked like they had never been touched), I should have changed the lower shaft before I drove the 300 miles to home :-(.
I need to get the Cruz, DRL, Dark Mode, well whatever can be turned on turned on, so I was going to ask for the inspection then.
I replaced the lower shaft, cleaned and lubed connections and bearings up to the lower output of the column, could that affect if it qualifies or not IDK, but I did read that a owner could put in for reimbursement of prior repairs. I'm sure You need a receipt for said repair, and not having one, I'll go with it was that way when I bought it from the dealer in San Francisco.
That is a very good idea on the retainer, I was going to leave a piece of the green plastic collar on the floor. Worst case is I get a no, and it is on Me. So far Vreeland Ford has been very helpful, heck they deliver to the door. Unlike Santa Maria Ford (I don't ever want to have to go back there) they were very rude when I asked a few questions.
well the tarp is spread, the tools and consumables have been gathered up, so it is about time to get on the flushing of the fluids, and get Her off the stands.
I've been chomping at the bit to get her going, cuz I need to get to LA and visit SocalSam. He Has kindly offered up some goodies that are on My list of good stuff I Need, Want, and Desire. :-) So HiHo HiHo
The Gray Ghost
AKA: The Murranator
#3296802 - 07/24/16 11:49 AM Re: Upper Steering Shaft [Re: EZlivin11]
SocalSam Offline
banned
Loc: SFV, Calif.
Originally Posted By EZlivin11
...I need to get the Cruz, DRL, Dark Mode, well whatever can be turned on turned on, so I was going to ask for the inspection then...
...I've been chomping at the bit to get her going, cuz I need to get to LA and visit SocalSam. He Has kindly offered up some goodies that are on My list of good stuff I Need, Want, and Desire. :-) So HiHo HiHo
Haha, 2008 CVPI mini meet! It will be nice to see what a properly sorted out 2008 is like.
While at the dealer for IDS programming, set Silent Mode to your preference. Mine is set to on for no warning chimes.
2004 CV LX Sport #2
#3296850 - 07/24/16 12:15 PM Re: Upper Steering Shaft [Re: EZlivin11]
EZlivin11 Offline
Looking Forward To It...
The Gray Ghost
AKA: The Murranator
#3297186 - 07/24/16 06:33 PM Re: Upper Steering Shaft [Re: EZlivin11]
This. Its another cvpi feature I didn't know about, but damn glad to have, seeing as I always spend time disabling the stupid things on older cars.
Alex.
#3297418 - 07/25/16 12:04 AM Re: Upper Steering Shaft [Re: EZlivin11]
EZlivin11 Offline
the steering column shaft slide in like butter, intermediate shaft no problem, and then I couldn't find the bolt that locks the lower shaft to the intermediate shaft NO WAY it never fails does it!!! You know it's gotta be here somewhere .LOL
Any She is all together (except 1 bolt) I do have an ABS light on after vacuum bleeding the brakes, so I'll need to connect the scan tool tomorrow. cleaners are in the trans, and power steering and She has been running for awhile, so after the scan I'll finish the flush. Fluids, filter an gasket, and pan with drain plug should be here tomorrow. She is getting close :-)
The Gray Ghost
AKA: The Murranator
#3297754 - 07/25/16 11:22 AM Re: Upper Steering Shaft [Re: EZlivin11]
The anticipation is killing me... biggrin
Seriously, from your pix it looks like you've done really top-notch work and I hope everything comes out great.
#3298970 - 07/26/16 05:45 PM Re: Upper Steering Shaft [Re: EZlivin11]
EZlivin11 Offline
Thanks it has been difficult working in the driveway to say the least. I've been sitting in Her Thinking what is going to be like, cuz She drove so nice before I started changing worn parts, what is the ride going to be now that She is all freshened up and ready for the prom... So close I can taste it LOL' biggrin
The Gray Ghost
AKA: The Murranator
2 registered (GooneyBird, wibiwo), 56 Guests and 11 Spiders online.
