#3401969 - 10/17/16 06:25 PM 17mm to 24mm Rear Sway Bar Bushings
EZlivin11 Offline
Loc: Central Coast Of CA USA
I ordered 21mm ES bushings, when they arrived they are much smaller than the stock bushings so the stock brackets are too big, and the ES brackets too small. Did I get the wrong bushing, or do I need to fab something?
The Gray Ghost
AKA: The Murranator
IF It's Not Broke, It Must Be Time For An Upgrade
2008 Ford Crown Victoria P71 4.6-2v
Upgrades /Mo's /1/2ShaftTB /P&PIntake /Steeda /Steering /Brakes /Suspension /Driveline /Rear-Axle3.55TL /BodySuspension-EnergySuspension /Interior /LTC-Leather /200Amp-Powerdistrabution-System /AuxBattery /SonyBluetooth /
#3402089 - 10/17/16 07:23 PM Re: 17mm to 24mm Rear Sway Bar Bushings [Re: EZlivin11]
chipdog4 Offline
Loc: SouthWest Indiana
It sounds like you got the wrong ones because the rear sway bar bushings don't come with a bracket and the stock one must be reused.
The rears do come with endlinks...
https://www.summitracing.com/parts/ens-4-5171g/overview/make/ford/model/crown-victoria
99 LSE clone
#3402409 - 10/17/16 10:06 PM Re: 17mm to 24mm Rear Sway Bar Bushings [Re: EZlivin11]
EZlivin11 Offline
Thanks for the part number, it is 3 bucks cheaper at amazon
The Gray Ghost
AKA: The Murranator
#3406561 - 10/21/16 10:10 AM Re: 17mm to 24mm Rear Sway Bar Bushings [Re: EZlivin11]
EZlivin11 Offline
Bushings arrived, rear axle is staged, that makes it install day....
The Gray Ghost
AKA: The Murranator
Traffic22 15
