#3541457 - 02/09/17 02:20 PM Alternator issues on going on 09 cvpi
PRT_OMNIPOTENT Offline
Loc: NJ
2009 cvpi is mine with just over 200 k on her
For the last two years or so
I seem to be going through alternators every 6-8 months or so..
Wherein the alternator doesn't completely go bad.
(It isn't shot)
It just begins to whine
But there are times where the whine goes away.
It comes and goes
And since it leaves at times
It doesn't lead me to Believe
it's actully the voltage Regulator.
But even if it is the V.R. why would it go bad every few months..?
#3541969 - 02/10/17 01:09 AM Re: Alternator issues on going on 09 cvpi [Re: PRT_OMNIPOTENT]
stalag Offline
Loc: Columbus, OH
Has the battery been checked?
#3542553 - 02/10/17 04:24 PM Re: Alternator issues on going on 09 cvpi [Re: PRT_OMNIPOTENT]
PB92 Offline
Loc: Communist CT
Are you putting the correct alt on, or an aftermarket high output? Is the charging system factory, or have you modded it at all?
US MARINES Kilo 3/3
Modified factory CAI. Big 4 upgrade, 0 gauge highstrand. High Power Cobra 29 Old school highly tricked out, w/300 watt box. 200 amp alt w/overdrive pulley. New body mounts. Moroso air/oil separator. Rebuilt 8.8 axle. ARA3 PCM. High power CB'er for 35 years.
#3542657 - 02/10/17 05:41 PM Re: Alternator issues on going on 09 cvpi [Re: PRT_OMNIPOTENT]
Check your engine ground (big wire going to the battery).
Quick dirty check if it is a ground issue, clamp one a jumper cable from the battery ground post to the alternator (should have some protrusion on it somewhere, if not, use the bracket. DO NOT allow the clamp to short to the battery stud.
Alex.
#3543177 - 02/11/17 12:05 PM Re: Alternator issues on going on 09 cvpi [Re: PRT_OMNIPOTENT]
Loc: NJ
The battery is a red top optima
I haven't checked the battery
The alternator is a 200 amp high output for the cvpi
So yes the alternator is correct
The charging charging is stock
I never touched it
I will try that ground check
#3543193 - 02/11/17 12:08 PM Re: Alternator issues on going on 09 cvpi [Re: GM_Guy]
Loc: NJ
U don't quite understand
What does this do exactly?
And where exactly do I connect the other end of the jumper cable too?
From the negative batt post to The alternator bracket?
And With or without the terminal removed from the battery post?
And once I do, what exactly does that do and what am I looking for?
#3543321 - 02/11/17 01:20 PM Re: Alternator issues on going on 09 cvpi [Re: PRT_OMNIPOTENT]
He's saying to use one side of your jumper cable, like the black side, to connect between the negative battery terminal and the metal casing of the alternator. Leave the red side of the jumper cables unattached. This will help determine if there is a grounding issue with the battery cable and/or the alternator itself.
No ABS, no RAS, no Traction Control, manual HVAC,
single exhaust, 2.73 open, and an ugly-ass landau roof.
Exactly what I wanted in a DD: simple.
#3546442 - 02/15/17 02:20 PM Re: Alternator issues on going on 09 cvpi [Re: RF_Overlord]
Loc: NJ
How do I connect one end of a cable to 2 different locations?
I have a wire running from the negative battery terminal to the inside of the quarter panel Near the battery.
and I have the other one that runs down to the starter-or in that general direction. there is no cable running off of the negative side of the battery that goes to the alternator.
I'm still confused
Of where to hook it up at
And what I'm looking for and what this test will do when I do.
#3546713 - 02/15/17 05:05 PM Re: Alternator issues on going on 09 cvpi [Re: PRT_OMNIPOTENT]
Your jumper wires, how many ends on each cable? Two.
You take one black one and clamp it to the batter negative post.
You take the other black one, and clamp it to a good ground on or by the alternator. (ie: where the bracket bolts to the alternator, a protrusion on the alternator case itself).
Instant test ground.
Alex.
#3547161 - 02/15/17 11:24 PM Re: Alternator issues on going on 09 cvpi [Re: PRT_OMNIPOTENT]
Loc: NJ
Ohhhhh. So I understand now.
So when I do
That
And start her up
If the whine goes away
It's a bad or dirty ground?
And If it still whines
It's the alternator?
#3548122 - 02/16/17 11:46 PM Re: Alternator issues on going on 09 cvpi [Re: PRT_OMNIPOTENT]
1 Adam 12 Offline
Loc: Glendale, AZ
Yes. Let me ask you a question - are you swapping the same pulley onto each new alternator?
~Chris~
MY ARTICLES
#3551042 - 02/20/17 04:35 PM Re: Alternator issues on going on 09 cvpi [Re: 1 Adam 12]
Loc: NJ
No I'm not.
And I just installed a new alternator
And it does the same whining sh**
Fresh battery
I even cleaned my ground connections at the starter and at the motor.
I'm out of ideas
#3551058 - 02/20/17 04:45 PM Re: Alternator issues on going on 09 cvpi [Re: PRT_OMNIPOTENT]
Loc: NJ
If it's not a ground issue or the battery
Then what is it?
#3551074 - 02/20/17 04:49 PM Re: Alternator issues on going on 09 cvpi [Re: PRT_OMNIPOTENT]
Loc: NJ
I tried to take a picture
But it won't upload
3 registered (OrlandoLTD, Sunfish, CrazyRay), 252 Guests and 10 Spiders online.
BigMerc96 142
a_d_a_m 139
dpk 129
Ponyguy 91
Moby_Vic 81
charlieD 79
RF_Overlord 70
SocalSam 65
Bellwestern80 53
EZlivin11 52
