#3546673 - 02/15/17 05:00 PM Re: coolant keeps spitting out overfl [Re: crownvicfreak]
crownvicfreak Offline
Loc: va
#3546945 - 02/15/17 08:02 PM Re: coolant keeps spitting out overfl [Re: crownvicfreak]
Did you bleed the cooling system? Trapped air has a nasty habit of causing the coolant to bubble out. In theory, it'll work its self out, but you can give it some help by letting it run without the pressure cap on the bottle. You'll see the level rise, possibly overflowing a bit, it'll bubble a lot, then the level will drop. It does this once the thermostat opens and the air can freely move thru the system, it finds its way to the bottle since its the highest point in the cooling system and without the pressure cap to contain it, it'll bubble out. Once the air is worked out, the level will stabilize and you can top it off and hopefully that's the end of it.
Originally Posted By s33k3r
#3547305 - 02/16/17 02:50 AM Re: coolant keeps spitting out overfl [Re: crownvicfreak]
2468 Offline
Loc: Argo Nunya
Never had the spitting coolant, but anytime I did something involving cooling system, I'd do what BigMerc said, but then I'd drive the car till it was op temp. Bring it back to the flight deck, and let it set about 1/2 hr then open the cap on the reservoir, & air could be heard escaping. I'd repeat the process til I heard no more air puffing out.
Owner/Maintainer '92 Crown Vic 'S' Police for last 19 yrs.
#3547489 - 02/16/17 10:31 AM Re: coolant keeps spitting out overfl [Re: crownvicfreak]
2011LX Offline
Loc: Oak Creek, WI
"air" will always escape when the system is hot and the cap is removed - the air space under the cap is pressurized...
That said, you are not purging the system by doing so. These degas systems purge themselves. Playing with the cap (on/off) does absolutely NOTHING.
If you put the cap on AFTER the coolant is hot and has expanded, no pressure will be generated, and no more air will escape. That's why it stops. Not because all of the air is purged. Afterwards, when the coolant cools and contracts in volume, the volume of air that you released when removing the cap is sucked back in through the cap to displace it. Else, the hoses would collapse.
Purging with the cap off is a technique used on the older systems with a recovery bottle - where the pressure cap is on the rad neck. In that case, when the air collects under the cap, there's no way for it to escape unless the system overheats and the cap vent opens to release the excess pressure.
In the degas system, the air that collects at top of the radiator simply migrates up the small purge line on the degas bottle and collects in the air space above the coolant where it's supposed to be, which keeps the rad and the rest of the cooling system air free. The most important feature of this system is that the cap encloses the coolant AND the airspace, rather than the old recovery system that regulated coolant volume directly.
The only 'trick' when purging a degas system is that sometimes some hearty throttle snaps are required to push a stubborn air bubble past an obstruction. The ebb and flow of the coolant will usually push it away.
OP, for some reason, the cap is venting pressure (if I'm understanding "spitting" correctly). Obviously, if the cap is operating correctly, the only reason that could be happening is because the system is at a higher pressure than the 16psi cap rating. I see a few possibilities:
-Overheat. The system pressure is too high (coolant is over temp and has expanded too much, increasing pressure above the cap rating). T-stat installed backwards?
-The coolant level is too high. Remember, the cooling system is a closed system with a constant volume, but the coolant increases volume as it heats. The air space in the tank is a sort of 'cushion' (in laymans terms) for this action. The air space dictated by the markings on the side of the tank is a calculated volume - Liquid coolant is in-compressible, so if there isn't enough air to squeeze, the pressure increases too much and the cap vents before the coolant has reached operating temp. Conversely, if the system wasn't full enough (too much air to absorb increasing coolant volume), pressure would be too low and the coolant would boil early.
- A head gasket breach is allowing compression into the cooling system, raising the pressure, causing the cap to vent.
Else:
-The cap is defective, venting under rating pressure.
currently @ 75k miles
Medium Light Stone interior
#3548170 - 02/17/17 12:14 AM Re: coolant keeps spitting out overfl [Re: 2011LX]
2468 Offline
Loc: Argo Nunya
The way I started that ritual, many years ago, was after I changed coolant... The temp gauge was reading higher than normal while driving. One day after driving, I let it set about 1/2 hr. I took the cap off just to check the mixture. Big puff of air came out, so I put the cap back on & drove it again, & the temp gauge was no longer riding high. I had always thought what I did, was somehow purging air. I've been doing it ever since out of habit.
#3553129 - 02/22/17 01:21 PM Re: coolant keeps spitting out overfl [Re: crownvicfreak]
Loc: va
well i have bleed the system about 4 times, still doing the same thing,
get in it and go stay on cold for about 5mins then start to go straight up to hot, stay at hot for maybe 25sec and gose back to normal temp, and stay there,
then sometimes it will do twice, but then it will go back to normal.
going to install the fan tomorrow,
i dont get it, never did this before.
#3553441 - 02/22/17 04:53 PM Re: coolant keeps spitting out overfl [Re: crownvicfreak]
Bangster Offline
Would have been a very very good idea to include the specs on the car, I was going to ask if it was a pre 1998, but the thread got screwed up with the db issue.
1974 Honda cb400
#3553489 - 02/22/17 05:27 PM Re: coolant keeps spitting out overfl [Re: crownvicfreak]
If the temperature is pegging then dropping like that, then there is air in the system somewhere.
#3553537 - 02/22/17 05:55 PM Re: coolant keeps spitting out overfl [Re: crownvicfreak]
Loc: va
its a 95 crown vic,
iv bleed it about 4 times now, tomorrow going to check for leaks and play in the water pump, and reinstall the fan,
just blows my mine, it wasnt doing this before the tear down,
#3553633 - 02/22/17 07:37 PM Re: coolant keeps spitting out overfl [Re: crownvicfreak]
2468 Offline
Loc: Argo Nunya
I read some things about overflow loss in an old maintenance book... Faulty cap; over filling; blown head gasket; or coolant foaming.
#3554225 - 02/23/17 02:17 PM Re: coolant keeps spitting out overfl [Re: crownvicfreak]
Loc: va
ok guys,
got the fan back in, still no change
the engine was warm not cold it started pouring water out the overflow cap, did this twice and it stopped,
you can watch the water get sucked in and 1 to 2 sec later you can see it fill the overflow to the full mark, and stayed, let it idle for about 30-45mins and the gauge went to the top of the temp icon to the bottom of the icon, heat was great,
is the cooling system suppose have pressure all the time??
while it was hot and running i could pull the cap off the overflow with no pressure what so ever is this right?
#3554241 - 02/23/17 02:27 PM Re: coolant keeps spitting out overfl [Re: crownvicfreak]
You can buy a kit that tests for the presence of exhaust gasses in the coolant at most FLAPS. Might be worth it for the peace of mind, but it still sounds like an air bubble to me...
No ABS, no RAS, no Traction Control, manual HVAC,
single exhaust, 2.73 open, and an ugly-ass landau roof.
Exactly what I wanted in a DD: simple.
#3554321 - 02/23/17 04:15 PM Re: coolant keeps spitting out overfl [Re: crownvicfreak]
09P71VIC Offline
Loc: Kansas
Did you use factory torque specs? I had to retorque mine after I drove it.
2009 CVPI - 125,500 miles
Former Kansas Patrol Car, Unit 929
#3554361 - 02/23/17 05:31 PM Re: coolant keeps spitting out overfl [Re: crownvicfreak]
Loc: va
yes, when we tore it apart the intake bolts were only hand tight
#3560025 - 03/01/17 01:11 PM Re: coolant keeps spitting out overfl [Re: crownvicfreak]
Loc: va
well its still doing it.
im at a lost,
3 registered (LSE_Dave, PixFixerGuy, guzzilapd), 25 Guests and 87 Spiders online.
a_d_a_m 227
BigMerc96 140
EZlivin11 103
Chaplian 100
RF_Overlord 96
dpk 93
Ezbok58a 90
Ponyguy 86
Moby_Vic 83
