#3542585 - 02/10/17 04:59 PM Rear Main Starving of Oil
Nebula7 Offline
Loc: Southern, OR
I have a 2003 MGM 290,000mi, and have an issue with the rear main starving of oil. I have replaced the PCV valves, and they are free, I have done oil changes every 5k since 40k, and very picky about maintenance.
I noticed when I remove the oil cap, the sound goes away, and only does it when below 1,200rpm. I've been running a K&N crank case breather on place of the oil cap, as a band aid. It has solved the issue, but now leaks oil through the filter when I get on it, allowing oil all over the passenger side valve cover, so I'd like to fix the issue. This problem doesn't seem very common.
I'm at a bit of a loss, and wondering if anyone has clues?
2003 MGM LS. 290,XXX miles
Mods: TR3650, 70mm BBK TB, ADTR Ported Polished Plenum, Dual H-Pipe Conversion, Heinous Rear Control Arms, Gas-A-Just shocks, BH1976 Relay Upgrade 55/100W, 3L27 31 spline axle rebuild, 04 P71 Zip/Airbox 80mm MAF, Mo's Speed Shop Tune.
#3544674 - 02/12/17 10:02 PM Re: Rear Main Starving of Oil [Re: Nebula7]
85ltdcrownvic Offline
Loc: Naples, Fl
Have you done a compression test?
#3544714 - 02/12/17 10:19 PM Re: Rear Main Starving of Oil [Re: Nebula7]
Nebula7 Offline
Loc: Southern, OR
The last compression test was done in 2014, and I had 110-130 in all cylinders (lowest cylinder 8). I haven't done one since 2014 (248k), but I was going to do one on my F150 soon, so it'd be a good time. I just need to figure out how to get a coil out on cylinder #1, as the bolt just spins... I can update as I do the test.
#3546513 - 02/15/17 03:51 PM Re: Rear Main Starving of Oil [Re: Nebula7]
2468 Offline
Loc: Argo Nunya
How's your oil pressure? Could the pump be below par?
Could there be any clogged passages? What about a clog at the pick up screen? My Buick started knocking & I found the pickup screen was clogged with debris from an internal nylon plastic part that shredded.
When I read about the band aid fix, I initially thought about a CCV problem, maybe from a collapsed or clogged hose, but your not getting oil coming out anyplace besides the breather you're using for the oil cap, are you?
With the lack of lubrication, are you sure you want to be driving it?
Owner/Maintainer '92 Crown Vic 'S' Police for last 19 yrs.
#3546985 - 02/15/17 08:09 PM Re: Rear Main Starving of Oil [Re: Nebula7]
AFAIK unless there is a oil galley blocked in the bottom end of block you can't starve one bearing of oil... If it pushing oil out the breather, then engine is just likely tired and has a blow by issue...
1998 Grand Marquis LS. 76K mi.
2007 Grand Marquis GS. 77K mi.
#3547257 - 02/16/17 02:05 AM Re: Rear Main Starving of Oil [Re: GrandMarq9807]
2468 Offline
Loc: Argo Nunya
That thought crossed my mind. Was wondering what led to determining it is just the rear main.
#3547449 - 02/16/17 09:47 AM Re: Rear Main Starving of Oil [Re: 2468]
If oil pressure was so low/restricted it was starving a main bearing the rods would have been burned up long ago, as oil feeds to mains then to rods... Imaginary problem... Or at least a incorrect diagnosis...
#3548202 - 02/17/17 01:08 AM Re: Rear Main Starving of Oil [Re: GrandMarq9807]
2468 Offline
Loc: Argo Nunya
I'm under impression OP hears the bottom end knocking, maybe?
#3548234 - 02/17/17 03:05 AM Re: Rear Main Starving of Oil [Re: Nebula7]
Nebula7 Offline
Loc: Southern, OR
It's not knocking. It's a peculiar sound, kind of like an old dryer. It has a squeal that doesn't go away unless above 1200rpm, and comes from the bottom end, towards the rear of the engine.
It is possible, an oil gallery is plugged due to the one guide breaking off in the past.
The tab above my finger (bolt) is the only piece to be in the pan. The passenger side was fine.
I don't know if it's blow by, but I run a vacuum gauge while driving, and the readings from 1200ft have not changed any bit since 5yrs ago.
I haven't gotten around to the compression check due to excessive rain, I will update with numbers when I can.
#3548242 - 02/17/17 07:00 AM Re: Rear Main Starving of Oil [Re: Nebula7]
I dunno what the problem is but it is NOT a main bearing, a squealing main bearing would destroy itself in just a few seconds...
As long as a engine has fairly even compression on all cylinders actual numbers don't mean much for vacuum... On my Comet vacuum was steady and easily pulled 18-20" but due to to someone installing later, big chamber heads, only regestered 95-110 psi cranking...
#3548410 - 02/17/17 11:53 AM Re: Rear Main Starving of Oil [Re: Nebula7]
Black_Sunshine Offline
Could the sound be the torque converter and not the motor?
75mm DBW TB
� hood ornament
� c-pillar emblems
� LS style body side moldings
CarDomain
Facebook
#3548690 - 02/17/17 04:37 PM Re: Rear Main Starving of Oil [Re: Black_Sunshine]
Nebula7 Offline
Loc: Southern, OR
It's a 5spd.
#3549250 - 02/18/17 10:08 AM Re: Rear Main Starving of Oil [Re: Nebula7]
PHoganDive Offline
Loc: Mass, USA
If it is leaking oil out the breather when you get on it, that indicates you have a lot of blow-by from the piston rings, which is pressurizing the crankcase when you get on it, and venting out the breather/filter, along with any oil in the filter. Your sig says the car is leaning on 300K miles, so it's entirely possible the piston rings are simply worn out.
The PCV system handles normal blow-by, but in your case it looks like the amount exceeds it's capacity, and the excess goes out the vent cap when the motor is under load.
#3549570 - 02/18/17 08:52 PM Re: Rear Main Starving of Oil [Re: PHoganDive]
Nebula7 Offline
Loc: Southern, OR
If this is true, why is it making a horrible squealing sound with the regular oil cap on at idle? Shouldn't the PCV valves take care of this? Also, if it were blow by, wouldn't my seals be seeping oil everywhere? My engine is bone dry everywhere. Finally, what would cause a squealing sound in the bottom of the engine, at the back, in the first place?
Lets say my rings are toast, and I do have blow-by. Still what I'm wondering is what would cause a loud squeal at idle with the regular cap.
Edited by Nebula7 (02/18/17 08:56 PM)
#3554345 - Yesterday at 05:26 PM Re: Rear Main Starving of Oil [Re: Nebula7]
Nebula7 Offline
Loc: Southern, OR
Just did the compression
1-165
2-155
3-156
4-155
5-160
6-158
7-160
8-160
I don't believe it's blowby...
11 registered (charlieD, casey67, 2004_p71, 97Aero, Bull, 1 invisible), 93 Guests and 83 Spiders online.
Moby_Vic 189
a_d_a_m 159
BigMerc96 138
Chaplian 112
EZlivin11 111
White99MGM 109
DudeAbides 95
charlieD 89
RF_Overlord 86
SocalSam 83
