#3497874 - 01/05/17 10:45 PM Pi Swap Check Engine Light
JLewis59 Offline
Loc: Plymouth, Ohio
I have a 2000 Grand Marquis, and not so long ago did a pi head and intake swap. Since then, the check engine light has been on. I got it scanned at auto zone, and they said the code was saying it was running rich in one of the banks. Before I did the swap there was no check engine light and no problems, theres also no problems now except whenever i start the car in the cold, if I dont let the engine get warmed up for about 15 minutes the car will stall if i put it in drive or reverse. I was wondering what this problem could be? Everything was fine before the swap and now the light is on and it;s bothering me. Thanks for any info on this.
2000 Mercury Grand Marquis - 80,000 Miles - Pi Head and Intake Swap, Directed Audio and Alpine Type R 12 inch subs
#3498162 - 01/06/17 12:38 AM Re: Pi Swap Check Engine Light [Re: JLewis59]
85ltdcrownvic Offline
Loc: Naples, Fl
It sounds like a combination of a bad iac and vacuum leak on only one bank. Pull the manifold and put new rtv around the ports and check the iac by unplugging it while idling to see if it makes a difference.
#3547153 - 02/15/17 10:58 PM Re: Pi Swap Check Engine Light [Re: 85ltdcrownvic]
JLewis59 Offline
Loc: Plymouth, Ohio
I was told to check for a vaccum leak i could spray starting fluid around the intake and whatnot and if i hear a rise in rpms then it means i have one. Would you say thats where i should start? Also we put injectors in the were bigger then the stock one which we got from a junk yard, but we tested them and they seemed to be working. COuld that cause the problem? Maybe one it sticking or has an unsual spray pattern? Thanks
#3547658 - 02/16/17 01:09 PM Re: Pi Swap Check Engine Light [Re: JLewis59]
casey67 Offline
Loc: Lemont,IL
Do not use starting fluid- way too toxic and flamable.
Use carb cleaner - the engine could run on it-it will find a vacuum leak.
On a stock engine, 2 reasons for running rich are the fuel pressure regulator ( pull the hose off when cold-turn key on-see if fuel leaks)
And Mass air flow sensor (MAF) try cleaning it with throttle body cleaner.Make sure to let it dry well.
08 CVpi
#3548178 - 02/17/17 12:19 AM Re: Pi Swap Check Engine Light [Re: JLewis59]
stalag Offline
Loc: Columbus, OH
For the MAF I would only use electronics cleaner. The solvents in carburetor cleaner and starting fluid both melt plastic and will foul the MAF sensor by coating that little thin wire that reads the air flow with the dissolved plastic. In fact if you intent on using carb cleaner/starting fluid it is highly recommended you spray that only into the throttle body itself and not the air tube or air box. In a modern computer controlled car though the use of starting fluid should never be needed. Diesels may require starting fluid when in subzero temperatures due to the way fuel is ignited in a diesel.
#3548298 - 02/17/17 08:37 AM Re: Pi Swap Check Engine Light [Re: JLewis59]
mdnos Offline
Loc: not here any longer
The larger injectors may be causing too much fuel to be dumped in causing a rich condition..I don't believe you can just put a larger injector in when the pcm is calibrated for another size.
#3548386 - 02/17/17 11:20 AM Re: Pi Swap Check Engine Light [Re: JLewis59]
BigNSlow Offline
Aussie powered
Loc:
Sounds like you got vacuum leak on one side of the intake. How long did you wait for the RTV to dry before running the car? What gaskets did you use?
Also put stock injectors back on. Your fuel table is off.
Edited by BigNSlow (02/17/17 11:21 AM)
1985 Grand Marquis
2002 Volvo V70
#3548482 - 02/17/17 01:34 PM Re: Pi Swap Check Engine Light [Re: JLewis59]
Bangster Online   content
Why RTV? with PI heads and PI intake, no mismatch.
I second going back to the original injectors.
00 Grand Marquis LS Premium - 97 Cougar 4.6 Sport - 89 Cougar LS - 63 Falcon 302 - 82 F-150 - 97 Mark VIII LSC - 2017 Escape SE
#3548722 - 02/17/17 04:40 PM Re: Pi Swap Check Engine Light [Re: JLewis59]
BigNSlow Offline
Aussie powered
Loc:
Sorry, musta missed the head part. Yea, no need for RTV then.
1985 Grand Marquis
2002 Volvo V70
#3563257 - 03/04/17 10:46 PM Re: Pi Swap Check Engine Light [Re: BigNSlow]
JLewis59 Offline
Loc: Plymouth, Ohio
Alright so i went back to the original injectors and notices something that seemed very odd. I have a vacuum line that is hooked up to a stud on my intake i believe. For some reason i don't think that's where it should be at, and was wondering what everyone thought. The only problem is i don't see where else it'd go seeing as how short it is and how it fits exactly on the bolt. Also, there is a vacuum line that has two ends on it, ones longer than the other to hook on what i believe to be some sort of sensor, and where it hooks up at there is one short and one long little spot to hook up bu it seems the small end of the line isn't staying in place well. Any thoughts?
#3563601 - 03/05/17 10:31 AM Re: Pi Swap Check Engine Light [Re: JLewis59]
Are you talking about this ground wire? Disregard the way the heater hose is on there, the heater is bypassed.
Is this the "sensor" with the two hard vacuum lines? Green goes to the top if that helps.
#3564025 - 03/05/17 06:36 PM Re: Pi Swap Check Engine Light [Re: JLewis59]
That "sensor" is the EGR vacuum solenoid. If you follow the 2 lines going into it, one will come off the plenum, the other goes to the EGR. Its job in life is to control how much vacuum pressure goes to the EGR diaphragm thus controlling how much the EGR opens.
1998 Mercury Grand Marquis LS HPP ~92k miles, not entirely stock.
1997 Town Car Cartier ~143k miles, 70mm TB, Ported Plenum, Gutted Airbox, Mechanical Fan Delete, Contour E-fan Retrofit, Dual exhaust with Magnaflows, rear cat delete, MSD Ignition, KYB Gas-A-Justs, Marauder/HPP rear sway bar, P71 front bar, air ride reinstated, Blinker Mod, Projector retrofit, Caddy 4-note horn retrofit, Wood rim steering wheel retrofit, natural weight reduction.. Smashed 1/13/13....I fixt it..
#3564169 - 03/05/17 08:29 PM Re: Pi Swap Check Engine Light [Re: Bangster]
JLewis59 Offline
Loc: Plymouth, Ohio
Alright so that is a ground then, and yes thats the sensor i can't remember if i had green on top or not, ill check tomorrow but however i had it it seemed like the green wouldnt stay on, like the sensor didnt have enough of a little tube for it to slide on to and hold it on.
#3564737 - 03/06/17 10:37 AM Re: Pi Swap Check Engine Light [Re: JLewis59]
I also found you want to swap in a 2001-2002 style MAF, even when using the stock 70 mm style. I did notice a change vs my old 96 MAF
NPI style MAF from my 96 Town Car
PI Style MAF from a 2002 Town car
My PI swap 96 Town car ran better with the 2002 MAF still using the stock 96 tune
#3565057 - 03/06/17 02:06 PM Re: Pi Swap Check Engine Light [Re: Bangster]
JLewis59 Offline
Loc: Plymouth, Ohio
Here you can see the green vacuum line seems like it's too short. It just kinda slides off if i push it on all the way.
[img]https://www.flickr.com/photos/152723605@N07/32907433550/in/dateposted-public/[/img]
Edited by JLewis59 (03/06/17 02:07 PM)
4 registered (Lincoln_GTC, WWR_CVPI, BrianDye, hairy_paperclip), 266 Guests and 10 Spiders online.
a_d_a_m 164
dpk 153
BigMerc96 130
Moby_Vic 112
WSTRLNG 88
reminc70 79
Ponyguy 78
RF_Overlord 67
Bellwestern80 57
SocalSam 48
