#3559385 - 02/28/17 08:45 PM How to test voltage regulator/slip rings
98BoatCaptain Offline
Loc: Albuquerque NM
I've had an intermittent Battery light (and occasionally the voltage needle will dip low for a bit) for a week or so.
Signs seem to point to a possibly bad voltage regulator.
One of the service manual tests is to measure resistance between both alternator slip rings (field and B+, I assume) to see whether the voltage regulator is bad.
It looks like I'll have to pull the alternator and take the back cover off to do this test.
Do I have that right?
1998 Mercury Grand Marquis LS
196k miles, many bits & pieces replaced, Peelformance White frown
Relay headlight harness & turbo encabulator
#3560601 - 03/02/17 04:22 AM Re: How to test voltage regulator/slip rings [Re: 98BoatCaptain]
PHoganDive Offline
Loc: Mass, USA
It may be the brushes are stuck/worn, and not making steady contact with the slip rings. If the slip rings are OK, you can just swap the regulator/brush assembly.
#3560977 - 03/02/17 03:52 PM Re: How to test voltage regulator/slip rings [Re: 98BoatCaptain]
Loc: Albuquerque NM
I'll find out soon, possibly tonight. If indeed the brushes are worn, fortunately I can swap those out separately.
Be nice if that's all it is - new brushes are only about $10 shipped, vs. ~$50 for a new VR.
#3561225 - 03/02/17 11:08 PM Re: How to test voltage regulator/slip rings [Re: 98BoatCaptain]
Loc: Albuquerque NM
Brushes look fine.
I tried to test the slip rings, but the procedure in the service manual makes no sense. It says to check resistance between each slip ring and the alternator case.
I get an open circuit reading (no ohms) on both slip rings, at all settings of the multimeter. It's supposed to read at least 200 ohms, else you need a new alternator.
WTF? How is my alternator working at all? Which it does, because I can measure a good 14.something volts at the battery's positive terminal with the engine running.
Edited by 98BoatCaptain (03/02/17 11:14 PM)
#3561329 - 03/03/17 02:23 AM Re: How to test voltage regulator/slip rings [Re: 98BoatCaptain]
fordoldfart Offline
Loc: kansas
You want an open between the slip rings and the case. Depending on the amperage rating of the alternator you want from 1 to 3 ohms resistance from slip ring to slip ring. This testing can be done with just the voltage regulator / brush block removed. If this unit has 150,000 miles or more usually you will see one slip ring with a pretty deep groove and short brushes. A bad diode can turn on the battery light on but it is usually on permanently.
#3561537 - 03/03/17 09:20 AM Re: How to test voltage regulator/slip rings [Re: 98BoatCaptain]
EZlivin11 Offline
Loc: Central Coast Of CA USA
+1^^^ Wear on the slip rings being the #1 issue with 150k. A bad diode would cause a battery drain with KOEO also.
The Gray Ghost
AKA: The Murranator
IF It's Not Broke, It Must Be Time For An Upgrade
2008 Ford Crown Victoria P71 4.6-2v
Upgrades /Mo's /1/2ShaftTB /P&PIntake /Steeda /Steering /Brakes /Suspension /Driveline /Rear-Axle3.55TL /BodySuspension-EnergySuspension /Interior /LTC-Leather /200Amp-Powerdistrabution-System /AuxBattery /SonyBluetooth /
#3561721 - 03/03/17 10:46 AM Re: How to test voltage regulator/slip rings [Re: 98BoatCaptain]
Loc: Albuquerque NM
OK. Then either the service manual is wrong, or I'm reading it wrong. So what is the book talking about with the "at least 200 ohms from slip ring to case" thing? I'm referring to Pinpoint Test F5 from the charging system section.
Either way, it sounds like my alternator is fine. Open circuit between each slip ring & case. Resistance between slip rings was, as you say, a few ohms. I'm sure I have the regular 130 A unit, given it's a standard '98 Grand Marquis.
I'm not 100% sure how many miles are on this particular alternator. It is a Motorcraft unit, but has a "Remanufactured" label. Must have been installed some time before I got the car, at 60000 miles.
The slip rings looked decent. No uneven wear. Brushes were the same length (judging by the holes in them) and had a healthy amount of springiness, so it seems likely they're making smooth even contact when in use.
So...still don't know what the actual problem is.
Thanks guys!
#3581089 - 03/20/17 09:30 AM Re: How to test voltage regulator/slip rings [Re: 98BoatCaptain]
Loc: Albuquerque NM
Any further thoughts on this?
The red "charging problem" light keeps illuminating intermittently. It'll stay on for maybe a minute or so max, sometimes just 10 seconds or so (can't really time it, busy driving!).
Every time I've looked lately, the voltage needle stays planted solidly in the middle of the gauge's range, so I don't think there's an actual charging problem. Light does not react according to engine rpm - it'll stay on either at idle or WOT, when it comes on.
I think my battery is fine, based on measuring voltage when off, BUT planning to stop by a VatoZone soon to get a second opinion.
Scratching my head otherwise. I've basically done everything the shop manual recommends for an intermittent charging light, short of replacing parts. At ~$50 for a voltage regulator and north of $100 for a reman'd alternator, I don't really care to take the "reconnaissance by parts replacemnet" approach.
#3581281 - 03/20/17 01:08 PM Re: How to test voltage regulator/slip rings [Re: 98BoatCaptain]
McVic Offline
Loc: SC
Following. Welcome to the 1998 intermittent voltage regulator fails! Been going through this ever since my car hit around 150k and changed the regulator once. My problem isn't quite like yours though. Every once in a blue moon mine doesn't charge upon cranking and the battery light comes on. Nothing remedies this but shutting the engine back off and cranking it again, then it's fine. A couple of times voltage went way above what it should.
I just watch that gauge like a hawk now. It's all I know to do.
1998 P73, CAI, PI Intake, Dual Exhaust w/Glasspacks, 18" Mustang GT Wheels w/Pirelli PZero Nero. Painted Black. SOLD! 4/16/17 :-(
1998 Expedition XLT, 4.6, 2WD, GAMECOCK RED, too many options to list, Bone Stock (for now)
#3581497 - 03/20/17 04:31 PM Re: How to test voltage regulator/slip rings [Re: McVic]
Loc: Albuquerque NM
Well, we'll see what Vatozone says about the battery.
If the battery is indeed in good health, I guess a VR swap would be the less expensive option.
Now that I've had Mr. Alternator out and apart once, it's not a huge deal to do it again.
I have to replace the tolerance ring anyway. Broke that sucker real good on the first try at getting to the slip rings & brushes.
I don't seem to have any actual charging problem, though. There have been one or two times the volt needle wandered low when the light was on. But as I said, it stays in the "normal" indication mostly. A multimeter confirms proper output at the alternator B+ terminal, so yeah, I'm not sure what to think.
eta:
guy at the bottom of this thread:
http://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=1076218
seems to have a similar issue.
Edited by 98BoatCaptain (03/20/17 04:37 PM)
#3581625 - 03/20/17 07:26 PM Re: How to test voltage regulator/slip rings [Re: 98BoatCaptain]
It seems that this is common on these early 6G alternators. Wonder why? I've seen the battery light come on for a few seconds twice now in my '98. It comes on just long enough for me to notice it, then it goes out. Not sure what to make of it, car only has 90k miles, but after 19 years I'm sure the alternator could use some freshening. then again, I have a functional 3G on the shelf in my garage, I could just retrofit that, the 3G is a great alternator even if it is less efficient.
1998 Mercury Grand Marquis LS HPP ~92k miles, not entirely stock.
1997 Town Car Cartier ~143k miles, 70mm TB, Ported Plenum, Gutted Airbox, Mechanical Fan Delete, Contour E-fan Retrofit, Dual exhaust with Magnaflows, rear cat delete, MSD Ignition, KYB Gas-A-Justs, Marauder/HPP rear sway bar, P71 front bar, air ride reinstated, Blinker Mod, Projector retrofit, Caddy 4-note horn retrofit, Wood rim steering wheel retrofit, natural weight reduction.. Smashed 1/13/13....I fixt it..
#3582065 - 03/21/17 10:29 AM Re: How to test voltage regulator/slip rings [Re: 98BoatCaptain]
Loc: Albuquerque NM
My alternator is "remanufactured" according to a sticker on it.
I don't know exactly when it was replaced. Some time before 60k miles, because that's when it became my car.
Since I haven't had any actual charging problems yet, maybe this is just something I'll learn to live with. >$100 for a reman replacement alternator is a bit rich for fixing a seeming indicator-only problem.
#3590138 - 03/29/17 09:39 AM Re: How to test voltage regulator/slip rings [Re: 98BoatCaptain]
Loc: Albuquerque NM
OK, I'm seeing semi-frequent excursions into definite "battery discharging" territory.
That's bad juju. No good at all if I'm going to be driving a long ways.
I didn't plan to drop the $ this month, but I'm realllly close to just going ahead and ordering a quality remanufactured alternator. Easier to just swap the whole works.
One thing though: WTF is up with the seemingly 2 different parts for the same model year car?
I'm seeing some part numbers referring to stuff like:
"Fits130 Amp; To 12/20/98
Or 130 Amp; Before 12/20/98; Retail
Or 130 Amp; Retail"
My '98 MGM was built in May 1998, so presumably I'd need the "before 12/20/98" model. But also I'm not seeing what could be different between the two types that would matter.
Edited by 98BoatCaptain (03/29/17 09:44 AM)
#3590634 - 03/29/17 05:30 PM Re: How to test voltage regulator/slip rings [Re: 98BoatCaptain]
I wondered the same thing as well. I looked up a replacement alternator for my '98 at AutoZone and saw the same thing, but I'm pretty sure the option was "fleet" and "non-fleet". Looking at the pictures, one was definitely a 130a 3G, the other was the 6G. No '98+ Panther had a 3G alternator, so IDK what source that info came from but its not uncommon to see weird stuff like that in parts catalogs. I've also seen the 4G listed for a '98 which is incorrect, all '98s had the 130a 6G. '99 civilian cars would have had a 4G, but like how all '96-'97 had the 130a 3G, all '98s have the 130a 6G.
#3591418 - 03/30/17 10:44 AM Re: How to test voltage regulator/slip rings [Re: 98BoatCaptain]
Loc: Albuquerque NM
ooookayyy...clear as mud!
Now that I look at Rockauto's catalog again, it is ONLY the Motorcraft new or reman'd alternators that make the date distinction I mentioned.
So I'm thinking that it is a distinction only relevant in a marketing sense. That is, it's the exact same part, just one version was used in fleet vehicles, another in non-fleet, or something to that effect. Similar to how many Motorcraft parts have a one-letter-different engineering number for the parts put in at the factory, vs. equivalent replacement part that you and I can buy.
1 registered (merk44z), 230 Guests and 15 Spiders online.
a_d_a_m 167
dpk 155
BigMerc96 128
Moby_Vic 114
WSTRLNG 85
reminc70 78
Ponyguy 75
RF_Overlord 65
Bellwestern80 58
SocalSam 48
Osu
Osu
