#3581481 - 03/20/17 04:25 PM How do I remove this S spring in my differential
xcopkar Offline
Loc: Il
What is this S spring on my CVPI differential and how do I remove and reinstall it? I can't pull it out with vise-grips. Is a special tool needed?
Thank you.
[img][IMG]http://i1305.photobucket.com/albums/s553/whackenputter/S30A0022_zpsjqrop8ec.jpg[/img][/img]
2009 B/W CVPI trac lock, license NOTAKOP
2007 B/W CVPI, license XCOPKAR
#3581513 - 03/20/17 05:00 PM Re: How do I remove this S spring in my differential [Re: xcopkar]
charlieD Offline
Loc: right next to Motown
Check you You Tube, a bunch of video's on how to do it.
Ironhead Charlie
'06 P71 3.55LS, "The Black Mariah" Winner of the Electoral but not Popular vote of the December 2016 POTM...
Now parked awaiting the 5 speed swap and some other goodies
'90 Saab 900 spg "The Swedish Meatball"
'01 Honda Civic Coupe, no name daily driver
'74 Harley Davidson Ironhead Sportster "El Diablo Rojo"
'98 Harley Softail Custom
#3581521 - 03/20/17 05:10 PM Re: How do I remove this S spring in my differential [Re: xcopkar]
That spring is what pushes the clutch packs together to provide the "posi" function of a Trac-Lock diff.
No ABS, no RAS, no Traction Control, manual HVAC,
single exhaust, 2.73 open, and an ugly-ass landau roof.
Exactly what I wanted in a DD: simple.
#3581537 - 03/20/17 05:33 PM Re: How do I remove this S spring in my differential [Re: xcopkar]
xcopkar Offline
Loc: Il
Thank you for the advice.
#3581545 - 03/20/17 05:44 PM Re: How do I remove this S spring in my differential [Re: xcopkar]
Are you replacing the clutches in it?
Originally Posted By Gale Banks
Have you ever test drove a Crown Vic? It’s like driving your grandmother’s living room and it handles about as well.
#3585074 - 03/24/17 09:30 AM Re: How do I remove this S spring in my differential [Re: xcopkar]
xcopkar Offline
Loc: Il
I thought I had to remove the S spring to remove the C clips that hold my axles in place. It turns out I had to loosen the magnetic sensors by the tone ring. That allowed the axles to go in far enough that I could remove the C clips.
#3587362 - 03/26/17 09:34 PM Re: How do I remove this S spring in my differential [Re: RF_Overlord]
PHoganDive Offline
Loc: Mass, USA
The "S" spring only provides a bit of initial preload. Under high power, the lions share of the locking force is applied by the spider gears. The angle on the face of the gear teeth tries to force the gears apart, this separating force increases with load (torque) and is applied to the locking clutches (in addition to the S spring force). Note that this also means the locking force increases with applied power, so the wheels will be locked together much harder under throttle, than when coasting or light power.
Under heavy throttle, over 95% of the locking force comes from the spider gears, not the "S" spring.
#3587698 - 03/27/17 06:38 AM Re: How do I remove this S spring in my differential [Re: xcopkar]
xcopkar Offline
Loc: Il
Thank you for the explanation.
#3587866 - 03/27/17 12:15 PM Re: How do I remove this S spring in my differential [Re: xcopkar]
Yes, thanks...I knew the spring alone couldn't be enough...
9 registered (a_d_a_m, GM_Guy, 2004_p71, RedPanther26, DudeAbides, 1 invisible), 270 Guests and 9 Spiders online.
a_d_a_m 170
dpk 155
BigMerc96 124
Moby_Vic 113
WSTRLNG 86
reminc70 78
Ponyguy 75
RF_Overlord 65
Bellwestern80 59
SocalSam 48
