Page 2 of 3 < 1 2 3 >
#2713229 - 05/24/13 11:11 AM Re: New Torque Converter install cost ? [Re: tsg]
4-door Cobra
Originally Posted By: tsg
AllData showing 5.4 hours to R@R the converter. Hope that helps
Ouch...it does help give Mike a better idea but it certainly doesn't help his wallet!
2004 Ford Crown Victoria - Police Interceptor
4.6L Terminator DOHC | 3.4 Whipple | T56 Magnum | 3.55 RAR | etc.
Build thread: CNGInterceptor's official Cobra conversion thread
Or you can follow the build on Instagram @cnginterceptor
1972 Ford Galaxie 500
2004 Ford Crown Victoria LX
#2713239 - 05/24/13 12:01 PM Re: New Torque Converter install cost ? [Re: 2011P7E]
With supplies and stuff, that'd probably be in the neighborhood of $500 for installation.
Which, really... isn't that terrible.
Originally Posted By: etcv97
#2713292 - 05/24/13 02:43 PM Re: New Torque Converter install cost ? [Re: 2011P7E]
Mrvic2004 Offline
Loc: Kansas City, MO
$450 here in Kansas City last time I checked.
#2713528 - 05/24/13 11:37 PM Re: New Torque Converter install cost ? [Re: 2011P7E]
2011P7E Offline
Loc: At your local Dunkin Donuts
Thanks everyone for the help ! Looks like I might just do the gears first, and get the new TC done at a later date.
2014 Police Sedan 32,000 miles ecoboost engine
Past:
2011 P7B Silver Birch 175,000 miles ADDCO front and rear sway bars (totaled)
2011 P7E Black 4.10 gears, BOC Tune, some extras ( took back at 47,000 miles )
2007 P71 Smokestone Metallic JModded ( traded with 150,000 miles )
2005 P74 Arizona Beige (traded with 55,000 miles)
2000 P71 Deep Wedgewood Blue (traded with 140,000 miles)
#3611930 - 04/17/17 02:01 AM Re: New Torque Converter install cost ? [Re: 2011P7E]
bigROC209 Offline
Loc: Stockton, CA
Does the spline count on a torque converter make a difference?
All I'm seeing for 4R70W torque converters are 31 spline but If I'm not wrong my car is a 28 spline.
I'm also seeing that some of the TC's are listed at 12.75 inch diameter with a 11.5 inch bolt pattern.
Does a P71 have a 11.25 inch "diameter" or 11.25 inch "bolt pattern" torque converter?
2002 Marquis LS Precision Trac, new engine @ 125K, GT Wheels, HP tires, SCT Xcal 2, 91 Octane tune from BOC, Traction Locker w/Ford Racing clutches, 3.55's, Police D/S, Ford Racing IM @114K, 75mm TB, Trick Flow Plenum, Ziptube, GT MAF, P71 Rear Coils, Summit Racing UDP's, HPP Sway Bar, Gas KYB's, J-Mod, 2-1/4" Dual Exhaust, Thrush Glasspacks & 18" tips, MSD COPs, NGK TR55's & Grey Injectors, Pinstripe removed, Disc changer, Koiler amp, Kicker Comp CVR 10" subs.
#3612482 - 04/17/17 06:13 PM Re: New Torque Converter install cost ? [Re: bigROC209]
09mnsp Offline
Loc: Minnesota, U.S.
What converter are you looking at? as far as I know the spline count on all 4R70W,75W,75E is the same. The "12.75" and "11.25" is referring to the diameter of the converter.
09 P71
Custom tubular rear control arms by Tink, Detroit Trutrac/Motive 4.30, J-modded, Circle D multi disc 3600-3700 stall, OBX LT's and 2.5" X-pipe, 2.5" Dynomax ultraflows into 3" mandrel bent tail pipes, HI Tech stage2 cams, Dragon Oval Plenum/60mm GT500 TB, Steeda Underdrives, Dyno Tuned By APSAutoworks 281rwhp/297rwtq
#3612506 - 04/17/17 06:42 PM Re: New Torque Converter install cost ? [Re: 09mnsp]
bigROC209 Offline
Loc: Stockton, CA
Here's one I was looking at:
http://www.ebay.com/itm/4R70W-Torque-Converter-Ford-F150-AODE-4R75-2200-2600-HIGH-STALL-94-10/201865239181?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D2%26asc%3D43252%26meid%3D10cdada2ddf34a58a39dc8f20959353f%26pid%3D100033%26rk%3D2%26rkt%3D8%26sd%3D131473539921
The reason the spline count caught my attention is because I remember when I was shopping for my traction locker and gears there were options for 31 & 28 spline setups. Mine is 28 spline. Obviously, I have no clue whether or not this has anything to do with the spline count on the TC.
Thanks
#3612882 - 04/18/17 06:07 AM Re: New Torque Converter install cost ? [Re: bigROC209]
PHoganDive Offline
Loc: Mass, USA
Thanks
The different spline count (28 vs 31) has to do with the rear axles, and has nothing to do with the splines on the torque converter.
#3614762 - 04/19/17 11:07 PM Re: New Torque Converter install cost ? [Re: 2011P7E]
Black_Sunshine Offline
The bolt pattern is referring to the spacing for the bolts that go in the flywheel. My flywheel had holes for both sizes.
I don't think that stall is high enough to be worth the swap. It would be a shame to get another one in there (especially if you're paying to have it installed) and find out that it was the same.
75mm DBW TB
� hood ornament
� c-pillar emblems
� LS style body side moldings
CarDomain
Facebook
#3616114 - 04/21/17 02:22 AM Re: New Torque Converter install cost ? [Re: Black_Sunshine]
09mnsp Offline
I'm Quoting Black_Sunshine here but am directing this toward the Original Poster of this thread. I agree, You need to get up past 3000 rpm IMO. But more importantly you want something of a smaller diameter than even the 11.25. The smaller the diameter, the quicker it'll rev. I've had a stock ford 11.25" 2400 stall(Police interceptor), a 9.5" street Edge 3200-3400 stall, a 9.75" circle d multi disc 2800 stall(Missed it's mark the first time somehow) and currently a 9.75 circle d multi disc 3600-3700 stall. I've also had my Transmission out 3 times and I will tell you it would definitely not be worth all the work for the extremely small amount you would gain with the converter the OP is considering. Of course this is just my opinion, but again I'v tried most everything in between...
Edited by 09mnsp (04/21/17 02:25 AM)
09 P71
#3616506 - 04/21/17 01:33 PM Re: New Torque Converter install cost ? [Re: 09mnsp]
Accumulator Offline
..... I've had a stock ford 11.25" 2400 stall(Police interceptor), a 9.5" street Edge 3200-3400 stall, a 9.75" circle d multi disc 2800 stall(Missed it's mark the first time somehow)..
Noting that you clearly wanted a higher stall, how was the 9.75" / 2800 with your gears/cams? I like mine a bit tight and that specific converter is on my radar.
#3617114 - 04/21/17 08:45 PM Re: New Torque Converter install cost ? [Re: Accumulator]
09mnsp Offline
Well I had 3.73 then and was swapping out my Edge 3400 after it failed on me. So in this circumstance I upgrades to a circle d and requested the same stall speed I had in the edge. For whatever reason it didn't stall high enough the first time so out it came and was sent back for a one time free re-stall. With all that said, I did drive on the 2800 stall for a few weeks. I could definitely appreciate it. at cruising speed the car pulled nicely when stabbing the throttle and unlocking the tcc. If you know what a stock 11.25" 2400 stall feels like, no matter whether you like it or don't, a 9.75" 2800 from circle d would be a very nice and noticeable improvement over it.
09 P71
#3617186 - 04/21/17 10:00 PM Re: New Torque Converter install cost ? [Re: 09mnsp]
Yes, our mods are similar. You have headers and more aggressive gears. Those the big differences in our setups.
I'm running a 10" 3200-3400 from Roadrunner. I had trouble with it about 2k miles in. It started whining so I pulled it back out and took it back. I chose them because they were the cheapest. I mitigated the risk by swapping it myself and they are local to me. I ended having to pull it out and wait a week for them to rebuild it. They said there was junk in the bearings. Slapped it back together and same. frown Took it out and had them go through it again. Once again they said there was junk in the bearings. I put an oil filter in-line after my coolers. Put it back together and no trouble since. Took the filter out after about 3k miles because I couldn't get it to stop leaking.
At this point I've banged around with this converter for 40k miles. Cams/stall/gears really make it completely different car.
75mm DBW TB
� hood ornament
� c-pillar emblems
CarDomain
Facebook
#3618282 - 04/23/17 12:51 AM Re: New Torque Converter install cost ? [Re: 2011P7E]
filthyboatguy Offline
Loc: CA
9.5" billet, 3600 stall, FTI or Circle D are my next mod.
Edited by filthyboatguy (04/23/17 12:52 AM)
2006 P71 70K
Adco bars, Metco arms/watts, ARP bolt, KYBs, TCE SS lines, 410s, JMOD, widened steelies with a 285/40/17 & 235/50/17 stagger, GT 500 wheels currently unshod, AM drag wheels w/M&H DRs in a 245/55/15 & 185/55/17 stagger, Eaton 1.5" drop front, 13' GT500 PP springs rear, Hawk HPS, Raybestos drilled/slotted, Steeda UDPs, Reinhart 91 tune, Jerry half-shafted/ported 75mm & ported SR plenum, 2.5" X piped Super 10 catback, BH1976 harness, Hellas, K&N panel, mint. 14.95 @ 92 with a 2.1 60' at a 1400ft DA.
1998 P74 HPP 93K
KYB, ENS, Bullitts, BH1976 harness, Magnaflow, K&N panel, mint daily with a busted heater core ;(
#3618354 - 04/23/17 02:43 AM Re: New Torque Converter install cost ? [Re: filthyboatguy]
09mnsp Offline
That will definitely make things more fun. smile
09 P71
11 registered (bensharn, GrandMarq9807, bravohotel, Ford_forever, DudeAbides, 1 invisible), 73 Guests and 10 Spiders online.
a_d_a_m 186
Ezbok58a 155
charlieD 152
BigMerc96 144
Ponyguy 120
dpk 116
White99MGM 102
SocalSam 84
Moby_Vic 77
reminc70 74
