#3615738 - 04/20/17 08:05 PM It's timing chain guide time!
Marauder2004 Offline
Loc: VA
I thought I'd share a recent oil report from one of my work beater cars, an '04 Grand Marquis. This is the second '04 GM I've put through highway service for my job. The first is still going strong at 249k. This one now has 243k. Both have had oil changes at roughly 15k mile intervals since I started using them with around 50k on the odometer. Both will amazingly still run up to 15k without having to add oil. The last three reports have indicated elevated AL levels.
I guess I'll pull the old mule into the garage and start tearing the front off to get to those guides.
04 MM Silver Birch/Light Flint, HS, TO, 6CD
04 MGM LS Black/Dark Charcoal
06 MGM LS Ultimate w/ HPP, Black/Dark Charcoal
69 Marquis convertible, 429
48 Ford F4
#3615778 - 04/20/17 08:45 PM Re: It's timing chain guide time! [Re: Marauder2004]
bigROC209 Offline
Loc: Stockton, CA
What kind of oil/filter are you using to go 15K between oil changes?
2002 Marquis LS Precision Trac, new engine @ 125K, GT Wheels, HP tires, SCT Xcal 2, 91 Octane tune from BOC, Traction Locker w/Ford Racing clutches, 3.55's, Police D/S, Ford Racing IM @114K, 75mm TB, Trick Flow Plenum, Ziptube, GT MAF, P71 Rear Coils, Summit Racing UDP's, HPP Sway Bar, Gas KYB's, J-Mod, 2-1/4" Dual Exhaust, Thrush Glasspacks & 18" tips, MSD COPs, NGK TR55's & Grey Injectors, Pinstripe removed, Disc changer, 2400 watt Pioneeer amp & 6x9's, Kicker Comp VR 10" DVC subwoofers.
#3616130 - 04/21/17 02:27 AM Re: It's timing chain guide time! [Re: Marauder2004]
I'd like to see how those guides look at 243k if you'd be so kind as to post pictures.
'03 Marauder - tune, J-mod, K&N, Addco swaybars, Heinous control arms, Steeda underdrives
'07 P71 - TR3650, Exedy clutch, Modular Head Shop stage II cams, Kooks headers, underdrive pulleys, 3.27 Trac-Lock
'91 LTD Country Squire - HO swap, WR-AOD, 3.55LSD, cargo coils all by pantera77
Former owner of: '02 GMQ GS | '04 GMQ LS | '04 GMQ LS Limited | '04 MM
#3617122 - 04/21/17 08:45 PM Re: It's timing chain guide time! [Re: a_d_a_m]
Loc: VA
I have only used Castrol Edge (gold bottle) 5W30 in both cars. The filter brand varies with what's on sale. Usually I use the OEM 820S, but sometimes I find the higher end Purolater, Bosch or Wix on sale. I realize the OEM filters are not intended for a 15k interval, but 80% or more of my driving is at 70+mph steady running.
I dug into it today and here's what I found. I discovered the source of the AL content, but it wasn't as bad as I had expected after running for several tens of thousands of miles after the AL levels started to increase. The plastic was worn through on the right side, but not (yet) on the left.
I replaced the guides, the other plastic piece, and the tensioners. Not too bad of a job but I'd rather replace an intake than do this again- which is what I'll be doing tomorrow. I have been noticing a bit of moisture at the metal/plastic interface below the thermostat housing. I replaced the intake on the other high mileage Merc two months ago.
Edited by Marauder2004 (04/21/17 08:48 PM)
48 Ford F4
#3617258 - 04/21/17 11:39 PM Re: It's timing chain guide time! [Re: Marauder2004]
Those don't look bad for 200+k on them.
My '02 Marquis was chewed all the way through at 100k (hence the need for the TSB from 2000-03).
#3631929 - 05/07/17 02:10 AM Re: It's timing chain guide time! [Re: Marauder2004]
bspurloc Offline
Loc: New England
I am more interested in the pic you took!
I thought the intake had to come off to get to the timing chains??! not sure why I thought that, and valve covers?
'03 Sport
'07 Audi Q7
#3632057 - 05/07/17 08:33 AM Re: It's timing chain guide time! [Re: Marauder2004]
Loc: VA
The intake does not have to come off to remove the front cover. The front bolts in the cam covers do have to be removed. I remove the front 5 or 6 bolts on each side to gently lift and break the seal on the front of the cam covers to the top of the front cover. You just have to be careful to not break the cam cover gaskets. As far as the intake removal- that was a separate job I did right after I finished the timing components and front cover.
48 Ford F4
4 registered (SFDE56, Mustangwilly, 2 invisible), 294 Guests and 14 Spiders online.
a_d_a_m 182
dpk 157
BigMerc96 129
Moby_Vic 104
WSTRLNG 83
Ponyguy 78
reminc70 78
RF_Overlord 64
Bellwestern80 56
LSE_Dave 51
