#3641801 - 05/17/17 09:18 PM Please help me verify this tag info
Steve68 Offline
Loc: Batesville, Arkansas
I currently have an 07 p71 rearend under a 53 F-100 (a friend said an 03 fit nicely under his 56🤔). It's too wide but I had no choice but to install it once I got the old one out. My truck was on a friends rack and it couldn't stay. I've traded for another p71 rearend. I think it's a 98 and was hoping if I list the rearend plate info then someone could help verify. Top line is SN 019C. The second line is L55 88 8K23. I know it's an 8.8 posi 3.55. I need help with the year. I've been told that the late 90s rearends are narrower and more like to fit than the 03 on up. If someone could help clear this up, I would really appreciate it.
#3641849 - 05/17/17 09:38 PM Re: Please help me verify this tag info [Re: Steve68]
Its probably a 1999 differential since the date code is November 23, 1998. It is also a 3.55 axle with limited slip.
If you are using the Panther suspension layout, then the 2 differentials are a direct swap for each other except for the location of the rear shock mounts. The '98-'02 differential is narrower than the '03-'11 diff, '98-02 used shocks mounted inboard of the frame rails as where '03+ were outboard. The rest of the suspension mounting points are the same. '03+ axles have slightly better rear brakes, but if its important enough to pull the backing plates and swap them is your call. I'd be inclined to keep the slightly smaller and non-vented brakes of the older axle since they are likely sufficient unless you are road racing the thing.
1998 Mercury Grand Marquis LS HPP ~92k miles, not entirely stock.
1997 Town Car Cartier ~143k miles, 70mm TB, Ported Plenum, Gutted Airbox, Mechanical Fan Delete, Contour E-fan Retrofit, Dual exhaust with Magnaflows, rear cat delete, MSD Ignition, KYB Gas-A-Justs, Marauder/HPP rear sway bar, P71 front bar, air ride reinstated, Blinker Mod, Projector retrofit, Caddy 4-note horn retrofit, Wood rim steering wheel retrofit, natural weight reduction.. Smashed 1/13/13....I fixt it..
#3641953 - 05/17/17 10:54 PM Re: Please help me verify this tag info [Re: BigMerc96]
Steve68 Offline
I've been reading almost non stop since I initially posted. I guess it boils down to this question which I think I already know the answer to. If the 07 is about 2 inches per side too wide then will the 98/99 also be too wide or does it track narrower. I'm no mechanic but am fortunate to have a good friend that is. I'm learning as I go. It's a pretty steep bell curve. Thanks for the quick response
#3641969 - 05/17/17 11:03 PM Re: Please help me verify this tag info [Re: Steve68]
dpk Offline
Loc: wny
They changed the axles in 03. The 98/99 are narrower (I'm not positive exactly how much).
previous: 2016 Buick Verano - bought 4/7/16 9 mi - GOOD RIDDANCE - 7/29/16 4,816 mi
Worst 3 months & 22 days OF MY LIFE!
2003 Buick LeSabre - bought 12/11/03 28 mi - traded in 4/7/16 117,531 mi
I miss you, Hollie.
Originally Posted By Bellwestern80
Man, you can't even grammar.
#3641985 - 05/17/17 11:07 PM Re: Please help me verify this tag info [Re: Steve68]
Steve68 Offline
Thanks dpk. any other input would be appreciated
#3642529 - 05/18/17 06:39 PM Re: Please help me verify this tag info [Re: Steve68]
According to the parts catalogs, the axle shaft for a '99 is 32.25" long and a '07 is 34.4" long, so, about 2" longer per side for a '07 vs '99 differential.
#3642841 - 05/19/17 09:19 AM Re: Please help me verify this tag info [Re: BigMerc96]
Steve68 Offline
Bigmerc, your the man. Thank you very much. You and others on this site have saved me a couple hundred. Much appreciated
3 registered (OrlandoLTD, Sunfish, CrazyRay), 252 Guests and 10 Spiders online.
BigMerc96 142
a_d_a_m 139
dpk 129
Ponyguy 91
Moby_Vic 81
charlieD 79
RF_Overlord 70
SocalSam 65
Bellwestern80 53
EZlivin11 52
