#3668442 - 06/22/17 02:16 PM Drivers Side Rear End Sag
AyKillah Offline
Loc: Maple Hill, NC.
Sooooo the search didn't help... I replaced both shocks(Police spec) and springs(Moog) in my 99' CVPI, yet the drivers side rear is still sagging. The entire time I was installing I though I was fixing the problem but I was wrong and now I'm even more at a loss. I need your input gents!
2014 Dodge Charger R/T Plus
2014 Ford Escape Titanium
1999 P71 w/ 2001 PI Engine
SCT Tuned--Steeda Underdrives--3.55s w/FRPP Tlok--K&N FIPK--BBK Tuned Length Headers-- 2.5" BBK O/R X Pipe--Flowmaster Super 44s dump'd--Lo-Tek Triple pillar pod w/ A/F-Tach-Voltage--17in. Bullitts w/ 245/275--Complete A/C Delete--BBK 78mm TB/Plenum Combo--1/2" plenum spacer--80mm Marauder MAF--190lph Walbro--Venom 24lb injectors--Jet 180* Thermostat--ZEX Wet kit--ZEX Purge--ZEX Bottle Heater--Marauder center console and shifter w/ Oil Pressure & n20
#3668586 - 06/22/17 07:53 PM Re: Drivers Side Rear End Sag [Re: AyKillah]
Chaplian Offline
Insert witty title here
Loc: Chicago, IL
It's probably the front springs. Your driver side front spring is probably bad and causing a tilt in the back.
2011 Crown Vic LX- 78,xxx.
2003 Crown Vic HPP- 235,xxx miles. Retired.
1995 Impala SS- 29xxx miles. The Lovely Lady
2003 BMW 325i Wagon- 8250 RPM redline. Complete M3 drivetrain, suspension, and electronics. Taylor Swift.
2017 Mazda3 GT Hatchback- 90,xxxx miles. 2.5L, fully loaded. The Daily Grind.
#3668794 - 06/23/17 08:23 AM Re: Drivers Side Rear End Sag [Re: AyKillah]
AyKillah Offline
would the front be leaning as well? I ask because the front looks leveled out and just the drivers side rear has the sag.
#3669466 - 06/24/17 09:05 AM Re: Drivers Side Rear End Sag [Re: AyKillah]
Chaplian Offline
Loc: Chicago, IL
Measure the ride heights from the center of the rim to the edge of the fender/wheel opening. See what the measurements are at all 4 corners and go from there.
#3691058 - 07/21/17 01:34 AM Re: Drivers Side Rear End Sag [Re: Chaplian]
cruz07 Offline
Loc: Dallas County, TX
Why would the front driver spring cause it to lean back?
2005 P71 146,XXX SOLD 03-10-2020
2018 Chevrolet Traverse 33,XXX
X-Panthers
1997 P71 161K
1998 P71 113K
Originally Posted By Moby_Vic
Because CVN is the land of $600 cars.
#3691106 - 07/21/17 06:31 AM Re: Drivers Side Rear End Sag [Re: cruz07]
Chaplian Offline
Loc: Chicago, IL
Your passenger rear is sitting low. You go to your front, realize the passenger front is low also b/c the spring's sagging, and that the driver's rear is high. This causes the back to look more uneven than the front (in some cases.)
