#415859 - 04/07/04 05:10 PM ENGINE: IGNITION--coil on plug ignition question
C_Paine Offline
Loc: Rochester, NY
Does anyone here know a lot about coil on plug iginition, how it works, what tells the coils to fire in which order, and could it be run off the old computer system from a 93 Mark VIII if wired properly? Any suggestions would help.
Edited by Liquid (04/14/05 02:28 PM)
1992 Crown Vic Police Interceptor
4.6 Marauder Engine
AODE with a Trans-go shift kit
18 inch Marauder rims
3.73 limited slip rear end
#415860 - 04/07/04 06:15 PM Re: coil on plug ignition question
AndrasOtto Offline
Loc: Waldorf, MD
You'd most likely have to get a computer from a car that used COPs. I'd venture to say it would be impossible to operate a COP system off a computer that wasn't set up for it.
99 CV Deep Wedgewood Blue
12.947 @ 104.05
00GT PI 4.6l engine; 24# injectors; 190 lph intank pump; Marauder MAF; 75mm BBK t/b; Trick Flow Upper intake; SCT ProRacer Flasher; Performance Automatic AODE valvebody; Underdrive pulleys; 3.73 FRPP gears and Mustang Trak-lock; Level Ten 3000rpm converter; Ford shorty headers cut and welded to fit; 2.5" cat-back with X, high flow cats; NOS 05-171 4.6L Dry kit; 245/55/16 Toyo Proxes T1-S on 16" '95 CobraR replica rims.
#415861 - 04/07/04 09:22 PM Re: coil on plug ignition question
Rat Offline
Loc: Omaha Nebraska
The ECU tells when the coils to fire, it's just simple ignition timing and firing order...
As far as swaping, I have no idea...
Brad
#415862 - 04/07/04 09:22 PM Re: coil on plug ignition question
Rat Offline
Loc: Omaha Nebraska
The PCM (?) tells when the coils to fire, it's just simple ignition timing and firing order...
Brad
#415863 - 04/08/04 04:20 PM Re: coil on plug ignition question
C_Paine Offline
Loc: Rochester, NY
Anyone else have suggestions?
4.6 Marauder Engine
#415864 - 04/08/04 04:24 PM Re: coil on plug ignition question
Dirt820 Offline
Resident Alcoholic
Loc: Machesney Park, IL
Background info would be extremely helpful, but I'll go out on a limb here.
You're putting a DOHC Marauder engine into a '92 Crown Victoria. Get a Marauder Computer.
The trans is also going to be an issue.
The coils are fired by drivers within the PCM. I've never seen a 1993 model year anything with coil on plug ignition.
I always wanted to be somebody, but I should have been more specific.
Lily Tomlin
#415865 - 04/08/04 04:32 PM Re: coil on plug ignition question
C_Paine Offline
Loc: Rochester, NY
I can't use a marauder computer because then I'd have to get a marauder fuel pump and a marauder tranny and rear axle to run the speedometer. I mean it could be done like that but I don't have the money.
4.6 Marauder Engine
#415866 - 04/08/04 04:36 PM Re: coil on plug ignition question
Ronman® Offline
Loc: MCO
You HAVE to have the PCM programmed to control your AODE.
The first application that comes even close to fitting your criteria is the '97 Mark VIII, which was the first Ford with COP ignition.
Why don't you just take the coil packs off the front of your old SOHC and fit them to the 32V? Oh, right, that would make too much sense.
Log off life.
#415867 - 04/08/04 04:37 PM Re: coil on plug ignition question
C_Paine Offline
Loc: Rochester, NY
Hey Ron, we may end up doing that, but first I wanted to see if we could make the coil on plug ignition work.
4.6 Marauder Engine
#415868 - 04/08/04 04:46 PM Re: coil on plug ignition question
C_Paine Offline
Loc: Rochester, NY
actually, the pcm worked well controlling the tranny, but I can't remember if we used the Mark VIII PCM or the Crown Vic one? I think we used the Mark VIII PCM from 93-94 Mark VIII, I know it had a 4R70W Tranny, but it works well with the AODE.
4.6 Marauder Engine
#415869 - 04/10/04 10:12 PM Re: coil on plug ignition question
C_Paine Offline
Loc: Rochester, NY
I did end up using the coil packs and wires, it dosen't look as nice but it runs.
4.6 Marauder Engine
Moderator:  a_d_a_m, KayTar, Liquid
3 registered (2003_mgm, ford05, 1 invisible), 38 Guests and 11 Spiders online.
a_d_a_m 193
Ezbok58a 161
BigMerc96 145
charlieD 145
Ponyguy 119
dpk 113
White99MGM 104
SocalSam 85
Moby_Vic 81
reminc70 70
