#50184 - 11/23/02 11:28 PM ENGINE: IGNITION--Pic of my bad Coil pack
Mr_Ash Offline
Loc: DuPage Co., IL
Edited by Liquid (12/15/03 08:31 AM)
"Last of the V-8 Interceptors"
2000 Ford Crown Victoria
Deep wedgewood Blue
56,XXX Miles
Gray Cloth Interior
Goodyear GT HR's
Deluxe Wheel covers
1992 P74 (Silver/Grey 98k) ~ Totaled/Sold
1994 P71 (Black/Blue 152k) ~ Under Construction
1996 P71 (Blue/Blue 143k) ~ Totaled
#50185 - 11/24/02 12:04 AM Re: Pic of my bad Coil pack
lumper Offline
Loc: connecticut
following this was fun, thanx for the pic, i know it helped me.
#50186 - 11/24/02 12:15 AM Re: Pic of my bad Coil pack
Mr_Ash Offline
Loc: DuPage Co., IL
Good way to test the coil packs is start the car and pull each plug/connector/boot thingy off the coil pack (ONE AT A TIME! or its a shock fest!), if ya see a spark it works if not then replace it!
Ooooh yeah, Jesse (CommandoVic) told me to where THICK rubber gloves, I figured "Ahh what the hell is a little shock!" needless to say I shocked my self about 17 times! plus a few times when my wrist watch touched the throttle body while reving the engine and holding a plug wire near the coil pack in the other hand! (DOUBLE SHOCK!)
Changing them out is VERY EASY! all you need to do is remove 4 lil bolts (its a small socket, cant remember number and tools are in my trunk) All you need is a ratchet and a Extention. IMO it would be best to leave all of the plug wires connected to the Old coil pack untill you have the new one bolted in that way you dont accdently switch any of the wires around!
Deep wedgewood Blue
56,XXX Miles
Gray Cloth Interior
Goodyear GT HR's
Deluxe Wheel covers
#50187 - 11/24/02 03:48 AM Re: Pic of my bad Coil pack
Anonymous
Unregistered
that's my next project after the waterpump,belt tensioner,and idler pulley.
#50188 - 11/24/02 10:29 AM Re: Pic of my bad Coil pack
Tony_the_Brit Offline
A suggestion is to always clean your coli packs at this time of year (unless your engine is kept shiny all year round of course).
Just remove the connections (remembering/marking which ones go where) and then clean with WD40 and a rag.
Dirt can provide an initial path for "tracking" of the spark away from the wires. This will also help you to see any cracks etc.
03 Crown Vic LX Sport maroon 1/4 ET = 14.237, MPH = 94.80...243rwhp 284rwtq(SAE) 177,000 m
03 P71 silver 213rwhp 251rwtq 200,000 m
04 P71 Spruce Green 101,000m (SOLD)
04 P73 Dark Toreador 115,000m
07 P71 Arizona Beige 190,000m
11 Crown Vic LX Blue 101,000 m
#50189 - 11/24/02 01:16 PM Re: Pic of my bad Coil pack
Fred Offline
Loc: Wakefield, Massachusetts
Does it run a lot beter now?
#50190 - 11/24/02 02:12 PM Re: Pic of my bad Coil pack
Mr_Ash Offline
Loc: DuPage Co., IL
Yeppers!
Deep wedgewood Blue
56,XXX Miles
Gray Cloth Interior
Goodyear GT HR's
Deluxe Wheel covers
#50191 - 11/25/02 12:04 AM Re: Pic of my bad Coil pack
93_Marquis Offline
Loc: Norwood, OH, USA
FYI: Removing the spark plug wires from either the coils or the plugs while the car is running is a VERY bad idea!! Your dealing with very high voltage...enough to do more than give you just a "Little" shock.
NEVER do this! Follow the proper test procedures for the components instead.
Ray
Car: 2004 Mercury Marauder
Engine/Tranny: 49k and bone stock...for now wink
#50192 - 11/25/02 12:08 PM Re: Pic of my bad Coil pack
lifespeed Offline
Loc: northern California
Ash,
17 times? You don't learn so quick.
To check for spark, you can plug a extra spark plug into each wire, and ground the plug. Starting and stopping the engine in between each plug is possibly slower, but less painful.
"Ouch. OK. Yikes! That one is good too. Owww! Not that one..."
- Lifespeed
2004 Silver Birch Marauder 140K miles
Wilwood F/R brakes, Penske 7500DA shocks, Hypercoil 600lbs F and Grand Marquis R air springs, Addco tubular sway bars, Metco control & Watts, 31 sp axles, Stainless Works cat-back exhaust, Lidio tune, BFG KDWS tires
#50193 - 11/25/02 12:32 PM Re: Pic of my bad Coil pack
Buck268 Offline
Loc: Grand Rapids, MI
Chiltons has the test proceedure documented... it involves Ohm meter usage... I tested a few ohms (3 i think) out of range, so I dropped (wasted) money on accels...slight improvement over old stocks....
Edited by Buck268 (11/25/02 12:36 PM)
#50194 - 12/15/02 11:23 AM Re: Pic of my bad Coil pack
Jersey Offline
Loc: S.Hackensack, NJ
Where are the coil packs located on a 98p71????
Mark from Jersey.
98 p71 NYSP-Albany.
181k - Stock.
#50195 - 12/15/02 11:48 AM Re: Pic of my bad Coil pack
Sepiroth Offline
Loc: Kouts, Indiana
On the 98 and newer vics they dont have coil packs. They have C.O.P. (coil over plug). On the intake manifold you will see 8 injectors and 8 individual spark plug coils.
#50196 - 12/15/02 11:52 AM Re: Pic of my bad Coil pack
metroplex Offline
Loc: Motor City, USA
Yeah its called COP as 96 PI stated before. Coil on plug.
If you want to get technical, its DISCOP
Distributorless Ignition System Coil on plug
Moderator:  KayTar, Liquid
NM117 334
Moby_Vic 146
BigMerc96 120
EZlivin11 120
Chaplian 118
RF_Overlord 115
Ezbok58a 112
a_d_a_m 100
mdnos 96
Ponyguy 93
