#617841 - 01/05/05 07:37 AM How to Stop Wiper Chatter ????
P71_Interceptor Offline
Loc: TROY, OHIO
I have the worst luck with windshield wipers.
Seems every vehicle I get always has problems with the wipers "chattering" when used.
Yea, I've replace the blades and still get the damn chattering.
So what's the secret to STOP the annoying windshield wiper chatter ???
Conservatives HATE Obama more than they LOVE America!
#617842 - 01/05/05 08:36 AM Re: How to Stop Wiper Chatter ????
metroplex Offline
Loc: Motor City, USA
Check the alignment of the arms and how its applying pressure to the wiper blades. If it's applying a lot of pressure to one side, it will cause chatter.
It would also help if you clean the windshield glass surface with Windex or something, then apply the old fashioned Rain-X stuff.
I would recommend silicone wiper blades. I've been using them for 2+ years (same pair) and they work great in the winter: they can't freeze!
#617843 - 01/05/05 10:32 AM Re: How to Stop Wiper Chatter ????
Amsoil_Dealer Offline
Loc: Clearwater, FL
I tned to agree with Metro on this one. If it happens on every car yuo have it might be as simple as the type of soap you use to wash the car.....Clean the windshield well and apply some Rain-X. You won't need the wipers as much and they will run pretty smooth (for a while).
Good Luck
2002 CV LX Sport - Bone stock, for now ;-) except for Amsoil lubes of course. 10W30 ATM engine oil, Amsoil ATF in the tranny, and Series 2000 75W90 gear lube in the diff. Kuhmo Ecsta KH 11 tires. Ford Motorsport Dual Mode Mufflers. 15.87 1/4 mile ET. www.lubedealer.com/dstevens
#617844 - 01/05/05 10:48 AM Re: How to Stop Wiper Chatter ????
metroplex Offline
Carnauba wax (from a car wash) will also tend to increase friction causing the chatter.
#617845 - 01/05/05 11:12 AM Re: How to Stop Wiper Chatter ????
Allen Maty Offline
Loc: Southern California
I had the same problem with the drivers side wiper! I found it was not perpendicular to the winshield! so I took the blade off, stuck a screwdriver in the 'hook' of the wiper arm and twisted it until the wiper was perpendicular to the winshield. Works great now!!
Just be carefull not to twist it too much!!
'99 Crown Victoria LX HPP w/ Digi-Dash 11/2001-12/2011 Sold! Still on road with 219K miles as of 1/15
2012 Mustang GT Premium 5.0 6 Speed Man /w 3.73 LSD. wink
For Sale: Maurader Air Intake, Zip tube & 80mm MAF with matching BOC Custom Tune Chip and ECU computer (will fit '99-'00).
#617846 - 01/05/05 11:13 AM Re: How to Stop Wiper Chatter ????
Raptor9458 Offline
Loc: Chicagoland
Also cleaning your wiper blades can help prevent this. Take some high-quality glass cleaner on a paper towel, and GENTLY run it from one end of the blade to the other. Do this several times until there isn't as much black stuff coming off on the towel. If you do this every few weeks, it can help prolong the life of your blades. running your wipers while going through a touchless car wash can also get them a little cleaner, but of course not as clean as doing it by hand. Some places also sell little wet-nap style cleaning wipes for blades that will help restore the blades.
I replace mine every six months as many manufacturers recommend, and clean them regularly and they don't give me much trouble. Oh, and getting quality blades to start with helps too.
#617847 - 01/05/05 11:17 AM Re: How to Stop Wiper Chatter ????
Loc: TROY, OHIO
You mean you're supposed to wash cars ?? j/k!
I'll do the Rain-X thing. Just forgot about it. That stuff is GREAT!
#617848 - 01/05/05 12:01 PM Re: How to Stop Wiper Chatter ????
Spzoid Offline
Loc: Taylor, Mi
My blades usually work well at city speeds, but they cahtter up at freeway speeds. I've often thought about installing a mini-spoiler onto the wiper arm to keep the blade close to the windshield at freeway speeds. Any thoughts on this?
-Spzoid
íSubite, Sentate, Callate y Agarate!
(Get in, Sit down, Shut up & Hold on!)
<img src="/ubbthreads/images/graemlins/cool2.gif" alt="" />
2000 Crown Vic P71
No Mods Yet <img src="/ubbthreads/images/graemlins/frown.gif" alt="" /> (I Broke)
http://home.comcast.net/~2000-p71/
#617849 - 01/05/05 12:32 PM Re: How to Stop Wiper Chatter ????
metroplex Offline
If you're using rubber wiper blades, good luck. I've never had any good experiences with rubber based blades.
The silicone stuff is much better. It remains soft and flexible in the winter, doesn't absorb water so it doesn't freeze up, and lasted the longest out of all the blades I've tried.
For those in the salt belt, make sure you have plenty of de-icer fluid in the trunk and in your reservoir.
#617850 - 01/05/05 12:37 PM Re: How to Stop Wiper Chatter ????
Colonel Offline
Loc: Louisville, KY
I've found Rain-X is the cause of wiper chatter myself. If there isn't enough water on the windshield.. *skurrrt* they chatter.
Quad-Cam Cop Engine, Bullet Proof Tires & Windows, Stab Proof Seats, Steel Door Beams, SuperCharger, Anti-Deer Harmonic Wheel Covers, Trunk Mounted Counterbalance System
..and many other things people told me my car is equipped with.
#617851 - 01/05/05 12:46 PM Re: How to Stop Wiper Chatter ????
metroplex Offline
I've never had a problem with Rain-X.
I also use Rain-X wiper fluid....
I would definitely check the wiper arms like Allen Matty said.
#617852 - 01/05/05 12:52 PM Re: How to Stop Wiper Chatter ????
Raptor9458 Offline
Loc: Chicagoland
I second that. Last week I went through half a gallon in a 24 hour period.
#617853 - 01/05/05 02:23 PM Re: How to Stop Wiper Chatter ????
stevo Offline
Loc: Wisconsin--most of the time
Foogettabboutitt!
CV's don't have a good wiper system! Tried all of the different blades, even the "Winter" version. Nothing works.
And don't you just hate rolling down the driver's window in a blizzard-type snowfall to clear all the snow off when the wipers start to pack too much snow over on the left side of your viewing area!!!!!!!
Yeah, I'm having a bad day. Trying to avoid doing the front brakes on the '93
Signature removed. See rules.
#617854 - 01/05/05 03:44 PM Re: How to Stop Wiper Chatter ????
Jinx Offline
Buy me a Coke
Loc: Gold Bar, WA
My drivers side wiper blade was horrible when I bought the car. I must have bought 4 sets of wipers before I realized the arm had somehow twisted and the blade was sitting at a slight angle. It works fine now that it's level with the windshield.
78 AM General M35A2 deuce and a half - 03 Mercury Grand Marquis LSE
Merc' Mods: J-Mod!, Custom Windshield Etchings - Thanks rock spewing dump trucks!
~~ Preparing for the inevitable zombie apocalypse since 2009 ~~
#617855 - 01/05/05 04:49 PM Re: How to Stop Wiper Chatter ????
RomanR Offline
Loc: Los Angeles, CA
Freeway speed! I have the same problem. I practically does not wipe at the speed over 55. Does the "mini-spoiler" help?
Crown Victoria, P71, '97, 110000mi
7 registered (CVJPMG, DES, 2004_p71, JaxRhapsody, IPreferDIY, 1 invisible), 85 Guests and 97 Spiders online.
NM117 324
EZlivin11 131
BigMerc96 127
Moby_Vic 126
RF_Overlord 124
Chaplian 117
mdnos 96
a_d_a_m 95
Ezbok58a 92
09P71VIC 91
