#629825 - 01/23/05 03:04 PM Wheel Bearing Replacement...
David Harleyson Offline
Loc: The Republic of Texas
OK, It looks like I have learned something else I didn't know on this board. Based on the SEARCHES I did, it appears that the wheel bearings on the CV's are a selaed one piece unit that is available only WITH the hub and studs!?!? I went to the trusty service manual and found info on the bearings from 91 and older. NOTHING on 92+.
SO...help me out, how does one check the "looseness" of these things? What is the torque spec on the nut? and how does one decide when to replace the assembly?
I'm getting ready to do a complete front brake job on my 98 (140500) and might as well do these too while I'm down there if I really need to. Any thoughts, links ect. would be much appreciated!
Thanks!!
"If you don't think you are going to like the answer, don't ask the question; because forgiveness is easier to get than permission"
'01 Harley Wide Glide: CV44mm carb, D&D pipes, 6200rpm computer, Mobil 1 V-twin, K&N filters
'04 Dodge 2500 crew cab Cummins/6 speed (work truck)
'05 Saturn Vue: 3.5 V6 SilverStars, Mobil 1 5w-20, Mobil 1 filter, Amsoil ATF
'98 CV P73: ABS/TC, P71 shocks, ENS bar endlinks, P71 ECM, 140 speedo, 180* t-stat, AWSF22C, SilverStars, Honeycomb grille, Mobil 1 5w-30, 235/60-16 Yokohama Avid V4s, 3.27 TracLock with +1 mod and F-150 "S" spring
#629826 - 01/23/05 03:07 PM Re: Wheel Bearing Replacement...
TheIndifferent1 Offline
Loc: ottawa, ontario
If it's not turning smoothly replace it. You could probably grab the studs and move it around to see if there is any play. There is no nut on the assembly as far as I know(i've never taken the dust cover off).
93 Crown Victoria LX
Towing Package
Phenolic piston calipers w/ AC Delco organic pads
Raybestos Super Stop Severe Duty brake rotors(slotted/cross drilled, they suck.)
Continental ContiExtremeContact 225/60r16
traction-lok rear w/ 3.27's
FRPP 9mm ignition wires
#629827 - 01/23/05 03:13 PM Re: Wheel Bearing Replacement...
Neither have I, yet,....but then what holds the hub/bearing assembly on the spindle? Pressed on??
#629828 - 01/23/05 03:21 PM Re: Wheel Bearing Replacement...
Kinger87 Offline
Loc: Gladstone MI
there is a big nut, something like a 22mm.
Once removed, the bearing comes right off.
2003 Grand marquis all stock
#629829 - 01/23/05 05:50 PM Re: Wheel Bearing Replacement...
Anyone have any idea what the torque spec is on the nut? And does it require any Loctite? Or is it a cotter pin setup?
#629830 - 01/23/05 05:56 PM Re: Wheel Bearing Replacement...
Buck268 Offline
Loc: Grand Rapids, MI
Torque to yeild, so be sure to use a brand spanking new nut
#629831 - 01/23/05 06:02 PM Re: Wheel Bearing Replacement...
RandyK Offline
Loc: Miami, Florida
Torque is 189-254ft/lbs(Chilton), no cotter pin and I use BLUE locktite on everything.
Freaked me to see no cotter pin, but the bad boy is not going anywhere at 250. If you look close, the hole in the nut is slightly oblong and the thing has not budged. YES, I marked it and checked a month later.
Randy
#629832 - 01/23/05 07:27 PM Re: Wheel Bearing Replacement...
Squeek Offline
Loc: Behind you
If you read the plastic cover, or any Haynes manual, you'd see that the wheel bearings are not serviceable. Replace them if you need to, but they cannot (should not?) be serviced.
I have no idea how to tell when they're bad, but I've never had to replace them on my '93 with 210k.
#629833 - 01/23/05 09:34 PM Re: Wheel Bearing Replacement...
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
You will hear (and feel) a bad front wheel bearing on a high speed curve. Also if you drive down an alley with buildings on both sides you will probably be able to hear the noisy bearing. If you jack up one wheel and check for play (9 and 3) and (12 and 6) you will detect any serious deterioration of the bearing. Rule out play from tierods and ball joints in your consideration.
In my own experience it has been the passenger side bearing that goes first (or only). It is a sealed bearing but the theory that I believe is that the passenger side gets salted and slushed more than the drivers side.
#629834 - 01/23/05 10:35 PM Re: Wheel Bearing Replacement...
Georges93LX Offline
Loc: Owensboro, Ky.
Try this.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7949465967&category=42609&sspagename=WDVW
1993 Crown Victoria LX. 5.4L Supercharged/6-Speed. SOLD. Black '03 Marauder 300a. SOLD.
If I gave a crap about gas mileage I would own a bicycle. It's time to start shopping.
#629835 - 01/23/05 10:57 PM Re: Wheel Bearing Replacement...
Buck268 Offline
Box body's had the bearings in the rotor like my '91 Camaro... 92+ vics have the sealed fronts (itegral hub).
#629836 - 01/24/05 01:08 AM Re: Wheel Bearing Replacement...
Kinger87 Offline
Loc: Gladstone MI
Those listed in the auction won't work. The wheel bearings on these cars have the studs and everything on them. I personally wouldn't worry about them, they hardly ever fail, and at nearly 100 dollars replacement cost, its just as well.
#629837 - 01/24/05 01:55 AM Re: Wheel Bearing Replacement...
Steve83 Offline
5 registered (mrti, Gee_Oh_Dee, MIAMI-DADE, Sakoulas, 1 invisible), 45 Guests and 116 Spiders online.
Moby_Vic 188
a_d_a_m 159
BigMerc96 139
Chaplian 109
White99MGM 108
EZlivin11 104
DudeAbides 96
charlieD 87
RF_Overlord 86
SocalSam 83
