#635969 - 01/31/05 05:34 AM OBD-II codes PO 172 & PO 175 WTF?
Bryan_S. Offline
Loc: Olean, NY
These codes are for "System to rich" Banks 1 & 2. Well , this may explain why I am using so much gas. I just don't know what is tripping the codes. My only guess is so far that I had lost an exaust donut and was running for about 2 weeks with the driver side pipe unattached simply because I was not going to mess with it in -20 weather. Recently got it back together. Few days alter these codes. Is the computer trying to get used to the exaust being fully functional again after "getting used to" haveing it the other way? I'm going to disconnect my battery when I get home for an hour or 2 then try it again to see if clearing it all and resetting will helps.
Any theories?
Bryan
sig is too long, reduce please -jt
#635970 - 01/31/05 09:02 AM Re: OBD-II codes PO 172 & PO 175 WTF?
JBLU24 Offline
Loc: NYC
#635971 - 01/31/05 04:39 PM Re: OBD-II codes PO 172 & PO 175 WTF?
Islandvic2 Offline
Loc: South Texas
I had same codes. I cleaned MAF and replaced both before cat 02's.
Problem never came back.
Fuel efficiency went up afterwards.
My experience may be different from yours though.
Good luck.
#635972 - 01/31/05 09:48 PM Re: OBD-II codes PO 172 & PO 175 WTF?
Rogerm60 Offline
Loc: Zinzinnati
Check fuel pressure and the ECT too.
2006 P71, Black on Black. Installing camera system and getting road ready.
#635973 - 01/31/05 10:34 PM Re: OBD-II codes PO 172 & PO 175 WTF?
1BADMERC Offline
Loc: one foot in the grave
Sounds like it could be an O2 sensor issue
1993 GM LS
243k miles
1994 Lincoln Mark VIII
144k miles
Mercury Owners Group
This is a disclaimer:
#635974 - 02/01/05 01:07 AM Re: OBD-II codes PO 172 & PO 175 WTF?
Steve83 Offline
See if there's gasoline in the red vac line to the FPR.
#635975 - 02/01/05 01:39 AM Re: OBD-II codes PO 172 & PO 175 WTF?
Bryan_S. Offline
Loc: Olean, NY
I'll clean the mass air sen tommorow. I had an exaust leak on the drivers side and the obd codes site above listed an exaust leak before the 1st O2 sensor. This was fixed almost 2 weeks ago though and I have erased the codes 2x up to this date and they keep coming back.
God, I hope it's not the O2 sensors.....
Bryan
Moby_Vic 173
a_d_a_m 141
BigMerc96 135
White99MGM 107
EZlivin11 103
Chaplian 101
charlieD 96
SocalSam 83
RF_Overlord 80
2468 80
