#814785 - 11/11/05 10:01 AM Power Seat wiring harnesses?
metroplex Offline
Loc: Motor City, USA
I was trying to disable the seat belt switch (to perma-disable the beltminder) and found a bunch of unconnected harnesses below my seat.
The wiring led to somewhere underneath the carpeting.
Is this a provision for a driver power seat?
#814786 - 11/11/05 10:21 AM Re: Power Seat wiring harnesses?
tbug Offline
Loc: Michigan
I'm pretty sure it is.
Previous Panthers
Grand Marquis
1986, 1993
Crown Victoria
1994, 1998
#814787 - 11/11/05 06:12 PM Re: Power Seat wiring harnesses?
DaBigBR Offline
Loc: Iowa
IIRC, all panthers come prewired for power seats (at least on the driver's side). I found this in my 2000 PI, and I would guess they do it as a cost saving measure, i.e. it's easier to wire every car for it then to pick and choose...kinda like cruise control.
Brad Reinhard - Back...in Deep Wedgewood Blue
2003 Police Interceptor Street Appearance
-Deep Wedgewood Blue Clearcoat Metallic
-All cloth and carpet, no holes anywhere.
-Motorola Spectra 800MHz Smartnet (C7)
#814788 - 11/18/05 04:14 AM Re: Power Seat wiring harnesses?
Captain J Offline
Loc: USA AOK!
So the harness is there in my 2000 PI as well so dose that mean I can just buy a power seat, plug it in, and it will work?
Joe
2007 CVPI (Last one was a 2002).
Mods: Paint job and a detail.
R/T Charger with more mods then can be listed (Pro Charger SC, Heads, Cam, ect...)
http://au.youtube.com/watch?v=sWS-FoXbjVI&feature=related
http://au.youtube.com/watch?v=pKFKGrmsBDk
#814789 - 11/18/05 02:05 PM Re: Power Seat wiring harnesses?
DaBigBR Offline
Loc: Iowa
Yes, assuming that you have a way to control the seats. If it were me, I would not settle for seats w/o controls mounted on the seat, I would imagine that adding them to the door would be a PITA.
On your 2000, I think only the driver's side will be powered, but it is not that difficult if you get a power passenger's seat to figure out how to make it work.
#814790 - 11/18/05 09:38 PM Re: Power Seat wiring harnesses?
Da Governator
Power Seats: 1995+ P71 and P73 models have a 6-way power adjustable drivers avaliable as optional equipment. Adjustment options include front seat height up/down, rear seat height up/down, and seat position forward/backwards. Controls for the seat are mounted on the seat itself. 1995+ P74 models and 2003 police models are avaliable with 8-way power seats, in addition to the 6-way power features there is also a motor to control the recline position of the seatback. Seat controls are mounted on the door. To add power seats to a car not currently equipped, one needs the seat tracks, wiring and switches. A note about the wiring: On 1995+ vics, the power wire for the 6-way power drivers seat (black with small white stripe) is on the same connector as the seatbelt buckle sensor wire. Adding a 6-way power seat to a 1995+ vic is "plug and play" if you've got the tracks, switch and jumper harness. On topic of 8-way power seats, the wiring for the seats in the door and under the carpet is contained inside the 14a005 body harness. This harness also contains wiring for the power windows, locks, keyless entry system, variable assist steering and rear air suspension. If you've got the factory keyless entry system in your car, then there is a high probability that your car is prewired for 8way power seats. And if you've got rear air suspension (i.e. hpp crownvic), the odds of having the 8way power seat wiring in place increase even more. Similarly, if you've got an 8-way power drivers seat, you're chances of having the 8-way wiring in place for the passengers seat are extremely high. But if you've got a 95-02 police cruiser, your odds of having the 8way seat wiring factory installed are close to zero percent. 1992-1994 crown vics were also avaliable with 8-way power seats, but the controls were mounted on the side of the seat not on the door. Note that you do not gain any new functionality per say if changing from 6-way to 8-way power seats, the manual lever for the recline is replaced with an electric motor so instead of pulling a lever on the seat while leaning backwards, you push a switch. But having an electrically adjustable backrest does increase the number of positions that it can be set to because the manual backrest recliner only clicks into a certian number of pre-set slots while the electric one is infinetly adjustable.
From 2vmodular's site
RIP 2vmodular
#814791 - 12/27/05 06:20 PM Re: Power Seat wiring harnesses?
P71CNG Offline
I read this thread and went to 2vmodular's site.... awesome info there by the way. I got some '99 Grand Marquis leather seats and the door panels with mounted switches in the doors. I need to find out how to wire themm up to my '98PI, which has only two wires coming out of the carpet. Do you guys know how to figure out what jumper wire harness I need to buy to make this work. I hop e I don;t have to make a custom harness... that is a real PITA. Thanks in advance for any help... my dealership has not been any help by the way.
#814792 - 12/27/05 09:08 PM Re: Power Seat wiring harnesses?
Da Governator
Not suprised
I would jsut make it, can't be too hard...
RIP 2vmodular
#814793 - 01/14/06 05:14 PM Re: Power Seat wiring harnesses?
Steve83 Offline
I just pulled a '93 seat with full controls on the base & power recline, but drock's quote from 2vm indicates this should only be on '95-up. I've already stripped the (whorehouse red) upholstery.
Anybody need a red driver's seat cover? I even washed it!
Moderator:  BigMerc96, Quasar
9 registered (Bangster, Fordiesel69, 1990CrownVic, LSE_Dave, mrjon1985, 1 invisible), 46 Guests and 79 Spiders online.
NM117 324
RF_Overlord 129
EZlivin11 126
Moby_Vic 126
BigMerc96 124
Chaplian 115
mdnos 97
Ezbok58a 94
a_d_a_m 92
Ponyguy 91
