#818725 - 11/18/05 09:15 PM Anyway to unlock steering column without key?
Tiggie Offline
Loc: Moneta, VA
Well, Boxes are addictive. I just bought an '87 today to go with my '82 I got in May. LOOOOAAAADDDED! Got it for $300, including towing and title.
The car didn't come with keys and I'd like to be able to steer it, and start it for that matter. I think I could get around the starting problem, but the steering wheel will still be locked.
Are there any alternatives to unlocking the steering wheel besides pulling the ignition switch out with a dent puller? I got into the trunk using an '87 T-bird key, but I have tried all the Ford keys I have and none of them work the ignition. I got about 15 more in the family, i'm going to try them whenever I can get my hands on them. Anyone got any ideas?
1982 LTD Crown Victoria - 302/VV, WR-AOD, Slicktop Conversion SOLD 06/07/08
1988 Crown Victoria LTD Wagon - Accidentally Tu-Tone, Dual 'Packs on Modified Sedan Tails
#818726 - 11/19/05 08:52 AM Re: Anyway to unlock steering column without key?
Cougrrcj Offline
All Panther, all the time!!!
Loc: N.E. Ohio
Pull the steering wheel, then jam the locking pawl down (wedge it in place), then replace the wheel. OR while you're in there, drill out the ignition lock pin and replace the lock.
89 Crown Vic LX - daily driver - 393 stroker/ WR-AOD!!! New Best ET - 13.068 Best MPH - 106.58, Best 60' - 1.86
#818727 - 11/19/05 10:34 AM Re: Anyway to unlock steering column without key?
Fairmont_Kevin Offline
Loc: Sarasota, FL
Get real friendly with a locksmith. They have huge rings of keys containing every possibile combination. Borrow it, try them all, then ask him to make you the right key.
If the borrowing thing doesn't work out, pay him to do it.
#818728 - 11/19/05 06:34 PM Re: Anyway to unlock steering column without key?
Tiggie Offline
Loc: Moneta, VA
Well since I didn't have the time to befriend a locksmith, and I'm too tight to pay one, I decided to do some drilling. I first drilled the pin and tried to pull the switch out. No luck. I actually broke the end off the switch trying to pry it out. I said well. Now that sucks. I took a drill and just started drilling the tumblers and cylinder. About 5 minutes later, the switch, or what was left of it, fell out and I could move the switch activator freely. Steering was unlocked as well as the shifter. And yup, it runs decent(it's got a miss, I'll check that out tomorrow), and the tranny shifts firmly. Yes, it looks like I'll be getting second gear in my good Vic.
#818729 - 11/19/05 11:45 PM Re: Anyway to unlock steering column without key?
Pooka Offline
For future reference:
Disconnet the battery.
Remove the steering wheel and all the plastic covers. Be careful with the "ring" cover if you have a tilt wheel. In fact, it really can stay on the car as removing it will not help.
Drill out the lock tumblers. Careful here; don't drill too deep.
Grab the chrome part of the lock (the part you twist) with a pair of pliers and turn like you are starting the car. Put the lock in the run position.
Push in the locking pin. Refer to a manual for its' location.
Pull the lock mech. out and disconnect the wire from the loom.
Install a new lock as the lock cannot be repaired.
If your gear indicatior is not lining up with the PRNDL as it shoud this is an excellent time to adjust it. This has nothing to do with the lock, but it is tough to get at except when all the covers are removed.
Pooka
#818730 - 11/26/05 02:22 AM Re: Anyway to unlock steering column without key?
BoxMan Offline
Loc: Millville, PA
Moderator:  88grandmarq, a_d_a_m, MAFpilot
6 registered (Sakoulas, mrti, DC_Dave, MIAMI-DADE, olschoolsteel, 1 invisible), 47 Guests and 118 Spiders online.
Moby_Vic 188
a_d_a_m 159
BigMerc96 139
Chaplian 109
White99MGM 108
EZlivin11 104
DudeAbides 96
charlieD 87
RF_Overlord 86
SocalSam 83
