#907177 - 03/28/06 05:45 PM Check Fuel Cap light & Check Engine light on.
GaCrownVic Offline
Loc: Greenwood, IN
I just purchased a 2002 P-71. After the first fill up, the Check Fuel Cap light came on. The next day, the Check Engine light came on. I took it to AutoZone and they told me the codes were 455 and 457. They told me to replace the gas cap (which I did) but the lights did not go out. I was told that I would have to drive the car approximately 200 miles before the lights would go out. Is this true or are they just giving me a line of BS?
2002 P71 - Former Alabama State Trooper Police Car.
1994 P71 - Former Gwinette Co. Ga. Police car.
#907178 - 03/28/06 06:52 PM Re: Check Fuel Cap light & Check Engine light on.
cvpi71 Offline
Mr. Kozmo
did you turn the key off/shut off engine when you fill up? You should!!! some car are more sensitive then other. one of the PI at work is a 02 and if you don't shut the engine off prior to gassing up the CEL will come on.
R.I.P Elfy 6/06
97 PI
#907179 - 03/28/06 07:20 PM Re: Check Fuel Cap light & Check Engine light on.
GaCrownVic Offline
Loc: Greenwood, IN
Yeah, I always shut off the engine before filling up.
#907180 - 03/28/06 08:39 PM Re: Check Fuel Cap light & Check Engine light on.
Da Governator
Yes it will take iirc 3 full driving cylces for the codes to go away if it was infact the fuel cap.
Alternatively you can disconnect your battery for ~15 mins and all the codes will be cleared
RIP 2vmodular
#907181 - 03/28/06 08:39 PM Re: Check Fuel Cap light & Check Engine light on.
cvpi71 Offline
Mr. Kozmo
or clear the codes with a scanner
R.I.P Elfy 6/06
97 PI
#907182 - 03/28/06 11:37 PM Re: Check Fuel Cap light & Check Engine light on.
rhyx Offline
Loc: Gainesville, FL
Isn't it against the law to fill up without shutting off the engine? There's warning signs all over the place at gas stations here.
/fill up without shutting car off = boom
Current Vehicle: 2009 Hyundai Genesis 3.8 Premium Plus
Former Vehicle: 2001 Crown Victoria LX
#907183 - 03/28/06 11:45 PM Re: Check Fuel Cap light & Check Engine light on.
DBellPSU Offline
Loc: NJ
hmm... I guess my car is weird then. When I first got my 2001 CV used in 2003 the check engine light was on and the dealer told me it was because the gas cap was bad and needed to be replaced. Yet I can leave the engine running when I fuel up and it doesn't trigger the cheeck engine light.
#907184 - 03/29/06 12:53 AM Re: Check Fuel Cap light & Check Engine light on.
GhostRider Offline
Didnt know there was ever a Check Fuel Cap light. Do you mean the Check Engine Light?
-Tim
#907185 - 03/29/06 01:27 AM Re: Check Fuel Cap light & Check Engine light on.
RyPow Offline
Loc: Guelph, Ontario, Canada
Can't speak for the analogue dash, but on my GMQ's digital dash there's a CHECK FUEL CAP light between the bar graphs for temp and fuel. Luckily I haven't seen it lit up yet Check engine is right above/below (can't remember) my TRAC OFF light, to left of speedo.
RyPow
The "Sand Box": 1987 LTD Crown Victoria LX - 73K, towing package (3.55 Trac-Lok, duals, 11" drums, HD water pump), no winters, second owner.
Add-ons: TripMinder
The Towny: 1985 Lincoln Town Car Cartier, previously owned by 'navguy12' on thelincolnforum.net
Projects: 1978 Lincoln Mark V Diamond Jubilee Edition, 460 EFI/E4OD swap
Others: 2012 Ford F-150 crew cab 5.0L 4x4, 2004 Buick LeSabre Custom w/Gran Touring pkg
#907186 - 03/29/06 01:29 AM Re: Check Fuel Cap light & Check Engine light on.
Ryan Offline
Loc:
Same here, must have been an addon for 2002.
#907187 - 03/29/06 05:40 AM Re: Check Fuel Cap light & Check Engine light on.
GaCrownVic Offline
Loc: Greenwood, IN
The Check Fuel Cap light is beside (to the right and slightly higher) the Check Engine light.
#907188 - 03/29/06 09:54 AM Re: Check Fuel Cap light & Check Engine light on.
Bangster Offline
2001+ got it, this is from the 2002 owners guide:
1130245-2002 gauges.gif (292 downloads)
1974 Honda cb400
#907189 - 03/29/06 06:37 PM Check Fuel Cap light & Check Engine light on.
GaCrownVic Offline
Loc: Greenwood, IN
Thanks everyone for your advice. After driving the car for 250 miiles the lights still would not go out. Tried the battery disconnect and it worked fine.
#2420087 - 12/07/11 06:13 PM Check Fuel Cap light & Check Engine light on. [Re: GaCrownVic]
bocap71 Offline
Loc: Florida, USA
Maybe one of you experts can help me. Got a 03 CVPI. 105K miles, runs great... but the stinkin' check engine light will not stay off. Had two different mechanics do smoke tests, told me it was fixed....two days later the light is back on. NOW the Check Fuel Cap light comes on -- but very strange -- I clear the codes with a scanner when I fill up, but every time the fuel guage reads 1/4 down the Check Fuel Cap light comes back on. If I clear the codes, the light stays off until I fill up again, and the light stays off until the fuel gauge reads 1/4 down again. Every time. Have changed gas caps twice. No effect. Do I have a gas tank problem here? Is it possibly the float thingie that monitors how much gas is in the tank? Run out of ideas, and patience. HELP !!
#2420317 - 12/08/11 12:48 AM Re: Check Fuel Cap light & Check Engine light on. [Re: bocap71]
Piranah Offline
Loc: Iowa
Try this. OP, you might want to try it as well.
CLICK ME
Former Panthers:
01 Grand Marquis. Sold
1994 Lincoln Town Car. Gone.
Moby_Vic 173
a_d_a_m 141
BigMerc96 135
White99MGM 107
EZlivin11 103
Chaplian 101
charlieD 96
SocalSam 83
RF_Overlord 80
2468 80
