#924026 - 04/21/06 08:59 AM Reset KAM and PCM
MGM95 Offline
Loc: the Netherlands
I have the 95 Ford cd,but i have some questions about it.
When i reset the PCM with my Kal scanner,is KAM alsoo cleared?
Mercury Grand Marquis LS HPP 1995
160000km.
Tires front and rear: Bridgestone 960 A/S Pole Position. Installed: Feb 2007.
#924027 - 04/21/06 10:16 AM Re: Reset KAM and PCM
dlgintn Offline
Loc: Tennessee
No. Disconnect the negative battery cable for 5 minutes.
__________________________________
99CV, HPP
#924028 - 04/22/06 06:08 AM Re: Reset KAM and PCM
MGM95 Offline
Does someone know by the way what rpm should be at hot idle with no ac and accessoires?
160000km.
#924029 - 04/22/06 06:17 AM Re: Reset KAM and PCM
Captain J Offline
Loc: USA AOK!
690? My car is at 890ish at cold temp.
2007 CVPI (Last one was a 2002).
Mods: Paint job and a detail.
R/T Charger with more mods then can be listed (Pro Charger SC, Heads, Cam, ect...)
http://au.youtube.com/watch?v=sWS-FoXbjVI&feature=related
http://au.youtube.com/watch?v=pKFKGrmsBDk
#924030 - 04/22/06 06:44 AM Re: Reset KAM and PCM
MGM95 Offline
My RPM is now 796-810 (HOT) with nothing on except of course the engine.
160000km.
#924031 - 04/22/06 09:05 AM Re: Reset KAM and PCM
dlgintn Offline
Loc: Tennessee
802-820 in Park at idle.
99CV, HPP
#924032 - 04/22/06 10:20 AM Re: Reset KAM and PCM
Fordiesel69 Offline
Loc: Erie, PA
If you have the true P71 programming, the idle will be slightly faster to keep the alt charging more efficiently.
-'99 Crown Vic Police Interceptor (SAP), 3.55 Trac-Loc(DK), Cloth Interior, Black Honeycomb Grill, Black PI Trunk Bezel, Silverstars, 179K
-'08 Crown Vic Police Interceptor (SAP), 3.27, Cloth Interior, Smokestone Metallic, 132K / 3427 Hrs
-'05 F-150 4x4 - Extended Cab, 3.55's, Dark Blue w/ Grey interior, 221K
#924033 - 04/22/06 10:20 AM Re: Reset KAM and PCM
MGM95 Offline
Well i found some information on my service cd.
PCM Reset and KAM reset or two different things.
Strange thing is,i had no codes (alsoo no pending codes) and i thought: why not clear the codes and see what happening.
Well the car drives different in my opinion.
So if KAM was not cleared why does the car drives different?
Does it make difference when you pull fuse 12 (this was the fuse for PCM??) to reset KAM when engine is warm or cold?
Edited by MGM95 (04/22/06 12:33 PM)
160000km.
#924034 - 04/24/06 12:23 AM Re: Reset KAM and PCM
Steve83 Offline
Pulling the KAPWR fuse is better than disconnecting the battery because it doesn't clear the radio presets & clock.
Engine temp. will make a difference temporarily if you go driving immeditately since a warm engine will allow the EEC to adapt correctly sooner. But it will eventually reach the same performance adaptions even if you do it cold.
6 registered (GM_Guy, Thewolverine, a_d_a_m, Loafy, NM117, FCV96), 279 Guests and 14 Spiders online.
a_d_a_m 171
dpk 155
BigMerc96 124
Moby_Vic 113
WSTRLNG 86
reminc70 78
Ponyguy 75
RF_Overlord 65
Bellwestern80 59
SocalSam 48
