#987549 - 07/21/06 08:00 AM Where is the fuel tank pressure sensor?
LATEXBOY Offline
About to replace it in my 97 PI. Is it in the tank? Do I need to drop the tank? Thanks
Keep working. Millions on welfare depend on you.
#987550 - 07/21/06 12:45 PM Re: Where is the fuel tank pressure sensor?
JohnG Offline
Tech Admin
Loc: Socialist state of MN
The FTP sensor is (at least on the '99 I had) on the Passenger side upper corner, and yes you will need to DROP (not remove) the tank for access.
#987551 - 07/21/06 02:57 PM Re: Where is the fuel tank pressure sensor?
Steve83 Offline
IIRC, I snagged this from a '98 P71. The FP plate is on the front & the tank is right-side-up in the photo, so that puts the FTP on the R of the car, like JohnG said. If you look thru the wheelwell, you might be able to see it over the frame.
Lowering it a few inches should allow you to access it.
But WHY?
If you plan on removing it from the tank, I'd recommend dropping the tank & washing around the sensor before your remove it. Otherwise, you could dump a LOT of dirt into your tank. If you do remove the tank, buy a new filler neck O-ring first. Use ONLY clean motor oil to lube it (or anything else on the fuel system) for easier install.
A few cans of Berryman B-12 Chemtool will allow you to rinse out the check valve on the filler neck. That'll make it easier to fill the tank. This junker was nasty before I washed it.
#987552 - 07/21/06 03:51 PM Re: Where is the fuel tank pressure sensor?
Mileaway Offline
Loc: Sacto. Calif.
does that part have a hose connecting from the filler tube to the tank with a little plastic gadget attached along with a rubber boot of some kind?
Tall Tale>origin..
possible existence of giants maybe?
#987553 - 07/22/06 01:24 AM Re: Where is the fuel tank pressure sensor?
Steve83 Offline
Uuuuuuhuhuh... No.
25 registered (03RedVicSport, BEAT_TRASH_05CV, ARRG, 1990CrownVic, Bellwestern80, 2 invisible), 40 Guests and 64 Spiders online.
KayTar 588
CNGInterceptor 390
sm41 355
Black_Sunshine 283
BlackVic_P71 276
Ezbok58a 253
ajdereicup 246
Moby_Vic 239
BigMerc96 228
Superhobo 214
