Page 2 of 2 < 1 2
#2856240 - 08/20/14 03:46 PM Re: The importance of your Exhaust Dampers [Re: 1 Adam 12]
73vwTodd Offline
Loc: Florida
Hey, sorry to bump this, but does anyone have a better picture or understanding of where those "other" exhaust resonators go? The normal ones (the big cyl ones with the bracket that attaches between the H-pipe and cat-back) is pretty common, but that other one (in the picture above, it's laying underneath / perpendicular to it), I could not find on ANY Panther in the Junkyard and there were ~20 maybe of varying years from 1994-2008. I did see on one car (forget which year, maybe a newer Grand Marquis) that it had smaller cans welded to the side of the mufflers, but definitely didn't look like those.
#2856249 - 08/20/14 04:44 PM Re: The importance of your Exhaust Dampers [Re: 1 Adam 12]
Wags4000 Offline
Loc: Northumberland, PA
I've seen it before but can't remember where....it's held on by the bolds on the clamp at the front of the muffler. you put the two pieces of the clamp on the pipe and then put the damper on the U-bolt before putting the nuts on. it sticks straight out to the side like the ones do at the CAT/H-Pipe connection.
2003 CVLX; 312k mi (perch 103k); P74; Black Paint/Black leather; Blinking side marker mod; 2.73 open dif; Autolite Dbl Plat; General Altimax RT43; LCM Ext relay, FRPP mani; Max-Life 5w-30
03 Crown Victoria LX by Wags4000, on Flickr
2001 Merc GM LS; RIP at 340k mi (bought at 67k)-my former commuter. Finally passed on due to no one driving it and things just stopped working.
1986 Merc GM LS; 165k mi (bought at 118k)- Red with White vinyl half roof; 5.0L; RIP
87 Caprice Wagon; 356k; 5.0L(307cu) RIP
#2856278 - 08/20/14 07:36 PM Re: The importance of your Exhaust Dampers [Re: Wags4000]
73vwTodd Offline
Loc: Florida
Ahhh... ok, that makes perfect sense. So it basically bolts onto the back of the exhaust clamps. I'm willing to bet those are like the first things to go... especially because when people put on new mufflers or a sportier exhaust, those just get tossed by the exhaust shops... frown that would make sense as to why I didn't see any of them. It was weird though, because there was ONE car which had something like that basically welded onto the side of the mufflers.
#2856374 - 08/21/14 10:53 AM Re: The importance of your Exhaust Dampers [Re: 1 Adam 12]
Wags4000 Offline
I searched around and there is nearly zero info on that damper. the best I found was a graphic of it on tasca listed for an 03 grand marquis, but it wasn't available to buy and it didn't list a part number.
see part 16
#2856493 - 08/21/14 11:24 PM Re: The importance of your Exhaust Dampers [Re: 1 Adam 12]
Wags4000 Offline
So i got under the 03 today thinking that maybe i had seen that damper on the muffler.....but...no damper...and no F'n clamp either! Wtf how does a clamp just rot off and go bye bye?!?! Been wondering why my car has a random exhaust growl. Its not constant and usually only happens when its raining hard and i hit the gas to pass on the highway.
#2856570 - 08/22/14 01:57 PM Re: The importance of your Exhaust Dampers [Re: 1 Adam 12]
winterbeater Offline
Loc: Michigan
I've always tossed those dampers on numerous cars without any bad effects that I have noticed. The quiet freak engineers add them in if they can't engineer a perfectly quiet system without adding weight.
2006 LX Sport
1999 Special Edition
RIP (2000 Cherokee) working on 4x4 replacement
Honda 500CR
#2856582 - 08/22/14 03:04 PM Re: The importance of your Exhaust Dampers [Re: 1 Adam 12]
1 Adam 12 Offline
Loc: Glendale, AZ
I'd like to see pics of that, my mechanic told me the left one would not bolt up to the cat/pipe joint because it was hitting something, which makes sense since all the diagrams I've seen call for one on the right, then on the left it's at the muffler clamp, even on Ford's website.
Prior to 03 or 04, all dual exhaust used the single exhaust layout in the 1st pic, and they changed it due to the redesign.
Here is my 07's Exhaust pictures:
~Chris~
2007 Smokestone LX HPP - 17.5K miles 1/2016
'05 PI Airbox/Ziptube, BOC 91 Octane Tune, PowerSlot F&R Rotors, Raybestos Police Patrol Pads F&R, 260A Mechman Alt w/OAD & Big 3, Ported Intake Plenum, Adco Front & Rear Swaybars, Metco Control Arms, Metco Watts Link, KYB Police Struts/Shocks F&R, Arnott HPP-spec "Limo" rear bags, Walker Quietflow 3's w/Resonator delete, 3.55 TracLoc conversion, 180 T-Stat, 22C Plugs, GY Eagle Sport AS Tires, Kenwood DNN992 Nav Headunit & Speakers, Viper 5901 Alarm/Remote Start & Street Guardian Dashcam
MY ARTICLES
Pulleys for Police Alternators | Replacing Door Weather Barriers | Exhaust Dampers and their importance
#2856638 - 08/22/14 11:26 PM Re: The importance of your Exhaust Dampers [Re: 1 Adam 12]
Wags4000 Offline
Both my 01 and 03 have a damper on both cats....both are single exhaust.
#2856648 - 08/23/14 12:10 AM Re: The importance of your Exhaust Dampers [Re: 1 Adam 12]
My 07 single exhaust is like the first pic. I never noticed before where they are on the cvpi. I'll have to look sometime.
#3159714 - 04/16/16 07:38 PM Re: The importance of your Exhaust Dampers [Re: 1 Adam 12]
bigROC209 Offline
Loc: Stockton, CA
Damn, when I got my 2-1/4" catback installed the shop tech removed those dampers. He told me they were counter-balance weights for only single exhaust cars. Damn it! I do have a slight drone that I'm sure those damper weights would have absorbed.
2002 Marquis LS Precision Trac, new engine @ 125K, GT Wheels, HP tires, SCT Xcal 2, 91 Octane tune from BOC, Traction Locker w/Ford Racing clutches, 3.55's, Police D/S, Ford Racing IM @114K, 75mm TB, Trick Flow Plenum, Ziptube, GT MAF, P71 Rear Coils, Summit Racing UDP's, HPP Sway Bar, Gas KYB's, J-Mod, 2-1/4" Dual Exhaust, Thrush Glasspacks & 18" tips, MSD COPs, NGK TR55's & Grey Injectors, Pinstripe removed, Disc changer, 2400 watt Pioneeer amp & 6x9's, Kicker Comp VR 10" DVC subwoofers.
Bottle in the trunk coming soon!
#3159786 - 04/16/16 08:47 PM Re: The importance of your Exhaust Dampers [Re: bigROC209]
I'll bet they would at that! I know that when I went to duals using factory system for same car and left them off I got noise and adding them back killed the drone like vibration.
________________________________________ ____________________
Problems huh? Then Read THE Book. Signed: Natural Borne Neanderthal .
#3655546 - 06/06/17 11:09 AM Re: The importance of your Exhaust Dampers [Re: 1 Adam 12]
TecNickal Offline
Loc: Blythewood, SC
Sorry to respond to an old thread, but all three of my 2003 TCs do not have these large exhaust dampeners.
On the H pipe however, a little back from the join with the cats, there are some itty-bitty ones. They are welded to the H pipe.
And looking under a couple of 04s - one was an L car and the other was a standard, they had the same setup as my 2003.
So these larger dampeners on 2003+ are for CV and GM only.
-66 Country Squire, 89 Colony Park, 03 540iT
-90, 3x 03, 06, 07 LTC
-04 F150 Reg Cab Long Bed
#3655594 - 06/06/17 12:24 PM Re: The importance of your Exhaust Dampers [Re: 1 Adam 12]
2kGM Offline
Loc: NW Virginia, USA
I wouldn't be surprised to find out that the part numbers of the TC exhaust in that year range are completely different, resulting in different resonances, and therefore the need of different damping.
The purpose of the dampers is to keep the pipes from resonating like organ pipes at particular engine RPMs. If the plumbing is different shaped, you can move the resonant point out of the operating range of the engine and do away with the dampers. A little quality time with a computer acoustics design program could have made the need for dampers go away entirely if Ford bothered to redesign things. If production cost was higher for the TC exhaust, or there was an existing supply of parts to use up, Ford would have elected to keep using the old design on the CVs and GMs.and would have kept the new/fancy design for the TC only.
1999 Grand Marquis LS HPP with PI intake manifold, mild J-mod, Class III hitch, KYB PI shocks.
2000 Grand Marquis GS with no options and mild J-mod - Sold to Father-in-law
Page 2 of 2 < 1 2
3 registered (KMBT, GM_Guy, RF_Overlord), 139 Guests and 15 Spiders online.
speedfreak 27
PrincePolaris 20
Traffic22 15
