#2893128 - 04/24/15 10:56 AM 408 Blueprint Engines
BIGTYLTD Offline
Loc: NY
Hello everyone!
I own a 1989 Crown Vic which had a stroked 347, that did not work out for me. I'm now waiting on a 408 from Blueprint Engines and a Lentech AOD Street TT. I have an EFI set up with Fiveology mass air conversion kit which I want to reuse. What intake manifold would suit me best without giving me hood clearance issues? Thanks in advance for any info!
1989 Crown Victoria LX; HID conversion, dual exhaust 2.5 from the headers 2.25 out the rear, Flow master Super 44s, Powertrax No-Slip differential, Denny's aluminum driveshaft, K&N air filter, new BFGoodrich tires, Perfect Launch 8.8 Differential Cover, 3.73 gears, gauges, 408 Blueprint engine, Lentech AOD street terminator transmission full manual w/trans brake, B&M rachet shifter, Trick Flow upper intake etc etc...Sleeper mode! 2015 STI
#2893133 - 04/24/15 11:45 AM Re: 408 Blueprint Engines [Re: BIGTYLTD]
JeffBoudah Offline
Loc: Holland,MI
PICS!
Cam specs?
And i would do a vic jr. converted to efi with an elbow and a huge throttle body or no elbow and a 4150 style tb.
2006 MGM GS
1984 Colony Park
1979 Tudor
#2893151 - 04/24/15 03:54 PM Re: 408 Blueprint Engines [Re: BIGTYLTD]
BIGTYLTD Offline
Loc: NY
Cam Specs:
Roller
.543 Intake / .554 Exhaust
218 Intake / 226 Exhaust duration
@ .050 - 112 degree lobe separation
The engine and trans are in the build process....three more weeks
I have a 70mm BBK TB from the old engine....good?
#2893179 - 04/24/15 08:43 PM Re: 408 Blueprint Engines [Re: BIGTYLTD]
I guess the, 'Too much is never enough' applies. =-)
Alex.
#2893194 - 04/24/15 10:56 PM Re: 408 Blueprint Engines [Re: BIGTYLTD]
JeffBoudah Offline
Loc: Holland,MI
Originally Posted By BIGTYLTD
Cam Specs:
Roller
That's a pretty small cam for a 408. Lift at .600+ and 230/240+ on duration would still be very streetable. What heads do you plan to run? You'd probably need a 75-90mm on a single plane set up for efi.
2006 MGM GS
1984 Colony Park
1979 Tudor
#2893879 - 04/28/15 03:05 PM Re: 408 Blueprint Engines [Re: BIGTYLTD]
Packman Offline
Loc: Joisey
That cam is friggin tiny. My 351W cam has more lift at .565 and .574. See how you like it, you may end up swapping to a Bootlegger cam or better yet, a custom cam.
Packman
2005 Grand Marquis base model (analog dash and a cassette player *sigh*) Mods: SW long tubes, full 2.5" exhaust (cats and dynomax 17749 muffs), and K&N CAI
1986 Crown Vic Built 351W and AOD, BIG brake swap, 3.73R&P, etc....
#2900567 - 06/05/15 09:42 AM Re: 408 Blueprint Engines [Re: BIGTYLTD]
Cougrrcj Offline
All Panther, all the time!!!
Loc: N.E. Ohio
When discussing camshaft durations, a hydraulic flat tappet and hydraulic roller have little in common. The roller cam allows the valve to open at a much faster rate than a flat tappet will allow, so the 'area under the curve' of high port flow is much higher with a roller.
By 'Roller' cam, is this a retrofit (for non-roller block) or standard hydraulic roller for '94-97 roller cam 351W van/truck block?
While the lift is 'low' (in reality it is kept near .550 for stock piston-to-valve clearance), What concerns me more is the short 216/220 duration for the big stroker motor..
My 393W was originally built with a standard block and a hydraulic flat tappet cam with the short duration (216/224) for emissions reasons (needed to pass Ohio's sniffer test), but once the car became emissions-exempt, I went to a retrofit hydraulic roller with the same .550 lift, but a 276/282 adv duration (224/230 @ .050") and instantly gained close to 75hp (ETs dropped from 14.20s to 13.10s), with no other changes.
BTW, the problem with running an EFI in a 351W is the lack of decent EFI intakes for it! The hot setup used to be the GT40 intake from a First Gen (93-95) Lightning. But the Lightning upper was very tall, so you had to use the GT40 Mustang upper. Problem is the Mustang inlet is on the 'wrong' side for a Vic. Then we get to the hood clearance issues, of which I can't help you since mine is carbed... Just use this Summitracing.com search for EFI intakes for a 351W. linky here
89 Crown Vic LX - daily driver - 393 stroker/ WR-AOD!!! New Best ET - 13.068 Best MPH - 106.58, Best 60' - 1.86
#2901646 - 06/11/15 12:39 PM Re: 408 Blueprint Engines [Re: BIGTYLTD]
Packman Offline
Loc: Joisey
Trick Flow Box-R (the 90mm version for 351W) for EFI. For hood clearance issues, I found a Country Squire in the JY and nabbed the hood from that. Cut a hole in it and welded braces to the existing hood braces to stiffen it up a bit. Still haven't riveted the scoop on yet. Still need to find the space to do the engine swap as no apartments I've lived at will let me even change a tire in their lots.
Packman
3 registered (cv83, CarMon, Rootintootin), 110 Guests and 17 Spiders online.
speedfreak 28
LordAeneas 24
PrincePolaris 21
Traffic22 16
