#3587330 - 03/26/17 09:21 PM Best source for FPP intake, gaskets?
Donald Offline
Loc: Oxford, Ohio
I realize there are many posts here about intake replacement. I need current info about where to get the FPP M9424P46 intake, gaskets, and injector O-rings.
It would be nice to find one vendor who has everything.
Thanks in advance. Don
2004 Crown Vic LX Sport Plus in Midnight Grey Metallic with Light Flint Gray leather interior. Exterior paint code "TV." Built Feb. 16, 2004.
3.27 Traction-Lok rear axle from a 2010 CVPI w 46K.
Aluminum PI driveshaft with Fabtech spacer.
CVPI exhaust sans resonators.
KYB Police spec rear shocks.
#3587386 - 03/26/17 09:41 PM Re: Best source for FPP intake, gaskets? [Re: Donald]
Chaplian Offline
Insert witty title here
Loc: Chicago, IL
http://adtr.net/product/ford-crown-victo...ntake-manifold/
Chris @ adtr has everything you need excluding injector o-rings.
O-rings: You need to order 2 packs of these because each injector uses 2 o-rings. https://smile.amazon.com/ACDelco-217-336...injector+o+ring
Or go to your local autoparts store and just order o-rings there.
2011 Crown Vic LX- 78,xxx.
2003 Crown Vic HPP- 235,xxx miles. Retired.
1995 Impala SS- 29xxx miles. The Lovely Lady
2003 BMW 325i Wagon- 8250 RPM redline. Complete M3 drivetrain, suspension, and electronics. Taylor Swift.
2017 Mazda3 GT Hatchback- 90,xxxx miles. 2.5L, fully loaded. The Daily Grind.
#3587634 - 03/27/17 02:04 AM Re: Best source for FPP intake, gaskets? [Re: Donald]
stalag Offline
Loc: Columbus, OH
Being in Ohio, both Jegs in Columbus and Summit Racing in Tallmadge Ohio are both sources as well. Any part you disturb that has a seal, that seal will need replaced. Don't try to reuse any seal that is currently on the car. There is also a coolant tube that runs under the intake as well. Replace that only if leaking, but make sure you inspect it. Replacement of that part will mean lifting the intake again if you have to do this later. I don't know if the 98-02 coolant tubes are compatible, but if you need that I can let go of mine that I kept after not needing it the last time I had to replace my intake. The O-rings you can get anywhere, but the OEM gaskets are better than aftermarket in this case.
Stalag;___________Just for Rizzo I am posting this in my sig. Coolants
2001 Lincoln Town Car Cartier L Sent to graveyard
#3587770 - 03/27/17 09:44 AM Re: Best source for FPP intake, gaskets? [Re: Donald]
The uner-intake coolant tube can be broken down into a few years ranges. '92-'97, metal with a rubber section connecting to the back of the waterpump. '98-'00, same shape as the earlier one but all-metal, the nipple on the back of the waterpump is probably different than the earlier ones due to them using a couple o-rings to seal the tube instead of that rubber section with hose clamp. '01+ is a different routing, it routes up along the drivers side head rather than right down the middle of the valley, this was because the PI intake sits deeper into the valley of the engine and would hit the tube in the earlier location.
#3587890 - 03/27/17 01:07 PM Re: Best source for FPP intake, gaskets? [Re: Donald]
Donald Offline
Loc: Oxford, Ohio
Guys:
I have done business with both Summit and Jegs. No problems there, except they will charge sales tax. I wondered about the intake gaskets. It seems they are ~$50 for the pair.
I have not done much with injectors. I will be sure to give that coolant tube a good once over while I have the intake off.
The plan is to have everything needed on hand before I start the project.
Don
Edited by Donald (03/27/17 01:08 PM)
#3588122 - 03/27/17 04:43 PM Re: Best source for FPP intake, gaskets? [Re: Donald]
ChrisM_NY Offline
Loc: Saratoga, New York
I've used Felpro from the auto parts store. With online discount and in store pickup the set was 25 bucks
part no MS 96281
2007 CVPI SAP 115K/800hrs
#3588450 - 03/27/17 09:49 PM Re: Best source for FPP intake, gaskets? [Re: Donald]
Donald Offline
Loc: Oxford, Ohio
Chris:
Thanks for that info. An Autozone coupon popped up in my email today for 20% off of one item. I'll use it for the Fel-Pro gasket set.
:0) Don
0 registered (), 78 Guests and 8 Spiders online.
RF_Overlord 32
speedfreak 28
Bellwestern80 27
LordAeneas 24
PrincePolaris 21
Traffic22 16
