#1392198 - 02/09/08 02:26 AM replaced clockspring and now I'm pissed
mkfanatic Offline
Loc: Hamilton, OH
I found a brand new OEM clockspring on eBay, ordered it, and installed it today. My cruise control still doesn't work and my horn is still messing up. My horn will work continuously only when my car is turned off. When I turn the car on, the horn will honk once or twice then blow the fuse. WTF?
1993 Crown Victoria P74 (wrecked)
1995 Crown Victoria P72 (sold to junkyard)
Mods: P71 Computer
2003 Crown Victoria P74 Sport
Mods: MM MAF + Airbox and K&N Air Filter, 04 Zip Tube, 3.73 gears with trac-lok LSD, AMMC Driveshaft, Tailshaft w/ Forced Lube Mod, and 93 Tune from Lonnie @ BOC
mkfanatic Offline
Loc: Hamilton, OH
Mods: P71 Computer
#1392236 - 02/09/08 04:08 AM Re: replaced clockspring and now I'm pissed [Re: mkfanatic]
DeadHeadP71 Offline
Loc: Indianapolis, IN
Probably nothing to do with your clock spring, sorry to say. Really try and check the wires going up to the steering column. This sounds like a simple short to ground somewhere, that's why you're blowing fuses. Check for any frayed or damaged wiring and repair it. It's the number one cause of a blown fuse, so give things a good check and you'll probably notice a wire rubbing on bare metal.
BF Goodrich Control Plus
#1392562 - 02/09/08 02:08 PM Re: replaced clockspring and now I'm pissed [Re: DeadHeadP71]
mkfanatic Offline
Loc: Hamilton, OH
Well then why doesn't the cruise control work?
Mods: P71 Computer
#1392566 - 02/09/08 02:14 PM Re: replaced clockspring and now I'm pissed [Re: mkfanatic]
DeadHeadP71 Offline
Have you checked the fuse for the cruise control, I can't remember if it's under the dash or in the engine bay. Either way check that out to see. A short to ground explains your problem, just look for some damaged wiring.
#1392569 - 02/09/08 02:15 PM Re: replaced clockspring and now I'm pissed [Re: mkfanatic]
Bull Offline
Contract Cleaner
Loc: Dayton Ohio
Because the cruise and horn are on the same circuit.
You have a short somewhere, you will need to isolate where it is and repair it. I am in the Dayton area, I may be able to help.
B
"Chaos, panic and disorder... my work here is done."
#1393449 - 02/10/08 06:30 PM Re: replaced clockspring and now I'm pissed [Re: Bull]
BP71 Offline
Maybe take a look at this thread,
http://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Main=93084&Number=1277056#Post1277056
It does sound like one of the two horn wires is pinched to ground if it's anything like the one I was working on. I almost missed finding the pinched wire in the above post because it really blended it with the surroundings inside the steering wheel.
#1393916 - 02/11/08 06:29 AM Re: replaced clockspring and now I'm pissed [Re: BP71]
Timmn1 Offline
Loc: Near I-80 & I-57
Not to hijack this thread, but what is a clockspring supposed to do?
1997 Grand Marquis - Started out life as a rental car in Milwaukee.
Mods:
Functional oil pressure gauge
Shark Plenum + Aviator throttle body
Headlight wiring
"Life after death is as improbable as sex after marriage!"
Comments
Offline
Moby_Vic 173
a_d_a_m 141
BigMerc96 135
White99MGM 107
EZlivin11 103
Chaplian 101
charlieD 96
SocalSam 83
RF_Overlord 80
2468 80
