Page 2 of 2 < 1 2
#1025654 - 09/16/06 02:33 PM Re: Ford rear fascia and tail lamp black trim
Dextrovic Offline
Loc:
IPS Corp. makes a line of Weld-On industrial adhesive solvent cements that can work wonders on ABS/acrylic and other compatible plastics.
Said cements work just like PVC cement but on various other non-PVC plastics as well. The result is a permanent welding of the plastics together. The same application and fitment procedures apply.
That said, check with a local plastics supplier.
#1025655 - 09/16/06 09:06 PM Re: Ford rear fascia and tail lamp black trim
metroplex Offline
Loc: Motor City, USA
Do I want to use the yellow 3M weatherstrip adhesive or the black?
#1025656 - 09/16/06 10:04 PM Re: Ford rear fascia and tail lamp black trim
Steve83 Offline
I've never had much luck with either, but the yellow is best suited to bonding vulcanized rubber. Make SURE you follow the instructions on the tube TO THE LETTER or it won't bond right, and you'll just have yellow snotwads hanging off your taillight.
That said...
I'd recommend NAPA's RightStuff. It's a neoprene foam rubber adhesive that's amazingly effective on just about anything. It goes on thick, so you'll have to use it sparingly, and it gets tacky FAST so practise on something else. If you get some coming out of the seam, just leave it alone until it dries, then clean it up with a razor knife.
#1025657 - 09/16/06 10:08 PM Re: Ford rear fascia and tail lamp black trim
VA P71 Offline
Smartass
Loc: CONUS
Someone suggested Automotive Goop (The Amazing Goop): http://www.amazinggoop.com/
I have used that stuff on plastic (vehicle exterior) and it's still working 6 months later and does not appear to be coming loose.
2001 CVPI & 2004 Expedition
#1025658 - 09/16/06 10:21 PM Re: Ford rear fascia and tail lamp black trim
dragoncvpi Offline
Loc: florida
I used the yellow and it worked well for me.
Gone but not forgotten
#1025659 - 09/17/06 03:50 PM Re: Ford rear fascia and tail lamp black trim
metroplex Offline
Do you recall the part #?
I found 08002 at a local store in black packaging, and according to the 3M tech sheet, 08001 and 08002 are the "yellow" but every website shows 08001 with "black" on the label.
I want the yellow gorilla snot that will permanently bond ABS and PMMA plastic pieces together.
#1025660 - 09/17/06 07:51 PM Re: Ford rear fascia and tail lamp black trim
dragoncvpi Offline
Loc: florida
I am sorry I don't recall the part number. I am out and actually was at a store and almost bought a tube since I was out and like to keep it on hand, but I didn't. I did not know anything about the black since I have used the yellow for a long time.
#1025661 - 09/17/06 10:34 PM Re: Ford rear fascia and tail lamp black trim
metroplex Offline
08001 and 08002 are listed as "yellow" but the images on google clearly say "black" on the tube of 08001... WTF, over?
08008 and 08011 are listed as black adhesive. The 08011 appears to be suited for EPDM rubber while 08008 seems to share the same tech data sheet as 08001/08002...
#1025662 - 09/17/06 10:52 PM Re: Ford rear fascia and tail lamp black trim
dragoncvpi Offline
Loc: florida
try contacting 3M tomorrow and they could tell you for certain.
#1025663 - 09/18/06 08:38 AM Re: Ford rear fascia and tail lamp black trim
Armada Master Offline
Loc: Houston, TX
I used the "Plumbers" Amazing Goop to patch up the plastic base of my portable basketball goal which had hairline cracks and was leaking water. Worked awesome! Let dry overnight though.
2004 Ford CVPI 130k miles
1993 Chevy Caprice 5.0 V8 100k miles
1997 Ford Crown Victoria LX 4.6 V8 100k miles
1991 Chevy Caprice wagon 5.0 V8 180K
1989 C1500 175k miles
#1025664 - 09/18/06 09:19 AM Re: Ford rear fascia and tail lamp black trim
metroplex Offline
right now it is a toss-up between 3M Adhesive and the Goop. I hear Goop takes hours to set, while the 3M is almost instant. I know that a soft/flexible adhesive will work better since the OEM/Ford adhesive was a hard epoxy that can crack off upon an impact (been there, done that on the T-bird). A soft but strong adhesive will generally handle vibration and impact a lot better. And I know 3M makes some tacky adhesive... I'll try to buy the 08002 3M weatherstrip stuff and test it out on a pair of CDs (PMMA aka Plexiglass, similar to PMMA lens) to test pull strength.
#1025665 - 09/20/06 07:43 AM Re: Ford rear fascia and tail lamp black trim
metroplex Offline
Progress Report:
I'm using the 3M Weatherstrip adhesive (08002, yellow, 2 oz tube). The first time I applied it, I screwed it up and had to remove all the snot from the tail lamp and the trim. This stuff is STICKY. Solvents only re-activate the adhesive... Goo Gone did a good job of helping me remove it though. After I degreased the surfaces with Denatured alcohol, I went to town again (try #2) and made sure only to use it in the spots that needed it (4 points that the factory also uses). I set the trim and left it there. I used a pair of coaster CD-Rs to try it out (PMMA plastic) and so far they are stuck good. You could try to pry them apart, but the snot turns into a yellow solid after 24 hours.
So far, so good. I just hope the brake cleaner I used won't cause the black trim paint to fall off.
#1025666 - 09/20/06 10:30 PM Re: Ford rear fascia and tail lamp black trim
dragoncvpi Offline
Loc: florida
Progress Report:
Cool, glad it worked for you. I put an emblem on a grille one time with it, it hardly had anyplace to stick and the emblem wasn't made to be put there, but the joker never came off.
Page 2 of 2 < 1 2
1 registered (Blu), 40 Guests and 262 Spiders online.
CrystalPistol 259
bluejay_32 161
Old_Guy_Stu 109
a_d_a_m 71
Moby_Vic 66
Dmblanch 60
Ponyguy 57
DudeAbides 46
Danger2manifold 35
