You probably have the Chinese-made copies which have plain circular plastic washers on the adjuster stalks where they butt up against the header panel. Compare them with your OEM ones which will have cutouts in the plastic washers. If this is your problem just unscrew the adjusters from your regular lights and use them instead.
11 Crown Vic LX Blue 151,000 m
