#1061792 - 11/08/06 08:47 PM help with headlights on a 99 Interceptor
pabikr17 Offline
I have a 99 crown vic Police interceptor. The headlights were fogged and i could not get them clear so i purchased new ones. I installed them and am unable to get them to aim high enough. The top adjust is all the way and if i go further it pulls through the back of the headlight. Any suggestions?
Thank you for your assistance,
Jeremy
#1061793 - 11/08/06 08:56 PM Re: help with headlights on a 99 Interceptor
Queen Victoria Offline
Check the two other screws and make sure they aren't caught against the hole they fit into.
Signature removed. See rules.
#1061794 - 11/08/06 09:37 PM Re: help with headlights on a 99 Interceptor
Tony_the_Brit Offline
You probably have the Chinese-made copies which have plain circular plastic washers on the adjuster stalks where they butt up against the header panel. Compare them with your OEM ones which will have cutouts in the plastic washers. If this is your problem just unscrew the adjusters from your regular lights and use them instead.
11 Crown Vic LX Blue 151,000 m
#1061795 - 11/08/06 10:11 PM Re: help with headlights on a 99 Interceptor
Captain J Offline
Yes, unscrew the mounts from the back of your OEM lights and use them. They should not have to be aimed that much at all.
2007 CVPI (Last one was a 2002).
Mods: Paint job and a detail.
R/T Charger with more mods then can be listed (Pro Charger SC, Heads, Cam, ect...)
http://au.youtube.com/watch?v=sWS-FoXbjVI&feature=related
http://au.youtube.com/watch?v=pKFKGrmsBDk
#1061796 - 11/09/06 02:09 PM Re: help with headlights on a 99 Interceptor
pabikr17 Offline
thanks guys i will try that tonight or tomorrow morning.
Jeremy
#1061797 - 11/11/06 07:22 PM Re: help with headlights on a 99 Interceptor
pabikr17 Offline
just want to let everyone know i swapped out the adjustment knobs and everything is perfect. Thank you to all the Crown Vic guru's out there.
jeremy
5 registered (Huhnigan, Ray_Bones, Rainbowpizza, a_d_a_m, 1 invisible), 47 Guests and 192 Spiders online.
CrystalPistol 330
bluejay_32 318
a_d_a_m 219
Rainbowpizza 155
DudeAbides 141
JeffBoudah 114
Moby_Vic 99
Old_Guy_Stu 80
Ponyguy 64
BigNSlow 63
