#1087814 - 12/16/06 05:33 PM Headlights Won't Turn OFF
SonOfThor Offline
Just like the title says. 98 CV P71. From Canada, Gas engine.
Here's the situation. When the car is OFF, the highbeams are now ON, all the time, cannot turn them off. THe blue highbeam light on the dash is aslo iluminated. Same when car is running but light switch is in OFF position. Doesn't matter if parking brake is engaged or not. Same result. Now, when I switch the light switch to full ON (all the way to the right, the third position), the highbeams now turn OFF and the highbeam indicator on the dash goes out. But if I turn the switch to the parking lights or to the off position, the highbeams come on again.
What is my problem here? Or, alternatively, is there an easy way to disable the highbeam circuit altogether? I rarely use the highbeams anyhow and I'm sure it would be cheaper to just disconnect them entirely, but if it's an easy fix, I'm willing to give it a try.
Thanks.
R.I.P. 1997 Crown Victoria, Ex-Police Car. 283,000 Km: Took out a couple of signs on the 417.
1998 P71 - 196,000 Km, German Castrol 0w30.
#1087815 - 12/16/06 05:38 PM Re: Headlights Won't Turn OFF
Fordiesel69 Offline
Loc: Erie, PA
Sounds like a bad multifunction sw. Wiggle the turn signal stalk very aggesivly (without breaking it). I think this is the most common problem.
-'14 Fusion S - 160K
#1087816 - 12/16/06 08:33 PM Re: Headlights Won't Turn OFF
SonOfThor Offline
Interesting suggestion, I'll give it a try, thanks.
#1087817 - 12/16/06 08:57 PM Re: Headlights Won't Turn OFF
Phord Phreak Offline
Loc: North Central Colorado
Son of Thor (great name!),
I'd bet your CV has (or had) "Daytime Running Lights" and that's where your problem originates from. I don't have wiring schematics here to look at (we don't have DRL's on our Fords in the Lower 48) but you might check your fuse panels (under hood and under the dash by where your left knee points) If there is a fuse for this function, try pulling the fuse.... ( the problem might be a bit more tricky, like in the LCM or just a bad ground in the system)
As for the suggestion that the MultiFunction switch might be to blame, with all due respect to Fordiesel69, I just don't see how that could be.
Let us know what you ultimately find
#1087818 - 12/16/06 09:04 PM Re: Headlights Won't Turn OFF
SonOfThor Offline
Phord Phreak - (also a great name!)
I do indeed have DRL. I'll def. check the fuse panels, but I currently have no idea which fuses are used for the lighting system. I'm going to have to dig around my Ford CD and see what's up. Thanks for the suggestion!
#1087819 - 12/16/06 09:55 PM Re: Headlights Won't Turn OFF
Fordiesel69 Offline
Loc: Erie, PA
The only reason I say it COULD be is because with the IGN in the OFF position and the headlights in the OFF position, you can still pull the turn signal stalk towards yourself and the high beams will illuminate as well as the dash indicator. The multifunction SW's fail in many different ways on these cars.
#1087820 - 12/16/06 10:24 PM Re: Headlights Won't Turn OFF
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
It is the daytime running lamp unit. It is on the rad support. Unplug it and the lights will go out. You will loose the high beam indicator.
You will need to remove the platic tray between the header panel and the rad support to access the DRL module. It will be just to the right of the hood latch or on the driver's side of the hood latch. 1 8mm bolt holds it in place. Undo the bolt and then just poll on the S.O.B. until the connector lets go.
Get another one from a low milage late model at the wrecker.
#1087821 - 12/16/06 10:50 PM Re: Headlights Won't Turn OFF
SonOfThor Offline
Gord, best idea yet!! WIll def try this! thanks!
#1087822 - 12/16/06 11:37 PM Re: Headlights Won't Turn OFF
This happened to me also when my wiper motor would not park properly. It took 15 sec or so after starting the car and the lights would go on. The wiper motor sends a signal to the LCM to turn the lights on when the motor is running. I would check the MFS first, that can be done with just a multimeter.
2004 Crown Vic LX SOLD!!
#1087823 - 12/17/06 01:41 AM Re: Headlights Won't Turn OFF
SonOfThor Offline
where's the MFS? how do I check it exactly?
#1087824 - 12/17/06 02:11 PM Re: Headlights Won't Turn OFF
Corsair Offline
Loc: Port Wentworth,Ga
thats short for Multi-Function-Switch.I.E. the turn signal lever.
2001 CVPI, 3.27, LED spotlight, J-Mod, plus a few bells & whistles.
2 registered (Rainbowpizza, 1 invisible), 39 Guests and 211 Spiders online.
CrystalPistol 330
bluejay_32 318
a_d_a_m 219
Rainbowpizza 155
DudeAbides 141
JeffBoudah 113
Moby_Vic 99
Old_Guy_Stu 82
Ponyguy 64
BigNSlow 63
